Welcome to the North American Subaru Impreza Owners Club Saturday October 10, 2015
Old 09-18-2005, 04:15 AM   #1
Member#: 74461
1998 Impreza 2.5 RS
WRC Blue
Default Exhaust manifold replacement
The factory manifold and converters on my 98 RS are in really bad shape. The manifold itself is cracked, and the converters look pretty beaten. I've installed a cat-back from the 04 STi and now wish to just upgrade the rest. I'd like an exhaust system that performs, and doesn't lose the boxer note. Should I go with a header, or test pipes? The car is supercharged and this is apparently my weak point. Thanks
scoobysouth is offline   Reply With Quote
Old 09-18-2005, 05:25 AM   #2
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
Hey, I'm planning on Supercharging my 98 RS also. But i'm shooting for alot more boost and power than you probably have. Either way, I'd recommend a Tech Works Engineering High flow cat section, and then some borla headers to keep/magnify your boxer note.
I was going to go with the EL High Output headers, HO High-flow cat section, HO midpipe with resonator, and then probably a Magnaflow muffler. This will probably ruin my chances of hearing the boxer note from my car. But i'm not hearing it now and i've got a 02 WRX Cat-back.
BTW, what Supercharger system do you have?
Old 09-18-2005, 11:32 AM   #3
Member#: 1197
1997 Impreza Wagon
Mystic Blue Pearl
FWIW, the "boxer sound" is the result of unequal/unbalanced headers. The stock headers result in some really weird exhaust pulse orders, so they make the funky sound. Unfortunately, it's the sound of inefficiency.
If you're looking for the best power, look for an equal-length setup like the Tech Works. If you just want a cool sound, the Borlas are well-loved (as mentioned above).
Portly is offline   Reply With Quote
WRX utec, STI intake manifold, sti exhaust manifold, sti up pipe Antyoo Engine/Power/Exhaust 4 10-21-2006 04:19 AM
'06 WRX exhaust manifolds vs. STi manifolds 1-3-2-4 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 05-08-2006 10:34 PM
Replacement bolts for exhaust manifold WR^2X Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 03-13-2006 09:55 PM
STI exhaust manifold and wrx manifold EdsWRX Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 06-09-2005 10:27 PM
2.5GT exhaust manifold vs. WRX manifold parklax Legacy Forum 12 08-19-2003 11:18 PM
