Old 09-18-2005, 07:44 PM   #1
impreza4show
Member#: 93822
97 impreza L
hot lava orange
Default NEED HELP ASAP!!! With 02 sensors.
Hey guys, i have a 97 impreza L 4 door with a 2.2L and automatic. i recently dropped my exhaust but forgot to unplug my o2 sensors. so now i wen't to hook up and i have 3 wires...1 black...2 white on both the cat and pre cat sensors. If anyone knows which hole these wires go into on the actual plastic plug i would really appreviate it. thanks.
impreza4show is offline   Reply With Quote
Old 09-18-2005, 09:34 PM   #2
tmeh
Member#: 30800
2000 .7 RS
so one side ripped out?
you should be able to see the same colours on the other side of the plug then, no?
tmeh is offline   Reply With Quote
Old 09-19-2005, 10:01 PM   #3
impreza4show
Member#: 93822
97 impreza L
hot lava orange
no the inlet wires are 2 white and 1 black and the outlets are yellow, red and white/black
Need help ASAP with smoking engine problem! PLEASE HELP! DJS_02_WRX Newbies & FAQs 14 10-10-2009 09:59 AM
HELP ASAP rear 02 sensor doesn't reach!!! maxipad Normally Aspirated Powertrain 30 01-30-2008 07:36 PM
NEED HELP ASAP with oil feed line onyxhunter Tri-State Area Forum 2 09-28-2004 07:06 PM
Need Help ASAP with borla system jin88 Normally Aspirated Powertrain 8 12-23-2002 09:53 AM
Need help ASAP with uppipe/turbo install jmaiken Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 09-20-2002 02:25 PM
