Old 09-19-2005, 02:49 AM   #1
pete wood
Member#: 96386
1960 VW buggy + EJ25
Ford Mulberry
Lightbulb Adjustable cam gears for an EJ25 DOHC?
Hi, I have an EJ25 DOHC motor (with factory loom and ECU) in my VW buggy. It goes well, but I wondering whether is any gain in performance to be had from these motors from adjustable timing gears on the stock cams. Also, if this is possible, will the factory ECU accommodate the changes or will it need to be chipped or retuned in some way? (I really need to keep the factory ECU for budgetry and registration reasons.) Also, will a set of cam gears for an EJ20 fit the EJ25? I know they share the same timing belt, so I reasoned this might be the case.
I ask this because I am in Sydney, Australia and no one over here pays much attention to this motor. Seems to me that with 2.5l and 10:1 comp ratio, it should be able to do a little better than 165hp at 6000rpm. What do you guys think?
pete wood is offline   Reply With Quote
Old 09-19-2005, 04:04 AM   #2
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Nobody has done adjustable cam gears for the EJ25's. There was a reason for it, but its been years since ive seen the info about it so I dont remember.
Meanwhile, read through Cobbs website for more info about stuff you might actually want to consider doing:
http://cobbtuning.com/impreza/
Old 09-19-2005, 06:11 PM   #3
John*G
Member#: 19562
95 coupe
red
If your only looking for 3-4 degrees try experimenting with a offset crank shaft key. You may have to make one yourself. They are used in V8's a lot and you maybe able to modify one.
John*G is offline   Reply With Quote
Old 09-19-2005, 11:13 PM   #4
pete wood
Member#: 96386
Ford Mulberry
Thanx, Already got a big aftermarket air cleaner and revised exhaust. Love to get some cams like that. Unfortunately my problem is that the company being in the US, it will cost me over $2000Aust by the time I get it here coz I am not sending my factory cams to them. I need to keep them if they need to go back in at some stage. $2k for max 10hp is very expensive. Does anyone have the specs for the stage three set of cams? Maybe I can get a set ground over here for cheaper. BTW, are EJ25 cams the same as EJ20s or do they differ in size?
Old 09-20-2005, 12:06 AM   #5
2slofouru
Member#: 90539
95 L with ej257k
powa, Raven R6
Probably wouldn't be a good idea to play with cam gears. You might have a little bent valve action happenig if you do.
2slofouru is offline   Reply With Quote
adjustable cam gears for the exhaust side of AVCS heads tino Built Motor Discussion 19 09-20-2009 07:14 AM
Adjustable Cam Gears for GC8 Required David_Wallis Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 05-07-2004 07:46 AM
AEM Adjustable Cam Gears For WRX Imprezer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 29 05-07-2002 07:55 AM
Adjustable cam gears for DOHC? Tangmere Normally Aspirated Powertrain 4 01-07-2002 10:52 AM
Adjustable Cam gears for SOHC Jaxx Normally Aspirated Powertrain 12 09-15-2001 05:01 PM
