Old 09-16-2005, 02:17 PM   #1
thehatchninja
Member#: 96129
Default turboing the 2.2 (searched)
I'm just reseraching right now, but i've only been able to find info on turboing the 2.5RS....not the n/a 2.2 which is probably what I'll be buying. In the future, hopefully near future, i want to buy an impreza wagon for my winter/daily car and run low boost on it. I don't want to spend a lot, or go through the trouble of a swap. ( I know how "plug and play" swaps can be, I drive a GSR powered civic). So, i've decided that a budget setup (quality parts, with me doing the installs and fab work) with good tuning will be exactly what i'm looking for. So i'm just looking for some people with experience in this area. What are these engines like? what should i look out for? etc etc. Thanks in advance.
thehatchninja is offline   Reply With Quote
Old 09-16-2005, 02:24 PM   #2
kaisersouse
Member#: 85900
2001 Forester S
kaisersouse is offline   Reply With Quote
Old 09-16-2005, 02:25 PM   #3
83Rabbit
Member#: 5050
spend the money and turbo the GSR!!!
83Rabbit is offline   Reply With Quote
Old 09-16-2005, 03:04 PM   #4
thehatchninja
Member#: 96129
that supercharger is sweet. I know some honda guys that have used that, they can be had for cheap too. electronic clutch superchargers are hardcore....MAD MAX baby!
but in the end turbo>supercharger
i will, but then that will be my weekend car. Right now it's all motor (built/milled head, stock bottom end appx 11.4:1, revs to 9.4k) When i build the bottom end it's going to be boosted, making 350+whp. So I'll definitely need a daily driver, and since i'm probably moving to a place where it snows i'll want awd. - enter impreza wagon.
Old 09-16-2005, 03:19 PM   #5
83Rabbit
Member#: 5050
ok as long as your gonna take advantage of the GSR swap
Old 09-16-2005, 04:09 PM   #6
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Your search was nil because you are in the wrong forum. Try the Aftermarket Forced Induction forum, and you will get far better results...
Old 09-16-2005, 06:26 PM   #7
thehatchninja
Member#: 96129
thanks monson
Old 09-16-2005, 10:48 PM   #8
RallyImprezive
Member#: 5476
2007 WRX UGM
2010 FXT
Honestly I didnt read that supercharger post....but my opinion none the less:
engine swap. It may cost less in the long run. The internals on the 2.2 are not as good and the heads dont flow well, which may affect the turbo spool.
my 2 cents. Thanks.
Edit: Low boost with a small turbo might be cool though.
RallyImprezive is offline   Reply With Quote
Old 09-17-2005, 01:20 AM   #9
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
90-94 internals are just fine. Forged in fact, except for the pistons in the NA. If you add some sort of engine management, you can get 210 chp 160 whp on 7 psi. Proven. And thats with no EM. But get the EM, thats also proven, ouch.
Old 09-17-2005, 02:41 AM   #10
HondaH8er
Member#: 3097
2013 Ford Focus ST
Performance Blue
I think any turbo kit for the RS should work with the 2.2, they're both EJ-series engines, identical outside. Might need to make some adjustments with a boost controller to keep the boost where you need it, but that's not really a problem. Remember, the key to safety and longevity is tuning. Definitely get engine management.
HondaH8er is offline   Reply With Quote
Old 09-17-2005, 03:36 AM   #11
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Pull. That. Timing.
Old 09-17-2005, 08:33 PM   #12
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Originally Posted by reddevil
Pull. That. Timing.
Pull timing and add fuel that is higher octane to prevent detonation. That is all! Piece of cake!
Kevin Thomas is offline   Reply With Quote
Old 09-18-2005, 12:53 PM   #13
tonzo
Member#: 94903
1996 Impreza Wagon!
Satin Black
Subaru Stars
So you're saying with the use of engine management that you can turbo a ej22 up to round 7 psi without an engine rebuild?
tonzo is offline   Reply With Quote
Old 09-18-2005, 07:06 PM   #14
Lethargic1
Member#: 20998
Would it really be worth it though? It's going to be a pretty low output isn't it?
Lethargic1 is offline   Reply With Quote
Old 09-18-2005, 11:05 PM   #15
Kevin Thomas
Member#: 110
1989 1989 XT6
Yes! 5psi without an intercooler, 7psi with an intercooler. All you need is a fuel controller and an EGT gauge. Be sure to keep your EGT (Exhaust Gas Temperature) near where you car runs stock and you'll be fine. Be sure to use at least 91 octane (93 if you can get it). That's it!
Old 09-19-2005, 12:34 AM   #16
BrysImpreza
Member#: 3102
2012 Sport Limited
Ice Silver
You may want to try different search queries, I did a huge write up on EXACTLY HOW to turbo a 2.2 liter. I know there's tons of others as well. Search for Unique Motorsports or Subachad here or on Google and all your questions shall be answered.
If not, buy a kit from Ludespeed or F.A.T.
http://www.forcedairtech.com/
BrysImpreza is online now   Reply With Quote
Old 09-19-2005, 02:41 PM   #17
thehatchninja
Member#: 96129
from my experience with hondas i've learned it's all about tuning. With good tuning, (never any preignition detonation) I'm sure that the motor will last. IF the motor is well tuned then it's only a matter of how much cylinder pressure/power it can handle before the cast piston's ringlands go. I was planning on just retarding the base ignition timing, getting bigger injectors, and an AFC, then tuning with a Wideband O2. Although not as precise this has been proven very reliable.
Old 09-19-2005, 02:42 PM   #18
thehatchninja
Member#: 96129
most of my questions have been answered through the aftermarket turbo forum. thanks
clutch advice (yes, ive read the FAQ and searched) happasaiyan Transmission (AT/MT) & Driveline 6 01-24-2006 05:39 PM
Turbo your NA 1.8-2.2-2.5 for $800 Shipped to the lower 48 states! Jaredm83 Private 'For Sale' Classifieds 13 02-09-2005 08:09 PM
Is the 2.5 Turbo the same in the STI and Forrester? tchprivat Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 09-09-2004 07:28 PM
Will the turbo manifold from a 2.2 fit a 2.5RS??? Xscreamer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-10-2001 09:13 PM
Is there a turbo/supercharger kit for the 2.2? KaZ General Forum Archive 7 02-23-2001 01:41 AM
