Old 09-19-2005, 11:11 PM   #1
azn2yunr
Member#: 67229
9295 BC/gm6
winestone/funky blue
Default when did obd2 come out? and other misc q's
when did it? ive heard it was 96 but i want to be sure.
also what motor came in a 95L with awd and the side feed injectors soch heads that look strangely similar to the legacy turbo heads. was it 1.8 or 2.2
on a cable clutch is it east to adjust the tension on the cable (shot in the dark here) the clutch is a little late on ingauging. doesnt slip just need to let the clutch out alot before it connects.
azn2yunr is offline   Reply With Quote
Old 09-19-2005, 11:18 PM   #2
norexyet
Member#: 39149
11 elantra
yea i said elantra
OBD 2 came out in 95/96, some cars have bits from obd1 and bits from obd2 from those years so that kind of sucks.
norexyet is offline   Reply With Quote
Old 09-19-2005, 11:30 PM   #3
azn2yunr
Member#: 67229
9295 BC/gm6
how can you tell which one you got
Old 09-20-2005, 12:09 AM   #4
norexyet
Member#: 39149
11 elantra
yea i said elantra
Not sure, ask the buyer, i found out when i hooked up a scan tool to a z28 camaro and only some ob2 functions worked.
Old 09-20-2005, 01:23 AM   #5
vrg3
Member#: 25796
1993 Legacy Turbo
Burgundy
Look for the 16-pin OBD-II diagnostic connector. OBD-I Subarus don't have 'em.
vrg3 is offline   Reply With Quote
Old 09-20-2005, 02:49 PM   #6
azn2yunr
Member#: 67229
9295 BC/gm6
ill have to check for that.
anyone else have imput on the other things
Old 09-20-2005, 02:55 PM   #7
bl_easy
Member#: 91407
Ver. 2 WRX STi wagon
BRetty green
I believe that OBD-II compatibility was required for all '96 models and afterwards. So, could have come out in '95.
bl_easy is offline   Reply With Quote
Old 09-20-2005, 02:58 PM   #8
vrg3
Member#: 25796
1993 Legacy Turbo
Burgundy
According to this page:
http://www.cars101.com/impreza_archive93_96.html
All stickshift 95 Impreza Ls had the EJ18. It has side-feed injectors (I think they're the same form factor as 92-94 NA Legacy injectors) and the heads should have a construction similar to that of EJ22T heads.
Old 09-20-2005, 03:21 PM   #9
azn2yunr
Member#: 67229
9295 BC/gm6
V- they are the same as the na legacys, they fit 550's form usdm sti's too. thats too bad thats its a 1.8. thing has no balls at all.
edit, it looks like i got a cross between an lx and an l . i have abs and 4 wheel discs but i have black molding and handles as well as a manual antenna
Uh... when did Vector come back and make a 270mph production car? Hites Off-Topic 55 10-14-2008 01:18 PM
When did sportshift come in? Mohawk Newbies & FAQs 2 01-22-2007 06:38 PM
how do i find out when something is coming out on video? alacrity024 Off-Topic 4 01-08-2005 12:32 PM
HKS Super-AFR and other fuel Q's Ethan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 07-09-2001 10:30 AM
