Old 08-22-2001, 05:58 PM   #1
98legacygt117
Member#: 8386
1998 Legacy GT 2.5
Red
Default OT: some major problems
OK....so heres the deal. Im soaking some rays down here in Panama City right now but I have bigger problems on my mind right now. When I drive my car for more then an hour and going through gears.. my clutch sticks to the floor...and then when it kind pops up.....getting into another gear is a task... Ive considered slave and master cylinder...but am really not sure. MY biggest problem is money... I dont have any. IM just wondering if any oif you could give me a few pointers and tips... thanks..
Drew
98legacygt117 is offline   Reply With Quote
Old 08-22-2001, 06:50 PM   #2
Radio Flyer
Member#: 374
'98 2.5 GT Wagon
Rio Red
Exclamation
I have had that exact problem intermittently for years!!
I had it in to the shop for servicing (warranty), and the shop was about to replace pretty much the entire clutch assembly -- even the pedals. They ordered the parts, but then refused to do the work later on (long story). As I thought it would've been overkill, unnecessary, and possibly damaging anyway, I was fine with that...
A couple months ago, I was talking to the mechanic at Troncalli, and he said he knew what it was: the clutch fluid was boiling. The reservoir sits right over the exhaust header, and it winds up overheating the fluid. He thought that a different clutch fluid might cure it, but, he hadn't tested it out yet, nor had anyone wanting to do it.
The problem will appear when you're not doing much moving. Don't lope along. And, just accept it -- for now.
My planned cure is to open up the scoop to let more cool air in, and more hot out...
  - Eric
    '98 2.5 GT Wagon - Pics - Page -
    ICQ #: 9292601
Radio Flyer is offline   Reply With Quote
Old 08-22-2001, 06:52 PM   #3
nuburu2
Member#: 2609
98 BK-GT White
'97 SVX Ebony Pearl
Default clutch sticking
Drew, Funny but I had an experience for the first time last weekend where the clutch pedal wouldn't come all the way up, stopping about 3" down. Wondering if this is a precursor to your problem and wondering if anyone else has had or fixed such a problem.
And hey, try to enjoy that Panama City sun!! "Don't worry, Be Hoppy"!
Glenn O
nuburu2 is offline   Reply With Quote
Old 08-22-2001, 06:54 PM   #4
nuburu2
Member#: 2609
98 BK-GT White
'97 SVX Ebony Pearl
Eric, How about a heat shield for the reservoir?
Glenn O
Old 08-22-2001, 06:55 PM   #5
silverSurfer
Member#: 1361
1999 Legacy GT Ltd.
2006 Rav4 Sport Silvarrr
change the fluid to DOT4 or DOT5
silverSurfer is offline   Reply With Quote
Old 08-22-2001, 09:14 PM   #6
anotherB4
Member#: 6120
BE5B AVOed B4-RSK
Sorta White
Where's legacyB4 - he had that issue.
Must be because he drives so sloooww...
anotherB4 is offline   Reply With Quote
Old 08-22-2001, 10:54 PM   #7
tahrndt
Member#: 1315
That is a problem I can't relate to...I am still trying to find my Clutch pedal!
Tim
tahrndt is offline   Reply With Quote
Old 08-22-2001, 11:24 PM   #8
legacyb4
Member#: 4099
1999 Legacy B4 RSK
Violet-blue Mica
Had what sounds to be exactly the same problem intermittently for over a year and a half.
The condition was worst when the car was hot, the outside temperature was hotter, and you were sitting in stop and go traffic.
I had my clutch fluid upgraded from standard Subaru grade and despite doing this twice, I still had the problem. Luckily, I was still covered by warranty so this last month when it was really acting up, I dropped the car off at the dealer and they took a good, long look at it.
For me, it turned out to be as simple as replacing the clutch master cylinder and clean fluid. I was able to get by the rest of the summer without a single incident of loss of pedal feel or response.
Hope that helped.
Cheers.
legacyb4 is offline   Reply With Quote
Old 08-23-2001, 01:28 AM   #9
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Default Wierd
Hadnt heard of the boiling fluid idea. I would have to say it sounds like the clutch master cylinder. Theres a piston at the end of the brake pedal that forces the fluid into the clutch line. It has several o-rings which wear over time allowing the fluid to backup behind the piston causes loss of clutch pressure. It usually starts out by a loss of pressure then eventual total loss of pressure and clutch fluid leaking under the carpet in the interior. If you are totally losing pressure it is this or the slave cylinder. Slave cylinder is more obvious-just look at it. If its leaking its bad.
subysouth is offline   Reply With Quote
Old 08-23-2001, 08:48 AM   #10
Radio Flyer
Member#: 374
'98 2.5 GT Wagon
Rio Red
Post
<i>Nubaru</i> - Hmm. Hadn't thought about a heat shield... I'll look at doing that as well. Oh, and wrapping the line leading to the clutch as well. And, staying out of bumper-to-bumper traffic.
&nbsp;&nbsp;- Eric
&nbsp;&nbsp;&nbsp;&nbsp;'98 2.5 GT Wagon - Pics - Page -
&nbsp;&nbsp;&nbsp;&nbsp;ICQ #: 9292601
Old 08-23-2001, 01:18 PM   #11
GTkrockett
Member#: 8678
Silverish 2.5GT
i didn't know anyone else had this issue. it's been so long that i've forgotten about it. i had this problem the first day i drove the car off the lot. actually, i picked up my subie on a friday evening and heading up to the mountains for some boarding. halfway up the mountain...i was freaking out. my clutch apparently had given way and was stuck on the floor. there was absolutely zero pressure on the pedal.
needless to say, i was worried because i couldn't shift gears and i'm climbing up this single lane, mountain road with no shoulder to pull off to the side. (the shoulder would be the mountain side)
anyways, clutch response would come back, go away, come back, go away, and finally returned without any more issues. the following morning, i called my dealership, pissed off as hell, and they asked if i needed to get the car towed back. i said no cause it was working, but did drop it off as soon as i got back from the trip.
after the dealer examination, they found no issues (at least, that's what they told me) the problem has never resurfaced. to make a long story short, i never found out what the issue was, but, i couldn't entirely agree with the "boiling fluid" theory cause it was a real cold night when driving up the mountain.
GTkrockett is offline   Reply With Quote
Old 08-23-2001, 03:38 PM   #12
gumball
Member#: 1209
I've had itermittent difficulty shifting IN to a gear every now & then, but luckily the pedal hasn't stuck to the floor. Yikes, I wonder if the Imprezzas have the same issue? And hearing that a 3rd gen. Legacy (LegacyB4) had the problem isn't too comforting. jeez!
gumball is offline   Reply With Quote
Old 08-25-2001, 09:57 AM   #13
98legacygt117
Member#: 8386
1998 Legacy GT 2.5
Red
Default good info
Im glad im not the only one that has or has this problem. where do i look in the engine for the slave and master cylinder? What kind of tranny fluid should I be using. If I have to replace the master clutch cylinder, can i do it myself or is it very involved? I really need to get this fixed for it looks like I may be selling the scoob. I dont want to... I love Subarus...
Old 08-27-2001, 08:13 AM   #14
Radio Flyer
Member#: 374
'98 2.5 GT Wagon
Rio Red
The clutch fluid reservoir is on the firewall, pretty much directly in front of the driver's seat. You can follow the fluid line to the top of the tranny to see where it all is.
I'd expect that changing out the reservoirs/cylinders would be a major PIA for all but the certified mechanics (and, I suspect that even they'd be grumbling quite a bit).
Okay, I am indeed speaking from my sphincter here, and have no further opinions to provide. Someone is bound to know of different grades of hydraulic clutch fluids.
Good luck, and let us know of your results.
&nbsp;&nbsp;- Eric
<i>98LegacyGT</i>: Don't do it!! You must keep the GT!
Old 08-27-2001, 05:12 PM   #15
98legacygt117
Member#: 8386
1998 Legacy GT 2.5
Red
Default hmm
Id love to keep the car..But im planning on going back to school in Florida. After school, its a 2001 Legacy GT B4.........hehehehehe. Well ok maybe Im dreaming But I plan on florida State University. education or a sweet ass car. Tough decision
Ran into some MAJOR problems while installing UEL headers HELP ASAP! Un0RiGiNaL Normally Aspirated Powertrain 62 06-09-2009 12:45 PM
there is some major problem with my account! dejaybambi Vancouver Impreza Club Forum -- VIC 3 07-06-2008 10:54 PM
('93-'01) major problem/emergency with bushings install BSer Impreza Forum 9 07-04-2001 10:40 AM
major problems after alignment.. please help!! wistful Brakes, Steering & Suspension 4 06-25-2001 05:59 PM
Major problems in the General Forum subaruwrx General Forum Archive 1 12-06-2000 11:45 AM
