Old 09-17-2005, 07:48 PM   #1
7andSubie Owner
Member#: 85426
Default Oil in spark plug hole
First of all, forgive my ignorance if this is a stupid noob question - I've been driving a rotary for 9 years so this is a new-fangled engine to me
I bought new spark plugs today for my 2000 Legacy (2.5L). I was just now looking at how difficult a job it would be and for the heck of it tried removing the boot from the #1 plug. Other than not even being able to get the boot off the plug, I also ran into what - to me - seems to be a problem.
There is a fair amount of oil coming from the chamber - enough to run down the side of the block and drip onto the garage floor. Now, as I said, I'm a bit ignorant on non-rotary engines, but this seems very NOT right.
If I am correct on this and it is not normal, what is it a sign of? The car has been running fine, although slightly rough at idle (which is a large reason for buying the new plugs). I haven't noticed any smoke or anything, but I do occasionally get a whiff of something that smells at least a bit like oil burning.
Any thoughts on this would be greatly appreciated! Luckily, I purchased an extended warranty when I bought in May 04.
Thanks!
7andSubie Owner is offline   Reply With Quote
Old 09-17-2005, 07:55 PM   #2
Hayes
Member#: 11808
Your spark plug seals are shot. You just need to do a valve cover gasket and SP seal replacement. Not uncommon.
Hayes is offline   Reply With Quote
Old 09-18-2005, 12:51 AM   #3
7andSubie Owner
Member#: 85426
How complicated is that? Also, is it something likely to be under the extended warranty?
This car is used for work, so I need to resolve this quickly (~4000 miles/month).
Old 09-18-2005, 12:52 AM   #4
7andSubie Owner
Member#: 85426
Almost forgot.... Thanks!
Oil inside spark plug holes 240c Forester Forum 5 09-15-2009 03:34 PM
Oil in spark plug tube Flexy Service & Maintenance 16 09-16-2005 12:17 PM
2.2L Crankshaft Positioning Sensor needed - also, oil in spark plugs question marcus12 New England Impreza Club Forum -- NESIC 10 01-11-2005 02:49 PM
Oil in spark plug hole, 91 2.2??? rallynutdon Legacy Forum 8 10-22-2004 12:08 PM
Oil in spark plug NickSTi South East Region Forum 8 08-27-2002 08:55 PM
