Old 09-16-2005, 08:32 AM   #1
Pacobeagle
Member#: 8775
2010 "Zed" 1000
Orange/White
Default My car won't stay running.....Utec
Okay,
This thing is bugging me out. My car from one day to the next is hard to start. You start the thing, it starts and shuts off immediately!! I've done nothing to the maps at all. So I try to go to the 0% column of my fuel map on the first three rpm points and add 5% fuel. For reference I was at -4.6%. The car still turns on and shuts off. I'm running closed loop, sti pink injectors, walbro pump, IK22 spark plugs.
Any ideas?
Oh, and at one point yesterday as I was trying to start the car I noticed I had no tach on my "dashboard" section of my utec. ***, is going on.
Pacobeagle is offline   Reply With Quote
Old 09-16-2005, 09:24 AM   #2
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
you may not get a tach while the car is cranking.
do you have an obd2 scanner? clean your maf sensor for the hell of it. how old are the plugs? fuel filter? can you hear the walbro prime when you apply ignition?
Old 09-16-2005, 12:24 PM   #3
hippy
Member#: 36528
2002 Impreza Wrx
When the engine is cold, it uses higher rpm ranges in the map then when it's warm to idle. Ie-Ya might have to adjust the first 5 rpm slots in the 0% column and not just the first 3.
peace
Old 09-16-2005, 02:20 PM   #4
Pacobeagle
Member#: 8775
2010 "Zed" 1000
Orange/White
Cool, i'll try it
Old 09-18-2005, 07:07 AM   #5
Pacobeagle
Member#: 8775
2010 "Zed" 1000
Orange/White
Update, I borrowed another MAS from a buddy of mine who has an Sti. Plugged it in and also cleared all codes. Turn the car on and.........VIOLA. Everything is running fine.
So I went to my local AUTOZONE and picked up a can of Electrical parts cleaner and sprayed the snot out of my MAS. When I went to re-install, I noticed a nick on the o-ring for the MAS. So, I re-install it but I need to get a new o-ring.
Thanks for the help,
Jose
Old 09-18-2005, 07:33 AM   #6
gadget951
Member#: 18419
WR Blue
So how does it run after cleaning it?
gadget951 is offline   Reply With Quote
MY97 Impreza 2.2L -- Cleaned MAF, now car won't stay running Nihilator Normally Aspirated Powertrain 29 09-06-2015 04:12 PM
Car won't stay running with Anti-theft B map MarkRx AccessPort 17 01-25-2007 02:19 PM
Car won't stay running TylerC21 Service & Maintenance 5 08-21-2006 08:42 PM
Hydra: Car won't stay running after install 03scubaru Other Engine Management 11 07-24-2006 04:38 PM
HELP.. car won't stay running WRXonmind Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-12-2004 05:40 PM
