Old 09-17-2005, 02:49 PM   #1
flynbenny
Member#: 82641
2006 Baja Turbo
Question 2.5L Head Gasket
Sorry if this has been discussed before. My mechanic says my 2.5L Forester needs a new head gasket. The week before I got the timing chain, front seal, water pump, and thermostat replaced, along with a coolant flush and new coolant. Three days later, the temp gauge indicated an overheating condition and the overflow tank was spilling coolant. The next day,the overflow was dry and I couldn't see any coolant in the radiator, so I added some, but it got full around half a gallon. The CEL is on too, with code 483? or was it 438?. I drove it about 25 minutes uphill and it didn't overheat, but the fan isn't coming on. The coolant overflow was almost full though, and my mechanic added about a quart of coolant to the system. I know that the 2.5L of this age (114K, 1998 EJ25D) has a head gasket problem due to a manufacturing defect, but are these symptoms normal? Any thoughts or comments regarding this condition, and is my mechanic's recommendation correct? Thanks
flynbenny
flynbenny is offline   Reply With Quote
Old 09-17-2005, 05:17 PM   #2
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
is it possible that your mechanic didnt get all the air out of the cooling system, because head gasket jobs from an independent vary, but are not as much as the stealerships. i dont know what code yur throwing, but im sure somewhere on here there is a compiled list of the CEL codes.
~Josh~
Old 09-17-2005, 09:36 PM   #3
flynbenny
Member#: 82641
2006 Baja Turbo
I'll ask him on Monday about the coolant air bubble thing. He'll do both head gaskets for $900, which is damn good, because the lowest quote I got (Denver Metro area) was $1500. I'll go check the code thread.
flynbenny
Old 09-17-2005, 09:41 PM   #4
flynbenny
Member#: 82641
2006 Baja Turbo
Just checked the CEL thread. It's code 483, the 'cooling fan function problem'. Any comments or suggestions?
Old 09-17-2005, 11:33 PM   #5
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
To chase down problems like that you'd probably need the service manual. I'd put 12v to the fan to check it and go from there. I'm sure it would involve a relay and a signal from the ecu or coolant temp sensor.
Is the fan plugged in?
Good luck with your head gasket work.
Tim Sanderson is offline   Reply With Quote
Old 09-18-2005, 03:26 PM   #6
flynbenny
Member#: 82641
2006 Baja Turbo
Yeah we checked and both fans ran fine when we engaged the A/C. But the wiring diagram he showed me (in the svc manual) also indicated that if the relay was bad this problem could occur. I will make sure he looks into this also. Thanks
flynbenny
Phase I 2.5L Head Gasket Failure Question Hovmerlin Warranty Issues & SOA Problems 1 02-12-2007 07:03 PM
Phase I 2.5L Head Gasket Failure Question Hovmerlin Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 02-11-2007 07:20 PM
2.5L head gasket recall not covered Spy Warranty Issues & SOA Problems 9 10-04-2006 01:13 PM
2.5L head gasket recall not covered Spy Vancouver Impreza Club Forum -- VIC 19 09-16-2006 04:22 PM
2.5l head gasket info page outback_97 Normally Aspirated Powertrain 0 07-16-2003 04:49 PM
