Go Back   NASIOC > NASIOC Subaru Models > Outback Forum
Old 09-16-2005, 01:01 PM   #1
benw82
Member#: 95830
1997 outback
Question oil issue. need help
i had my 97 outback with a 2.5 for about 3 weeks.
when i check the oil level when its cold and been sitting its right at the full mark.. if i drive it and it gets warm and i check it, its WAY above the full mark.
any ideas?
benw82 is offline   Reply With Quote
Old 09-17-2005, 10:32 AM   #2
outbackwbeer!
Member#: 64060
98 lifted FOZ M/Ts
glacier white
Oil does expand when heated ....usually ATF will do this .However, engine oil should not. Make sure you wipe clean the dipstick and recheck.
So when the engine is cold again the oil level is right at the full mark.....right?
outbackwbeer! is offline   Reply With Quote
Old 09-19-2005, 10:29 AM   #3
Mr.Sparkle
Member#: 83725
I believe oil dipsticks have a low mark, full mark, then above the full mark there is a notch. The full mark should be for when the engine is cold, but the notch above that is for when the engine is hot. Outbackwbeer is right, oil does expand when hot, which is why they have the notch to tell you the hot oil level.
Mr.Sparkle is offline   Reply With Quote
Old 09-21-2005, 11:45 AM   #4
benw82
Member#: 95830
1997 outback
when cold its right at the full mark. when i drive it around and get it to operating temp then check its sometimes above the "notch". what should i change or do????
Old 09-21-2005, 01:49 PM   #5
bluesubie
Member#: 767
04 FXT
You need to drain some.
-Dennis
Old 09-28-2005, 04:19 AM   #6
bostonblizz21
Member#: 97138
drain then clean!
bostonblizz21 is offline   Reply With Quote
Oiling issues, need help Aaron'z 2.5RS Factory 2.0L Turbo Powertrain 28 10-10-2009 12:19 AM
OT Computer Gurus: Sound Card Issues, Need Help huckedup16 Off-Topic 6 01-03-2004 01:32 AM
Electrical Issues Need Help! mRgUnN Electrical & Lighting 8 05-20-2003 04:31 AM
URGENT: Electrical Issues Need Help mRgUnN South East Region Forum 5 05-19-2003 01:56 PM
Boost Issues, Need Help kdawg Factory 2.0L Turbo Powertrain 11 12-08-2002 03:25 PM
Message Board Statistics All times are GMT -4. The time now is 06:08 AM.
