#1 |
Member#: 6072
SCIC
Vehicle:01 Silver 2.5 RS 04 Silver WRX STi |
Has anyone pulled off the panels under the hood scoop and vents?
Any advantages/disadvantages? Any problems caused by removing the panels?
#2 |
Miss You Mom
Oct 1940 - Feb 2008 Super Moderator Member#: 809
NESIC
Vehicle:2000 2.5 RS, '14 For 92 5MT SVX |
<FONT face="Comic Sans MS">Everyone, go easy....
. I have both vent plates off and my hood plate cut open (long story). No problems at all to report. If you have a cold air intake with a cone filter right under the vent, you might want to reconsider as rain will wreak havoc. Three or four people will post that the battery can't get wet- hogwash, as it does anyway from A) the drain holes in the plate and B) from the water that sprays in behind the drivers headlight and between the headlight and the hood. ![]() Brian AIM: captaindamorgan ICQ: 84483950 http://ravensblade.cjb.net "Eureka!" may be loosely translated as "Duck! It's gonna blow!"</FONT f> |
#3 |
Member#: 4311
My hood scoop and vents are open all the time, no problem at all..... (so far)
#4 |
Member#: 4636
Vehicle:2001 1st Gen |
i took mine out for awhile on da intake side...unfortunatly it was durin my trip to ny when there was a BIG Flash flood....engine is fine but...a friend of mine who got his car da same as mine....i noticed it was alot more dirty then his....mustve been all that rain.....so i jus spaced them wit a one inch faucet washer...and cleaning the entire engine an polishing it soon...
and also cut out the back part of the hood scoop plate... [This message has been edited by Accurit (edited May 11, 2001).] |
#5 |
Member#: 3097
NWIC
Vehicle:2000 2.5RS Coupe Silverthorn Metallic |
I have the vents spaced to let hot air out, but haven't done anything with the hood scoop plate. Probably won't, either, but that's just me. Lucky this is your first post, anybody asking that question with more than 10 posts would get shredded! You probably don't know about it, but there is a "search" function up in the upper right area, and a lot of times, you can find the answers you need by looking there. Just a little sumpin' fer next time
#6 |
Member#: 1910
NESIC
Vehicle:2 Left Feet |
I removed the hood scoop plate and will be adding spacers this weekend for the vents. Taking the blocking plate off the hood scoop was easy. Like 15 screws and 2 of those irritating compression rivet thingees. I'd have done the vents at the same time, but I didn't have any spacers...
#7 |
Member#: 2817
Vehicle:2001 Impreza 2.5RS BRP |
I took the center vent off, and put 2 layors of window bug screen instead. No worries of debris going in and hitting the airbox. No problems whatsoever so far.
| Thread Tools | |
| Display Modes | |
| Hood Scoop and Vents backing plates and other RS stuff | 2.5 Blue Roo | Private 'For Sale' Classifieds | 27 | 07-10-2004 05:14 PM |
| FS: RS hood scoops and vents | ImprezaTs | Private 'For Sale' Classifieds | 14 | 11-11-2003 12:51 AM |
| OBS 2.5rs hood scoops and vents | pitcrew | Private 'For Sale' Classifieds | 16 | 11-04-2003 04:32 PM |
| For Sale: Carbon fiber hood scoop and vents | Merc | Tri-State Area Forum | 11 | 04-11-2002 07:58 PM |
| hood scoop and vents | Kaotikimpreza | Interior & Exterior Modification | 4 | 06-28-2001 01:27 AM |
