Welcome to the North American Subaru Impreza Owners Club Friday October 21, 2016
Old 09-19-2005, 05:18 AM   #1
Member#: 92562
Default 2K RS: Coolant Leak and Sloshing Sound
Hey guys,
I have recently discovered that my 2k rs is leaking coolant pretty bad after smelling sweetness during driving. I will get that taken care of at the dealership, as I recently had work done on the engine.
However I had a few questions about this whole thing, and was hoping I could try to understand whats going on.
1. The coolant is leaking in 2 locations.. right under the engine and at the front, where the radiator connects to the block. Seeing as how it seems to be leaking from more than 1 location, could there be an issue with the pressure of the cooling system, a corrosive additive, or somethig else just wrong?
2. At about the same time this issue occured, I started noticing that at initial startup, there would be a watery sloshing sound coming from my engine when I would rev it. The sound would go away though after a minute or so. Is this a coolant related issue or possibly something else?
Any advice and info would be great.
Thanks in advance
skuwahara is offline   Reply With Quote
Old 09-19-2005, 07:34 AM   #2
Member#: 95157
05 Impreza RS 2.5
OBP 5spd Winged
Take it in right away.....make sure you put some water or coolent in there.....the sound you hear is the lack of coolent in the system as it starts to presurrize its like a straw with a hole in it....the leak is more then likly only in one spot and run off is making it seem like multiple leaks "ei"lower rad hose,water pump,radiator so on.....take it in right away!!
Boom05rs25 is offline   Reply With Quote
Old 09-19-2005, 11:18 AM   #3
Member#: 18074
2008 Speed3
Mine did the same thing when my headgasket blew. What's your mileage?
C-daleRidr is offline   Reply With Quote
Old 09-19-2005, 11:37 AM   #4
Member#: 71361
2000 Impreza 2.5RS
Default been there.
SOA will warranty MY00 head gasket... Mine was replaced at just over 60K before I bought it (the radiatior failed and it overheated. The Dealer replaced the radiatior and said things were fine. Two years and a couple leakdown tests later, they fixed the gasket, new cyl head, and a bunch of other stuff.) Don't forget to get them to add the Bars-leak....er,
Radiator Coolant Conditioner when they're done.
Another thread on the matter.
mrpedal is offline   Reply With Quote
Old 09-19-2005, 04:46 PM   #5
Member#: 65227
Sometimes my 99' Forester 5MT, when cold, will make a sort of watery churning sound behind the dash. I'm pretty sure it's just the water pump flowing coolant through the heater core and hoses.
medfurd is offline   Reply With Quote
Old 09-19-2005, 10:35 PM   #6
Member#: 92562
Default thanks
thanks for your help everyone.
yea, i'll be taking it in tomorrow. i filled up the resvoir with lots of coolant for my drive up (hopefully not too much, if there is such a thing).
to reply to the question about the mileage, its a car with 116K, but a brand new stock engine in it that has about 2K on it. The dealership threw in a 30,000 mile warranty with the engine, and I'm hoping this will get covered, since it seems to be an issue with the connection of the cooling system to the engine.
thanks also about the water churning sounds. thats good to know, and hopefully i wont have to hear it too much more.
Old 09-20-2005, 10:09 AM   #7
Member#: 51642
2008 WRX
Yep my 01RS make the watery sound every so often on start up and even occasionally during stop and go traffic.
DreddRS25 is offline   Reply With Quote
Coolant leak and need help hellr4iser Newbies & FAQs 4 05-29-2009 08:57 AM
Coolant leak and hiss... Nick Boxler Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 04-06-2009 04:29 PM
Water sloshing sound when revving and clutch in? affinity1 Newbies & FAQs 7 04-02-2006 11:07 PM
STI 04 water sloshing sound in cowl area WickedSTI Impreza Forum 5 04-20-2005 04:12 PM
sloshing sound + low coolant OneInchPunch Service & Maintenance 3 03-27-2004 04:39 PM
