Welcome to the North American Subaru Impreza Owners Club Wednesday September 2, 2015
Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 09-19-2005, 03:55 PM   #1
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
Default Hydra auxiliary map switch setup
My Hydra is off to Phil today to get modded and flashed for AVCS, then I'll be ready to start tuning or rather asking a lot of questions. First batch:
Does anyone know how to set launch control/flat shifting up? I assume I could use the same clutch switch connectors as I had with the UTEC, but I am an idiot at wiring and I need a drawing a kid could read.
I would also like to wire a switch to toggle back and forth from pump gas to a race gas fuel and timing map. I would buy something like this if it was available.
Have you guys seen the wideband display for the Hydra? It was only like $50 US, but I could only find it on an Australian site.
That's all for now, THanks.
rjrutzky is offline   Reply With Quote
Old 09-19-2005, 05:41 PM   #2
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
The harness that Phil provides hooks into the same clutch switch as the Utec one. If Phil is uploading a new map to the Hydra it will likely have everything setup for the launch control (and flat shifting) already. Just a couple of RPM settings you can play with. Haven't seen the wideband display.
Old 09-19-2005, 05:44 PM   #3
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
Theres a wideband display?
Old 09-19-2005, 05:54 PM   #4
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
It's been in the works... I was unaware anything official was released...
jblaine is offline   Reply With Quote
Old 09-19-2005, 06:42 PM   #5
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
I found the WB on an aussie site, but can't find it again. it said $50 u.s. and looked like a txs tuner. woot!
Old 09-19-2005, 07:14 PM   #6
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
We do have a Element Hydra EMS Accessory Wiring Harness that allows you to run water injection, Anti-lag (launch type), Launch control, flat-foot shifting, and the ability to use a switch to enable the standard maps and the AUX Maps (this will be automatic with the integrated water injection system). This retails for $59 but we're almost sold out again.
If you have no need for Anti-lag you can actually use the Anti-lag maps as an optional map also.
There currently is no WB display available in the US but a Hydra specific display is in the works. This will allow you to view any two of your data logged items such as AFR and RPM, Boost and IDC, etc. I don't think this will be available until around SEMA which is November.
Thanks,
Phil
www.elementtuning.com
Element Tuning is offline   Reply With Quote
Old 09-19-2005, 08:19 PM   #7
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
Thanks,
Phil
pm sent Phil
Old 09-20-2005, 09:08 PM   #8
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
found the pic of the wb02
http://www.mdac.com.au/
Old 09-21-2005, 03:09 PM   #9
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Phil, short of the website, is there some channel I am unaware of where I can find out about these sorts of things before someone happens to ask a related question?
Old 09-21-2005, 03:29 PM   #10
Element Tuning
Member#: 54918
673 WHP Element
The truth of the matter is that I haven't been marketing these items just yet. I've just been selling them to those in the "know" for now until we can fully stock them as I don't like to market products that I don't have in inventory.
The fully integrated water injection system is still being tested and originally the Accessory Harness was born out of this.
The display is still a couple months away but will hopefully be released for SEMA.
When we're ready for a full release it will be in the "News" or "Homepage" of www.elementtuning.com but for now Nasioc is best place to hear about upcoming products.
Thanks,
Phil
Old 09-21-2005, 06:34 PM   #11
MZM
Member#: 514
07 Legacy Spec B
Impreza 93 STI
Phil;
Look for a PM
Mike McBride
MZM is offline   Reply With Quote
Old 12-01-2007, 03:02 PM   #12
extrememedia
Member#: 160756
If you have the auxillary map switch on and have autotune on will the autotune start modifying the Auxillary fuel map to match the AFR table?
extrememedia is offline   Reply With Quote
Old 12-01-2007, 03:22 PM   #13
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Great question. I wondered this a few months ago myself and forgot to ask.
Old 12-03-2007, 10:26 AM   #14
Element Tuning
Member#: 54918
673 WHP Element
No it will modify the main fuel map, not AUX map. Make sure to Autotune the main fuel map first and then adjusting the AUX fuel map is quick and simple to do manually.
Thanks,
Phil
Old 01-05-2008, 05:57 PM   #15
Chino1
Member#: 128985
2002 bugeye STi-ish
MBP
how can i buy the wb02 display???
Chino1 is offline   Reply With Quote
Old 01-06-2008, 09:59 AM   #16
sean18337
Member#: 135588
2007 STI *SOLD*
I'm interested in the wb display as well! Let us know if this works out!
sean18337 is offline   Reply With Quote
Old 01-14-2008, 03:14 AM   #17
spoolinsti05
Member#: 108051
2005 TickingTimeBomb
Jr tuned TT Sleeved
talk about bringing a thread back from the dead lol. Well as long as where here I'd like to know how to hook up the anti lag and stuff. So far I herd the Aux Map needs to be grounded witch I guess I can do with a switch I'm lost with wiring like this. unless I have a Diagram to go from. For 1500 dollars you'd figure we would get this with the system.
My plains are to run the Anti Lag on the Race fuel map only. and To run the LC and FF shifting on both pump/meth and race gas maps. Can someone help me out on this if so please PM me I'd like to have this set up by the next month or so ready to have tuned.
spoolinsti05 is offline   Reply With Quote
04-06 sti Utec w/ map switch, gm 3 bar map sensor for speed density & tatrix cable methaddict Engine/Power/Exhaust 26 07-12-2008 12:47 AM
FS (NY): TurboXS UTEC Delta v03 + TXS 4BAR MAP Sensor + Remote Map Switch bbong Engine/Power/Exhaust 5 04-08-2008 05:46 PM
STI UTEC with TXS map sensor and map switch bgod Engine/Power/Exhaust 3 09-06-2007 10:22 PM
Can I use an LED switch for XEDE map switch? djoye Electrical & Lighting 0 09-02-2005 04:30 PM
Hydra Users: Anyone know the Hydra injector mapping? wgknestrick Other Engine Management 12 03-07-2005 04:12 PM
