Old 09-19-2005, 12:45 PM   #1
BlkTS02
Member#: 50142
2002 2.5TS
MBP
Default high-flow cat install (part two)
Some of you may remember that I had a cobb high flow cat a while ago, but I took it off because it was way too loud. I'm guessing the element started to fragment so it was essentially a track-pipe with a resonating chamber where the cat used to reside. So I was running with a stock cat since then.
Anywheres I picked up a lightly used random tech cat the other day and installed it this morning.
Fit is much better, it mated up to my revolution motorsports headers and stromung mid-pipe without incident. I picked up a 2.25 graphite donut gasket from auto-zone for under two bucks.
After getting everything bolted up I started her up and was suprised at the noise when the engine caught. Granted it was in my garage but it was alot louder than I was used to. I slid back under the car to check for leaks, none. I did notice that at idle the car was quiet, just a steady purr. I climbed out from underneath and gave her some gas.
Damn, this is addicting
So I backed of of the ramps and went for a drive.
Definately improves the car, butt-dyno notices a huge improvement in acceleration while ear-drums notice the not-so-subtle bangs and pops of unburnt fuel entering the header
I scared the crap out of some chick jogging along
Feels like I lost just a bit of low-end torque but the gain through the mid and upper end was more than worth it.
So I'm back to a full SS exhaust and a metal substrate cat which should last me a long time.
My neighbors are gonna love me now
BlkTS02 is offline   Reply With Quote
tools required for txs high-flow cat install? wmontgim Newbies & FAQs 0 01-21-2008 10:25 PM
Installed random tech high flow cat converter: Full exhaust review. powerlabs Normally Aspirated Powertrain 30 05-26-2004 07:14 PM
Looking for Universal High Flow Cat part # and specs, or suggest a 3 inch High Flow ciper Factory 2.0L Turbo Powertrain 4 07-17-2003 02:16 PM
random tech high-flow cat installed Poppa smurf Normally Aspirated Powertrain 34 10-06-2001 10:20 AM
FS...Brand New BPM 3" Midpipe with High Flow Cat installed. BADWRX Bay Area Impreza Club Forum -- BAIC 6 06-23-2001 12:31 PM
Message Board Statistics All times are GMT -4. The time now is 03:41 AM.
