Old 09-17-2005, 07:31 PM   #1
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Default Warning for 2.2ltr Single Exhaust Port and Borla
The Borla single port exhaust header does not fit the 2.2ltr automatic trannied Impreza properly. It is really really tight and one of the holes did not mate up properly. The last hole had to be drilled out out to make it fit. It was not a direct bolt on. That is all!
Kevin Thomas is offline   Reply With Quote
Old 09-17-2005, 07:33 PM   #2
svek
Member#: 82259
1999 impreza 2.2L
Brilliant Red <4EAT Club>
whats funny is when you go to their site, you pick out your car and everything, then it asks what tranny you have, but either one you click gets you the same part #
thanks for the info btw
svek is offline   Reply With Quote
Old 09-17-2005, 07:41 PM   #3
shoeler25
Member#: 52202
2001 2.5RS
Did you try contacting Borla at all about this? And what generation header is it? That was a problem they had with older generations. My 2 port 2.5 header mated up quite nice.
shoeler25 is offline   Reply With Quote
Old 09-17-2005, 07:48 PM   #4
G.Subramaniam
Member#: 64528
Rallispec installed a single port borla on my 2.2L and did not report any problems
G.Subramaniam is offline   Reply With Quote
Old 09-17-2005, 11:35 PM   #5
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Most of the borlas fit a little tight on the head exhaust studs. They don't have any expansion joints. I think that's also why the tend to crack.
Tim Sanderson is offline   Reply With Quote
Old 09-18-2005, 03:07 AM   #6
99subi
Member#: 78118
2002 Corvette coupe
05 Legacy
my borlas sucked i say this evrytime im in a header thread, well they rattled to say the least
99subi is offline   Reply With Quote
Old 09-18-2005, 10:23 AM   #7
G.Subramaniam
Member#: 64528
Thats why Rallispec puts in a flex-link on borlas
Old 09-18-2005, 06:04 PM   #8
Lethargic1
Member#: 20998
Good info man, thanks.
Lethargic1 is offline   Reply With Quote
Old 09-18-2005, 08:35 PM   #9
Blue98leg
Member#: 65036
2013 WRX
Yeah i had to bore mine out. My second set though, the first went straight on.
Blue98leg is offline   Reply With Quote
Old 09-18-2005, 10:00 PM   #10
Kevin Thomas
Member#: 110
1989 1989 XT6
No I did not. I do not expect them to do anything about it. I'm not really concerned because I wanted the Borla header for dyno testing. Unfortunately, since I work my butt off, I did not have the time to do the drilling myself and so I let the dealership do it. There went my dyno $$$. I just wanted to warn others of this. Forget tight fitting, it should be able to slide on just like my stock header. I just wanted to let those 'home mechanic' wannabes like me know what they are in for when they try to fit it on.
I never tried to slide it on with all the studs in place. One of my studs came out with the nut so I tried to put the stud on 'after' I installed the header and the stud would not screw in. I should've taken the header back off but I had to bang it in place in the first place. Time was little and I wanted it on NOW. I haven't had the time to deal with it since. Part of the problem is that I have 3 other projects going on as well (Both Subaru XT6s and Subaru RX turbo), hence little time.
Old 09-18-2005, 10:20 PM   #11
shoeler25
Member#: 52202
2001 2.5RS
Yeah, I didnt mean try to get Borla to replace it or whatever. I was just sayin maybe they could document it and if enough people complained, maybe something would be done. Or they might be able to say how many other people have seen the same thing.
3rd-FS Borla headers for 2.2L single port Legend STI Scammer Central 8 12-26-2008 11:45 PM
2.2 Single exhaust port - enlargment cjfike Normally Aspirated Powertrain 6 08-24-2004 10:59 AM
Headers for 2.2L single port G.Subramaniam Normally Aspirated Powertrain 1 07-08-2004 02:03 PM
When did the 2.2L heads change to single exhaust ports? subysouth Normally Aspirated Powertrain 2 09-06-2001 12:25 AM
Does MRT make a single exhaust port header for the 2.2L? 96Lconversion Normally Aspirated Powertrain 4 03-14-2001 12:38 AM
