Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 08-22-2001, 02:11 PM   #1
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
12 Legacy GT 13 Armada
Default Anybody Have True Ram Air Intakes Available Yet?
A friend and I at one time were trying to design an effective Ram Air system that is fed from our hood scoops. At the same time I saw a few other people designing a similar product.
I have kind of given up on designing and selling my own setup because the cost and hassle of just making them would suck.
Anyway, I am very interested in buying a well planned Ram Air system for our cars. Has anyone produced or have plans for an effective Ram Air setup?
Let me know.
Brad
[email protected]
MY99 2.5GT is offline   Reply With Quote
Old 08-22-2001, 03:22 PM   #2
JGard
pooptastic
Member#: 1904
2011 E70 X5 35D
E36 M3/4/5
from what I've seen...people have done some of their own make-shift ones... but nothing mainstream. Try 8complex...he has a Ram-air of sorts.
JGard is offline   Reply With Quote
Old 08-22-2001, 04:25 PM   #3
ImprezedRS
Member#: 2771
2003 BMW Z4
I'm still working on mine it should be done soon and after I'm done with it I will start on making and selling them.
ImprezedRS is offline   Reply With Quote
Old 08-22-2001, 06:12 PM   #4
Julian
Member#: 1182
MY00 RS
BRP
Won't happen. Not "True" Ram Air anyway. You may develop an intake that gets fed from the hood scoop, but it won't be a ram air system. Myth. Search for Ram Air here and see what results you get. Aside from all that, even on a car like the GM F-bodies that use Ram Air, the intakes (and especially the scoops) are designed with that in mind. And even on those cars, with ~300HP, the "ram air" effect is good for ~6HP at 125+mph. Now, if that's all the factory can get from something specifically designed to do so, why could an individual do better?
You may get a great cold-air system drawing air from the scoop, but don't confuse it with a True Ram Air system.
Julian is offline   Reply With Quote
Old 08-23-2001, 01:17 AM   #5
ATX25RS
Member#: 4597
2011 Mitsu Outlander
Sport (Ex-Suby owner X3)
Brucelee - What would you do about water????
I had a dragon filter throttle body mounted, but got water onto it. Now I have a heat shielded cone filter (cloth not foam or paper) mounted on the throttle body being fed from the scoop.
My two cents about the f-bodies is they are really detuned vettes. You give them to much power and they begin to compete with each other. Car companies are usually not making engines to their full potential. If that was the case there would be no aftermarket accessories.
Andres
ATX25RS is offline   Reply With Quote
Old 08-23-2001, 02:20 AM   #6
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
try this.....
<img src="http://pages.prodigy.net/burninrubber/engineshot2.jpg"></img>
the welded version is coming soon. This intake, plus a couple of other parts, makes it spin in second gear running it hard. It can run over a bumpy road, in third, and it skips bumps like a high powered v8. You can romp it, spin a bit, then take off like a rocket. As in, it hits bumps, and spins the tires if you aren't careful. G
HamFist is offline   Reply With Quote
Old 08-23-2001, 06:46 AM   #7
KillerTHC
Member#: 4942
01 SRP 2.5 RS-T
Ludespeed Stage 3 Link'd
there is something on ebay that looks amusing.
http://cgi.ebay.com/ebaymotors/aw-cg...item=594600718
http://cgi.ebay.com/ebaymotors/aw-cg...item=594570922
seems pretty cool. i dunno much about intakes and how to design a good one.
KillerTHC is offline   Reply With Quote
Old 08-23-2001, 09:36 AM   #8
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
That looks like a pretty cool idea on ebay.
I respect the guy for not call it Ram Air. It is sort of but the design would be too ineffective to create any psi.
What I mean is the design would have to be more like burninrubbers to be effective. Lets be optimistic and say that from a hood scoop fed Ram Air setup we can get 1 psi of boost. It would be more effective to have a direct feed to an open airbox like burnin, rather than have a weak flexible tube that can expand and contract under pressure.
Honestly to keep my expectations down the least an effectively designed ram air setup could do is provide cooler ambient air to the engine. Everybody knows that cool air produces more power and less chance of ping.
Burninrubber-Do you have any problem with rain? I have a design that would virtually eliminate the possibility of water damage to the engine even if you went through a large puddle.
I wish we lived a little closer. Then we could toss ideas around and really develope this thing.
My main problem is my MAF sensor. I think I have found a way to fit it safely into a ram air setup.
Brad
Old 08-23-2001, 11:01 AM   #9
adeck
Member#: 6840
2001 2.5RS
Blue Ridge Pearl
"And even on those cars, with ~300HP, the "ram air" effect is good for ~6HP at 125+mph. "
Just checked GM's website its 15hp. I had a homade *ram-air intake* that reached positive intake manifold pressures at WOT at any speed. It was too damn loud though I had to take it off.
adeck is offline   Reply With Quote
Old 08-23-2001, 12:09 PM   #10
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
adeck- How was your ram air setup designed. My design uses the rectangular filter with a big reseviour of cleaned air behind it so it will have air to produce torque from a standing start. I refuse to use a cone filter setup as they don't provide that reseviour of clean air behind it for producing torque like a rectangular setup would.
Brad
Old 08-23-2001, 12:25 PM   #11
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
You just hafta be mindful of those deep puddles. If you have the intake on there...it makes you paranoid of them. It does fine in a downpour, though. Now that we're getting good air here in Denver, I can spin the tires on the 1/2 shift. No headers, stock cats, stock engine, on 91 octane pump gas. I can also drive it just fine around 1500-2500rpm in fourth putting around neighborhoods. You never have to go below third to make it scoot. Time to go to the track. I can't wait for my flywheel, headers and cats. The instant power of an N/A car in the first three gears makes it fun. I still long for 14-18psi though. 12's or 14's...which do you think is more fun? Gary
Old 08-23-2001, 12:33 PM   #12
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
If your talking 1/4 mile times I would say 12s woudl be a lot more fun!!!!!!
Old 08-23-2001, 12:54 PM   #13
GooseMan
Member#: 2462
2012 Audi A4 Avant
S-Line Titanium
Try the Rallispec setup. The filter sits right under the pass. side hood vent, and the rest of the engine is "sealed" off, to keep the hot air from being sucked into the filter. It just sucks in purely cold air from the outside. Works for me! Got a 15.3 with it, no other mods (OK, a Brullen muffler, thats it)!
GooseMan is offline   Reply With Quote
ram air intake vs cold air intake Shaji Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 62 07-21-2002 10:05 PM
Beer + Boredom = true ram air NA intake Daveish Normally Aspirated Powertrain 30 05-05-2002 05:37 PM
Should i block off the factory ram air intake after installing cold air? keystone Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 12-07-2001 04:23 PM
Cold-air/Ram-air intake from hood vent (not scoop)? Fred Fredburger Normally Aspirated Powertrain 31 03-21-2001 12:13 PM
new TRUE ram air for 25 dollars HamFist Technical Forum Archive 2 08-20-2000 02:53 PM
