Old 09-21-2005, 10:28 AM   #1
Jericho99
Member#: 96525
Default idle low when AC is off
Hi everyone,
Just bought a 2000 2.5rs manual and noticed that the engine idles around 400 when AC is off but when it is on it looks to idle correctly at around 700-750. Is this a major problem? I would think that this would be the opposite, reset the ECU a possible solution? Any feedback would be great.
Thanks.
Jericho99 is offline   Reply With Quote
Old 09-21-2005, 10:46 AM   #2
Calamity Jesus
Member#: 44501
1984 That's *Sir*
Weinerlicks of Douche 2u.
Yeah, reset the ECU.. and check for any possible vacuum leaks. Then start the car and watch as the idle sets itself.
Old 09-21-2005, 02:45 PM   #3
newbiescooby2.5rs
Member#: 93758
i have the same issue except mine is a 01 2.5rs AT. There are no mods on it, just stock. It hovers at 400rpm then stays around 500rpm when its cold out. AC isn't on though...is low rpm bad? Also, wouldn't ur ecu learn after a few weeks where it should be at? i was thinking 700-750rpm is normal.
oh i just changed my o2 sensor and it stopped surging and hesitating, would this cause the low rpm mentioned in jericho999's post?
newbiescooby2.5rs is offline   Reply With Quote
Old 09-21-2005, 02:55 PM   #4
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
AC runs on vacuum.
of course the idle will change when the AC is on
Subie Gal is offline   Reply With Quote
Old 09-21-2005, 03:12 PM   #5
svek
Member#: 82259
1999 impreza 2.2L
Brilliant Red <4EAT Club>
doesnt the tach start at 500 rpm?
and if you watch my temp gauge, when you turn the ac compressor on the temp goes up
svek is offline   Reply With Quote
Old 09-21-2005, 06:13 PM   #6
jasona
Member#: 11786
2014 OB 2.5i 6MT
Custom Dirt/Snow twotone
Never heard of anyone complain their idle is too low...
jasona is offline   Reply With Quote
Old 09-22-2005, 01:26 AM   #7
Aphex28
Member#: 11506
2015 WRX
You can't be idling at 400 RPM... the last ticks aren't to scale really.. the Tach starts at 500 RPM...
Aphex28 is offline   Reply With Quote
Old 09-22-2005, 10:09 AM   #8
Jericho99
Member#: 96525
It idles around the middle of 0 - 1 on the tach or just below, so that would be normal? I thought it would be more of about one tick below the 1?
Old 09-22-2005, 10:27 AM   #9
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The line below the "1" is actually 750 but many people mistake that mark for 500. If your idle speed were really that low the ECU would set a trouble code and turn on the CEL.
Car overheats at idle when AC is on--HELP! wjc04wrx Service & Maintenance 5 05-06-2007 08:48 PM
Coolant low when I take off radiator cap after hard driving cky211 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 04-02-2004 01:50 PM
Engine not liking when AC is on JF1GD2 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 02-03-2004 10:09 AM
getting a misfire when ac is on at idle? mrtrex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-26-2002 08:22 AM
Deck not turning off when car is off Sparticus Car Audio, Video & Security 18 02-15-2002 01:53 AM
