Old 09-19-2005, 07:59 PM   #1
HD-sw20
Gone But Not Forgotten
Member#: 37056
Default Accessport Boost Controller Question
I know the Stock Map Sensor is good for approx 24PSI. How good is the AP boostcontroller function? Can it support 30PSI? I'm trying to find out if i need to ditch my Blitz-SBCID. Where can we get a 3-4 Bar map sensor that is plug and play?
TIA
HD-sw20 is offline   Reply With Quote
Old 09-20-2005, 09:13 AM   #2
WolfPlayer
Member#: 65054
2005 STI (CGM)
Descooped / Dewinged
The AccessPORT isn't a boost controller. It is an ECU reprogramming device. The ECU is the boost controller and it pulses the stock Denso 'bleed type' solenoid to work with the new parameters that the AccessPORT uploads to the ECU (target boost and WGDCs changed with regard to boost controlling).
t
WolfPlayer is offline   Reply With Quote
Old 09-20-2005, 09:59 AM   #3
happasaiyan
Member#: 37731
TIA
chee, it can support it, but it would be doing it blind at that point. to have stable, predictable boost control up to 30psi, youre going to need an upgraded MAP sensor.
are you getting an accessport and ditching the utec? either way, i would just keep the sbc-id. it will work fine as long as jorge knows the boost you will run.
happasaiyan is offline   Reply With Quote
Old 09-20-2005, 10:04 AM   #4
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
Jason's right, Chee. Cobb is finishing up the MAP calibration functions of the Protuner which will allow a larger MAP sensor, but in the mean time just keep using the SBC-ID.
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 09-21-2005, 09:20 PM   #5
HD-sw20
Member#: 37056
Jorge (RiftsWRX)
www.ProjectWRX.com
Thanks Guys I have a accessport in the garage... The new shortblock is going in this weekend and hopefully i get my breakin done early Oct and then Time for Tunning........ Guess i'll keep the Sbc ID for now.
Stock Boost and Boost controller question benibarra23 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 06-15-2010 09:13 PM
accessport boost gauge question rotaman AccessPort 10 07-20-2006 02:39 AM
boost gauge/boost controller question scoobaru_wagon Newbies & FAQs 9 04-30-2005 09:37 PM
manual boost controler question bttune2.5rs Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 05-30-2001 06:26 AM
More boost controller questions.... Obscure411 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 34 05-15-2001 10:15 AM
