Welcome to the North American Subaru Impreza Owners Club Friday March 6, 2015
Old 09-19-2005, 04:34 PM   #1
fastwrx006
Member#: 38016
06 GG EVO IX
400 hp
Default Exhausts and EWG?
Couple of quick question...... do I have to get rid of my Helix downpipe when going EWG? Can I make my PDE uppipe work with a tail 38mm gate or do I have to get a new uppipe? What psi spring comes standard in a tail 38mm gate? I have boost control issues so should I go with a stiffer spring to be on the safe side?
fastwrx006 is offline   Reply With Quote
Old 09-19-2005, 04:38 PM   #2
bboy
Member#: 56468
04 Improved STI
Dirty White
As far as I know to put the dump tube into the DP is a custom job but one that can be done by many folks.
As for the spring the standard I'm told is a 1 bar spring. That considerably stronger that the stock ones that are around 7 psi. It's really hard to know what the best spring is. The cracking pressure of the spring relates to the exhaust pressure as well as the boost pressure that is acting on the actuator. What's too much is the question I have, and don't know the answer to.
Old 09-19-2005, 04:55 PM   #3
west005
Member#: 65684
1993 JDM Soarer TT
White on golds
If you want the Ultimate racing up-pipe with ewg built in you will need to check with them about which bellmouth DP fit. Otherwise you can have a WG flange welded on to about any up. You can call the vender or tial directly about your turbo application and which spring stiffness to use.
west005 is offline   Reply With Quote
Old 09-19-2005, 06:19 PM   #4
bboy
Member#: 56468
04 Improved STI
Dirty White
I'm going with the new Element Tuning EWG up-pipe and having the dump tube welding into my Perrin down pipe. I know that it does not work with the TurboXS bell mouth not sure about the Helix or PDE.
Old 09-19-2005, 07:01 PM   #5
powerleak
Member#: 72571
04 STI
you can check out my EWG when we meet up it was plumbed back into the downpipe like the guys are mentioning above.
powerleak is offline   Reply With Quote
Old 09-19-2005, 08:11 PM   #6
fastwrx006
Member#: 38016
06 GG EVO IX
400 hp
SZ60+EWG= I need a ride in that monster Which gate do you have? 44mm tail?
Old 09-19-2005, 08:19 PM   #7
03scubaru
Member#: 83557
PSM Now with 405 whp
You don't have to dump your external wastegate back into the dp. Mine just dumps straight down. Also the wastegate comes with whatever spring stiffness you want. The one that I am selling right now has a .6 bar spring in it. To answer your last question are you having boost control issues or boost creep issues. If it is boost creep then the external wastegate will eliminate it.
03scubaru is offline   Reply With Quote
Old 09-19-2005, 08:30 PM   #8
powerleak
Member#: 72571
04 STI
38mm is working just fine
Old 09-19-2005, 08:31 PM   #9
fastwrx006
Member#: 38016
06 GG EVO IX
400 hp
my boost is just odd, it makes 10psi and holds that until 5500rpm where it shoots to 25+psi. its very odd. I'm going to have it checked out soon and maybe add a tail 38mm gate if needed.
Old 09-19-2005, 09:43 PM   #10
03scubaru
Member#: 83557
What boost controller are you using?
Old 09-19-2005, 09:58 PM   #11
fastwrx006
Member#: 38016
06 GG EVO IX
400 hp
Turbosmart E-boost ebc
Old 09-19-2005, 10:07 PM   #12
Project Rex STi
Member#: 77249
04 STi
I just finished fabbing my EWG setup w/ dump tube. Mines probably a lot different than most. I'm happy with it. BTW, these are the rough pictures, it's alot cleaner now and coated.
Project Rex STi is offline   Reply With Quote
Old 09-19-2005, 10:39 PM   #13
DaHellWidU
Member#: 67496
2011 Legacy GT
oh man that is pretty.
i wonder what min is goina look like
DaHellWidU is offline   Reply With Quote
Old 09-20-2005, 04:30 AM   #14
AQ Motorsports
Member#: 60836
2006 Mod Class STI
TIMEATTACK!!
Is that a Perrin downpipe? Damn man - that's good thinking. I've been staring at one in the shop for a while... I was trying to think of a way to use that divorced wastegate pipe for that. Beat me to it.
AQ Motorsports is offline   Reply With Quote
Old 09-20-2005, 07:50 AM   #15
Project Rex STi
Member#: 77249
04 STi
It is the Perrin DP, but i couldn't reuse the actual tube you are speaking of. I actually cut the wastegate tube off and used the hole it used. But yea, i sat there and looked at it for a while too.....finally figured out what i wanted to do.
FS: Green style turbo/APS exhaust with EWG plumbed back in/injectors/AVC-R and more davidm_sh Engine/Power/Exhaust 4 03-12-2009 12:36 AM
FS:Deadbolt SZ55 Turbo, GrimmSpeed ewg uppipe, tanabe exhaust and more VIIImylunch Engine/Power/Exhaust 36 08-19-2008 12:43 PM
07 wrx TMIC, exhaust, and turbosmart ultragate EWG mhspyder97 Engine/Power/Exhaust 12 04-18-2008 11:36 PM
Restrictive exhaust with EWG "semi ok"? RossWRX Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 12-17-2005 06:49 PM
will stock exhaust with EWG setup one wicked wrx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 03-22-2005 12:37 AM
