Old 09-19-2005, 02:22 PM   #1
tonyakavw
Member#: 83536
Default Timing Belt install questions
I'm replacing the timing belt on my 2001 2.5RS engine and after cutting off the old one I noticed that I hadn't rotated the engine such that the cams have their indicator pointing straight up. Is this a problem? When I go back to put the new belt on, how can I ensure that the alignment is still on? Could I possibly get it on pretty close (within a tooth or two), rotate the engine to the correct position and then do the final alignment that way?
Also, the idler pulleys have some surface rust on them due to the fact that this engine was stored for some time with a broken/missing timing belt cover. The worst ones are the ones where the outside of the belt runs over. The toother one is not bad at all, just very light surface roughness. Is this sometihng I could sand smooth with some 400/600 sand paper and then polish? Or should I just buy new ones?
-Tony
tonyakavw is offline   Reply With Quote
Old 09-19-2005, 03:12 PM   #2
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Car in neutral.e-brake on. battery negative disconnected
pull the plugs.(easier to rotate motor and "feel" it)
Rotate the crank and align the timing mark(it's the single slash on the rear tooth, not the triangle)
Rotate the cam sprockets to align their timing marks.
I recommend using only oem subaru belts. They have install marks on them. and You can pretty much trust that they are correct.
Good luck.
Tim Sanderson is offline   Reply With Quote
Old 09-19-2005, 05:27 PM   #3
Hayes
Member#: 11808
The crank must have the timing mark up when #1 piston is at top dead center on the compression stroke and not the exhaust stroke. The idler pullies should be smooth or replace them. I think crocus cloth is the best way to try to polish them.
Hayes is offline   Reply With Quote
Old 09-19-2005, 06:04 PM   #4
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
That is incorrect sir. When the crank sprocket timing mark is aligned all four pistons are half way up the cylinders. The timing mark is not tdc anything.
Old 09-19-2005, 08:49 PM   #5
Texas25RS
Member#: 3148
2012 Mazdaspeed 3
Crystal White Pearl Mica
Cut the TB off... why does the soudn of that worry me... You shouldn't have need to do that...
Texas25RS is offline   Reply With Quote
Old 09-19-2005, 10:27 PM   #6
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
Ditto.
Here's scans for the 2.2 liter, but should be the same for the SOHC 2.5's
http://www.main.experiencetherave.co...ming_belt1.jpg
http://www.main.experiencetherave.co...ming_belt2.jpg
http://www.main.experiencetherave.co...ming_belt3.jpg
http://www.main.experiencetherave.co...ming_belt4.jpg
http://www.main.experiencetherave.co...ming_belt5.jpg
http://www.main.experiencetherave.co...ming_belt6.jpg
http://www.main.experiencetherave.co...ming_belt7.jpg
http://www.main.experiencetherave.co...ming_belt8.jpg
Legacy777 is offline   Reply With Quote
Old 09-19-2005, 10:39 PM   #7
Hayes
Member#: 11808
Tim is correct. I was thinking about a camshaft that turns at 1.2 crank speed. sorry. ed
Old 09-19-2005, 11:59 PM   #8
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
That's awesome legacy777! IF people decide to search they would find some good info there. Sometimes people get baffled with the old style tensioner.
Thanks for the links man.
Old 09-20-2005, 09:40 AM   #9
Legacy777
Member#: 4800
Welcome.
Old 09-21-2005, 11:12 PM   #10
John2.5RS
Member#: 1140
2000 S201 #78, '95 L
'13 F150 Ecoboost
Exclamation woah!
You don't want the pistons at TDC. they should be half way so you don't bang the valves with the pistons. Make sure you rotate the crank slowly by hand, then line up the cams after the crank. The Crank doesn't have a exhaust/compression stroke, that has to do with the cam position, the crank maintains the same rotaton, and doesn't care about the exhaust or compression strock, per say. The crank will rotate the same regardless of the camshafts' postion, but to make the engine run, you will have to line up the timing marks. The driver side pulley can be a pain to keep on it's mark sometimes, If I were you, If you have an adjustable rubber oil filter band wrench or something to keep the cam from rotating out of position, have a friend hold the camshaft sprocket while you put the belt on. I've done it myself several times but the first time was a PITA.
John2.5RS is offline   Reply With Quote
Old 09-21-2005, 11:13 PM   #11
John2.5RS
Member#: 1140
'13 F150 Ecoboost
Thumbs up A little FYI
I may be a little off right now, I just got off aof work a couple of hours ago and I had a couple jack n cokes.
Old 09-22-2005, 01:24 PM   #12
tonyakavw
Member#: 83536
Thanks for all the tips. I have the engine sitting on a furniture dolly currently, so access to the front of the motor is very good.
After reading the comments and looking at the factory service manual, I'm almost wondering if I even need to move anything at all. As long as I get the lines lined up on the crankshaft and cams, it seems like the timing will be on. And since the motor is out of the car, there is no problem with being able to see that things are lined up.
-Tony
Help! Timing Belt Install, stuck on the... you know, install RS-Flyboy Normally Aspirated Powertrain 11 07-09-2009 02:03 PM
Timing Belt Install Questions Bad Wagon Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 08-28-2006 05:52 PM
Timing belt install?? AK'S REX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 05-15-2004 01:18 PM
Timing belt installation for a PE belt? IA Performance Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 10-27-2003 04:45 PM
02 WRX timing belt install after crash cky211 Service & Maintenance 1 12-29-2002 12:25 AM
