Old 09-18-2005, 03:56 PM   #1
sickmint79
Member#: 54385
Default lug torque specs, 05 sti ?
maybe i just suck at reading the manual, but i can't find this. help?
sickmint79 is offline   Reply With Quote
Old 09-18-2005, 04:05 PM   #2
sdogg3kgt
Member#: 38397
2002 Lovemachine
I "think" I heard somewhere it's 32lbs ft.
sdogg3kgt is offline   Reply With Quote
Old 09-18-2005, 04:08 PM   #3
Member#: 67
1999 Outlasting
the competition.
Close :P
i usually run them to 75-80 pounds
tom
Old 09-18-2005, 04:09 PM   #4
sdogg3kgt
Member#: 38397
2002 Lovemachine
Originally Posted by [email protected]
Close :P
tom
haha. never mind. must have been for something else then.
Old 09-18-2005, 04:24 PM   #5
sickmint79
Member#: 54385
32/33 is what i've heard for the oil plug
75-80 aight, where is this in the manual exactly?
Old 09-18-2005, 04:31 PM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Old 09-18-2005, 10:03 PM   #7
tuskenraider
Member#: 65699
15 WRX
WR Blue
I use "That feels about tight".......has worked for years.
tuskenraider is offline   Reply With Quote
Old 09-18-2005, 10:17 PM   #8
Shoppingcart
Member#: 94378
2006 wrx sti
blue/gold
85lb's on the tq wrench
Shoppingcart is offline   Reply With Quote
Old 09-18-2005, 10:31 PM   #9
Uncle Scotty
Member#: 16200
OK buy Nates beans
....overtorquing lugs is a PERFECT way to stretch them and make them break at the worst possible time....
...and it really is unnecessary.
Old 09-19-2005, 09:01 AM   #10
conker69
Member#: 59692
2005 Impreza WRX STi
WRB-Gold
I have the service manual but I can't remember which section it is listed in....but if I get time I will look.
conker69 is offline   Reply With Quote
Old 09-19-2005, 04:43 PM   #11
DimSum22
Member#: 37968
(i.e. - torque in star pattern to 30 ft-lb, then 60 ft-lb, then 90 ft-lb)
Use a quality torque wrench: IMO, the craftsman 1/2" torque wrench you can buy at sears is about as low as I would go in terms of quality. Be careful not to drop or bang the torque wrench on anything, as the shock will affect the calibration of the tool, and remember to always back the tool back down to a few clicks above its lowest point. Note: I am talking about a Non-beam torque wrench. The beam torque wrenches, while more rugged, are much more difficult to use.)
DimSum22 is offline   Reply With Quote
Old 09-19-2005, 10:54 PM   #12
Ramsdale
Member#: 1951
08 M3
Crack open your owner's manual to page 9-12.
Ta-da.
Alternatively, good ol' page 13-9 can be read, which refers you to the above.
KR
Ramsdale is offline   Reply With Quote
Old 09-19-2005, 11:49 PM   #13
Uncle Scotty
Member#: 16200
OK buy Nates beans
Originally Posted by DimSum22
30/60/90
....w0w....so you are overtorquing your lugs by ~90%...GREAT....
Old 09-20-2005, 12:02 AM   #14
AndrewSS
Member#: 51674
2005 Subaru WRX STi
WRB/GOLD
ive got a crappy harbor freight torque wrench... isnt it ok?
anyway, say you suspect your lugnuts might have become a bit loose after an autox or whatever, i just dial about 70lbs and torque them (star pattern) thats the proper way to do it... right? you dont "add" that amount to the torque the actual nuts are at before the tightening... am i understanding it right... when the thing clicks and its set at 70lbs, the nuts are set at 70lbs, it doesnt "add" 70lbs to the nuts??? someone explain this for a n00b please
AndrewSS is offline   Reply With Quote
Old 09-20-2005, 12:18 AM   #15
sickmint79
Member#: 54385
andrew you are correct on how the wrench works
and rams thanks for pointing out the pages !
Old 09-20-2005, 12:32 AM   #16
schuey_1
Member#: 72524
05 Subaru WRX Sti
I have the WRX impreza service manual the same one that all subaru mechanic use.And they recomend 65.7 Ft-lb
schuey_1 is offline   Reply With Quote
Old 09-20-2005, 07:53 AM   #17
conker69
Member#: 59692
WRB-Gold
What section is this in?? Just curious.
And that does sound correct. This has been discussed before....no need to go way over this number like some people are suggesting nor is there anything wrong with using a Craftsman torque wrench. Been using one for some time now....works great.
Old 09-20-2005, 11:37 AM   #18
Uncle Scotty
Member#: 16200
OK buy Nates beans
I posted the god damned page, above......what part of that is difficult?????
Old 09-20-2005, 11:40 AM   #19
conker69
Member#: 59692
WRB-Gold
I missed that...sorry. It cracks me up that I can't remember which section that information is listed in.
Old 09-20-2005, 11:43 AM   #20
Uncle Scotty
Member#: 16200
OK buy Nates beans
....sorry......but usually, usually-----in these cases, I post the page out of the FSM.
...it is also in the owners manual
Old 09-20-2005, 11:47 AM   #21
conker69
Member#: 59692
WRB-Gold
Right...same here when I can help give people the correct information.
Actually I was talking about which section in the FSM such as....Body, Transmission, STi Engine, Chassis, etc. All of my FSM PDF files are "coded" so I am trying to learn where some of this information is located without having to look through everything each time.
Old 09-20-2005, 11:52 AM   #22
Uncle Scotty
Member#: 16200
OK buy Nates beans
chassis------>wheel & tire system(see WT-5, WT-6 at the bottom of the above pages)
...easy
Old 09-20-2005, 11:57 AM   #23
conker69
Member#: 59692
WRB-Gold
...easy
It should be but not when files are name like this:
MSA5T0515A69723
Old 09-20-2005, 12:51 PM   #24
Uncle Scotty
Member#: 16200
OK buy Nates beans
MSA5T0515A69723
u got jacked on yer manual...
Old 09-20-2005, 03:38 PM   #25
DimSum22
Member#: 37968
~90%?
Lug Torque Spec '10 WRX? STI 2 NV Tire & Wheel 8 02-19-2010 07:45 PM
Lug Torque Spec Big-E Brakes, Steering & Suspension 1 10-18-2006 08:49 PM
Camry wheel lug torque spec re92 Off-Topic 10 09-11-2005 12:39 AM
Wheel Lug Torque Specs WTypeRogerX Tire & Wheel 2 02-12-2003 03:38 PM
stock wheel lug torque specs pwrup25RS Brakes, Steering & Suspension 19 02-10-2001 12:02 AM
