Old 09-18-2005, 12:28 PM   #1
randomthoughts
Member#: 71810
05 Evo 8
Question This Cant be Safe
Ok so i have some mods done to my 02 like stg 2 accessport, aps fmic and full exhaust, shortram, I installed a mbc today messing around with it i hit and hold 1.7 bar on stock internals and turbo, whats the range for the td04 and is this safe at all. Let me know.. Buy the way it halls ass setup like this....
randomthoughts is offline   Reply With Quote
Old 09-18-2005, 12:33 PM   #2
scooterforever
Member#: 55011
Of course it does, you're running 24 lbs of boost and are probably lean as hell. If you're gauge is reading right, you are beyond the efficiency range of the stock turbo. So what are your EGTs and AFRs?
Edit: you have $$$$ saved up for a new block, right?
scooterforever is offline   Reply With Quote
Old 09-18-2005, 12:47 PM   #3
ChgoJay
Member#: 71722
The stock turbo cant move 24psi of boost. Check your gauge.
ChgoJay is offline   Reply With Quote
Old 09-18-2005, 12:50 PM   #4
anthonyrb98
Member#: 48307
02 bugeye
hbspeed tuned 18g sleeper
does your car run ok with the fmic?
anthonyrb98 is offline   Reply With Quote
Old 09-18-2005, 12:54 PM   #5
LotusDriftx
Member#: 48528
Check your math, 1.7 bar is pretty much equivalent to 24psi.
LotusDriftx is offline   Reply With Quote
Old 09-18-2005, 01:01 PM   #6
randomthoughts
Member#: 71810
05 Evo 8
The car runs fine, with the fmic, and i havent a bit of problems running that much. But i wanted to check cause i was going to turn it down.
It seems like the turbo moves the air just fine
Old 09-18-2005, 01:02 PM   #7
LOLSTi
Member#: 51452
2004 Subaru WRX STi
1992 Mazda Miata
his guage is obviously wrong.. the stock td04 literally can not produce 24 lbs of boost without the EJ20 blowing itself to pieces.
LOLSTi is offline   Reply With Quote
Old 09-18-2005, 01:04 PM   #8
randomthoughts
Member#: 71810
05 Evo 8
OH and by the way why i have a chance to holla at yall which would be a good turbo to run with this much boost. I have been toying with the idea of T3 to4e 60 63.5 ar or a gt 30
Old 09-18-2005, 01:12 PM   #9
scooterforever
Member#: 55011
Just please don't try to run whatever bigger turbo you get with the AccessPort. You're already pushing your luck now with the MBC, intake and FMIC.
Old 09-18-2005, 01:31 PM   #10
ChgoJay
Member#: 71722
Thank you.
Old 09-18-2005, 01:33 PM   #11
LotusDriftx
Member#: 48528
actually I read the post wrong, sorry about that.
Old 09-18-2005, 01:41 PM   #12
ErikAnderson
Member#: 26739
Turning it down would probably be a good idea. You are strongly running the chance of doing horrible things to a) your turbo b) your motor or C) all of the above.
Save up and get a bigger turbo.
ErikAnderson is offline   Reply With Quote
Old 09-18-2005, 01:50 PM   #13
darkstarmoto
Member#: 44681
2011 WRX SWP Hatch
www.48hrs.info group lead
Why are you running an MBC with and Accessport anyways?
darkstarmoto is offline   Reply With Quote
Old 09-18-2005, 05:07 PM   #14
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
....I thnk a ***BOOM*** thread is upcoming....
Old 09-18-2005, 05:14 PM   #15
ms3p
Member#: 51596
2014 FiST
2006 SV650S blue hotness
12345
ms3p is online now   Reply With Quote
Old 09-18-2005, 05:15 PM   #16
Drews_WRX
Member#: 20354
2005 SRT-4
POS Mopar stage 2
I wouldnt know about 24psi, but when I was messing with my MBC for the first couple times (on stock ECU and stock TMIC) I was hitting 20psi....and probably did this for 5-6 pulls. My motor and turbo are still good with 80k on the clock.
Im sure the FMIC is helping alot to cool down those HOT turbo temps...
BUT please turn the boost down to atleast 16-17psi.
Drews_WRX is offline   Reply With Quote
Old 09-18-2005, 06:26 PM   #17
randomthoughts
Member#: 71810
05 Evo 8
the acessport isnt all that great in the first place. A utec or something like that would be a much better investment
Old 09-18-2005, 06:44 PM   #18
boost4life
Member#: 75129
09 WRX stg 2+
Lost the boxer rumble
Uh , yea that sounds like madness, if you got a access port and hitting 24 psi on the tdo4 that is bad news and just plain stupid, granted 24 psi not the same as 24psi on a larger turbo but it's the turbo im worried about along with your IDC's AFR's and EGT's , I know it's not holding that boost but rather spiking to 24psi. And tghe FMIC loose it till you get a` larger turbo. I think this thread is gong to have a bad ending .
boost4life is offline   Reply With Quote
Old 09-18-2005, 07:14 PM   #19
BVM
Member#: 41049
2010 Impreza WRX
KTM 250sx
Even if the TD04 could push 24psi, it wont last very long doing it. Since I have raised my boost to 17.5 my turbo has become much louder over the last year (anytime in boost no matter the amount).
BVM is offline   Reply With Quote
Old 09-18-2005, 08:26 PM   #20
KitchenerWRX
Member#: 79934
02 WRX
MBP
^^ its louder cuz its spining faster, 17.5 is maximum it can handle before going out of efficiency and putting un needed stress on it
KitchenerWRX is online now   Reply With Quote
Old 09-18-2005, 08:41 PM   #21
Cusson
Member#: 95695
2003 WRX Sedan
ACLASS
hahahaha i agree...
but on a more serious note, your stock turbo should not be running that high, i'd be careful if i were you cause your car could be in big trouble.
Cusson is offline   Reply With Quote
Old 09-18-2005, 08:47 PM   #22
BilW
Member#: 62003
02 WRX
The lag has to be killer with the stock turbo and APS FMIC. I ran 21 ps for a while with stock turbo, felt great, but everything else was off, high egt, lean conditions, etc...Do yourself a favor and listen to a couple of these guys here. 17.5 is enough, unless you have cash in hand for a motor build!
BilW is offline   Reply With Quote
Old 09-19-2005, 03:25 AM   #23
darksands
Member#: 75122
2005 Impreza WRX
Crystal Gray
your right, its not safe... so stop being unsafe before your engine blows.
darksands is offline   Reply With Quote
Old 09-19-2005, 04:39 AM   #24
spongejosh
Member#: 62783
Midnight Black Pearl
you are taking a chance just buy having all of that "extra" stuff on your accessport stage 2. turning the boost up that high is just stupid at this point.
sell the fmic, intake and mbc and buy a vf34 and injectors. that way you are at least at a safe tune (cobb 2.5).
or sell the AP and buy a utec. but imho if you get a utec and try to tune it yourself, you're probably gonna blow the car up anyway.
josh
spongejosh is offline   Reply With Quote
Old 09-19-2005, 05:57 AM   #25
BVM
Member#: 41049
2010 Impreza WRX
KTM 250sx
I dont think you read my post well enough, I said louder no matter what boost level. Its just wearing out.
this cant be good for your subie. wrxsnowstyle General Community 9 10-30-2006 10:27 PM
This cant be wtlw HighWayDrifter Off-Topic 24 11-20-2003 12:05 AM
Whoa whoa whoa... this cant be! KooK Newbies & FAQs 20 02-20-2003 01:18 PM
ummmm, this cant be safe Bankheist Texas Impreza Club Forum -- TXIC 4 12-11-2002 10:25 PM
WHAT THE!! This cant be right. RotarFreak Warranty Issues & SOA Problems 4 02-12-2002 10:05 PM
