Old 09-21-2005, 12:50 PM   #1
jester409
Member#: 64376
04 WRX
Default How much HP out of a 1.8L?
I am not particularly power hungry, but wouldn't mind adding an extra 20 or so horsepower to the 1.8L. Can anyone recommend a good path to get there? Possibly a set of heads off of another subaru motor and new cams? Is this even possible, or should I just read up on a 2.5 swap?
jester409 is offline   Reply With Quote
Old 09-21-2005, 01:24 PM   #2
EcksJay
Member#: 77677
1997 OBS
'07 KLR 650
2.5 swap is by far a much better route, for the money.
EcksJay is offline   Reply With Quote
Old 09-21-2005, 01:29 PM   #3
99subi
Member#: 78118
2002 Corvette coupe
05 Legacy
wow im dumb
99subi is offline   Reply With Quote
Old 09-21-2005, 01:35 PM   #4
Nicklbrso
Member#: 44887
00 GC6
what he said
Nicklbrso is offline   Reply With Quote
Old 09-21-2005, 02:07 PM   #5
jester409
Member#: 64376
04 WRX
That's what I was thinking...
2.5 it will be...
Old 09-21-2005, 03:06 PM   #6
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
I've got one, complete with ECU...
Old 09-21-2005, 03:35 PM   #7
chip4761
Member#: 55867
2005 Saabaru
AS
Matt - Oh yeah? How much $$?
jester - If you want 20HP, get an ej22. However, only if you can get it for free, or very very cheap. Mine was free. It was worth a saturday.
chip4761 is offline   Reply With Quote
Old 09-21-2005, 05:09 PM   #8
jester409
Member#: 64376
04 WRX
Agreed... I think a 2.2 would probably have enough power for me, and if I could get a dirt cheap one, I would think about going in that direction. Otherwise, I'd swap in 50hp before I would 20hp.
Old 09-21-2005, 05:41 PM   #9
Matt Monson
Member#: 832
99 2.5RS, '85 911
Chip,
PM me if you are interested.
You guys should look up the high compression frankenstein thread. Use Ej22 heads on an Ej25 bottom end on your stock ECU and wiring. Don't even mess with putting Ej18 heads onto any other block. I should have a couple of rebuilt Ej25 bottom ends available sometime next month...
Old 09-21-2005, 10:36 PM   #10
93subi
Member#: 81255
98 05 LGT, silver
98 Trans AM, Red
I found that putting a new motor in my car would be a pain since the 1.8 wireing harness goes thru a different spot in my cars fire wall then the 2.5 or 2.2 wireing harness does so instead of chopping stuff up I just put a 2.2 short block from a 1991 legacy in and slapped my 1.8 heads back on, gave me a lot of HP, more than I thought it would and the CR is up higher now, also the engine seems to be much more resposive
93subi is offline   Reply With Quote
Old 09-22-2005, 06:49 AM   #11
EcksJay
Member#: 77677
1997 OBS
'07 KLR 650
Ummm...no. The mounts for the wiring harnesses are in the same spot. But anyway, if you are swapping a 2.5 into a 1.8, you will most likely end up using the 1.8 engine harness and vacuum harness. No cutting and stuff that way.
Old 09-22-2005, 08:57 AM   #12
chip4761
Member#: 55867
2005 Saabaru
AS
ummm, no. The wiring harness from the intake manifold on a two port ej22 is on the drivers side. It is on the passengers side on an ej18. That's why you keep your intake manifold for that swap.
Old 09-22-2005, 11:47 AM   #13
Lethargic1
Member#: 20998
The Ej22 is a nice engine with some decent power; however, like all things, you will get used to it and then want more power. I say, go for the better engine swap NOW while you're going to do it anyway and get the Ej25. Trust me, I can already see a swap coming my way sometime down the road. This is also why I'm reluctant to put money into modding my engine.
Lethargic1 is offline   Reply With Quote
Old 09-22-2005, 12:56 PM   #14
Matt Monson
Member#: 832
99 2.5RS, '85 911
An Ej22 block under Ej18 heads can't be giving you more than 15 or 20 extra horses, for a lot of work. I concur with the guys saying go straight to an Ej25. And you can get a set of Delta cams for $165 and install them before you even drop the engine.
And I am sorry guys. I have gotten a couple of PM's about my Ej25. It is no longer available. I am putting it into my RS while I do some more work to my other engine...
Old 09-23-2005, 11:08 PM   #15
EcksJay
Member#: 77677
1997 OBS
'07 KLR 650
Originally Posted by Matt Monson
....I concur with the guys saying go straight to an Ej25. And you can get a set of Delta cams for $165 and install them before you even drop the engine.
I got the Delta cams in my car, and it dyno's 150 HP and 158 TQ....AT THE WHEEL!!!
$500 for the motor, $165 for the cams, 2 days of work, and that's about it!
Old 09-24-2005, 12:32 AM   #16
Lethargic1
Member#: 20998
You send the cams out to Delta and they regrind them, or do you just buy new cams?
Old 09-24-2005, 01:29 AM   #17
93subi
Member#: 81255
98 05 LGT, silver
98 Trans AM, Red
are u getting 150 hp to the wheels on a AWD L or a FWD L ?
Old 09-24-2005, 08:09 AM   #18
EcksJay
Member#: 77677
1997 OBS
'07 KLR 650
You take the cams out of the 2.5, send them to Delta, they regrind them, ship 'em back the next day. Between shipping and work, you're looking at about a week total.
150hp AWD
Old 09-24-2005, 09:23 AM   #19
Lethargic1
Member#: 20998
150hp AWD
Hmm...I wonder how much I would get out of my ej22 cams. I must do more searching.
Old 09-24-2005, 11:45 AM   #20
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Are you sure about this? I was looking for dyno information and could've sworn you said this was crank hp.
Ahh, here it is.
In reference to this dyno plot:
http://we-todd-did-racing.com/wetodd...EzZGZkMzF5NTQx
This thread: http://forums.nasioc.com/forums/show...highlight=dyno
Someone asked this question about your dyno plot--->
Originally Posted by supermoose
what kinda dyno was that. its showing crank Hp right?
You responded--->
I believe that it was a DynoJet. And yes, that is crank hp....
Either way, your torque band is excellent and anyone would love to have that.
Kevin Thomas is offline   Reply With Quote
Old 09-24-2005, 07:45 PM   #21
93subi
Member#: 81255
98 05 LGT, silver
98 Trans AM, Red
think its time for me to get a 2.5 swap and some cams, that would be crazy power to a front wheel scooby
Old 09-24-2005, 10:36 PM   #22
EcksJay
Member#: 77677
1997 OBS
'07 KLR 650
yes. I "thought" it was CHP. I was kinda dismayed to see those numbers, when I left, I failed to confirm if it was CHP or WHP. I went back a few days later, and they said that they really don't have a way to measure CHP. So yes, it is WHP
other post edited for clarity
Old 09-25-2005, 12:02 AM   #23
redwagon
Member#: 2181
2008 SpecB
Wow, you met an honest dyno operator. So few and far between.
<-- so sick of bs calculated/compensated/estimated chp numbers...
As to the OP's question, I'd either go straight to an EJ25 swap or DIY turbo. The little EJ18 makes so little power as it is, the few percent here and there from boltons just doesn't add up to enough to be worth the money. You spend the same amount of cash modding the engine as you do for a complete swap, but still end up with less power and driveability. Remember that the beauty of the EJ25 is not it's peak hp figure (which is still modest) but the low rpm torque. You can find good EJ25s from people who are swapping EJ20* engines for not much money. Easy swap. If you cash left over, get the cams at the same time as others here have suggested. Get some EL headers and maybe some engine management and you're well on your way to 200hp.
Go check out the AFI forum and search for EJ18 + turbo. Quite a few guys there have gone this route, Subachad is one that's had great success and has parts which you'll need. It seems you can get 200hp from 5psi or so and still have a reliable car. It's a bit more work than an EJ25 swap but if you like tinkering and having a unique car, that could be the way to go. If you're patient and pick up your parts at the right price you can put the whole thing together for not much more than a swap.
(sorry y'all, to be blaspheming in the NA forum )
<-- too lazy/impatient to go the turbo route, swapped instead. Worth every penny.
redwagon is offline   Reply With Quote
Old 09-25-2005, 01:59 AM   #24
Hawk296
Member#: 14555
1995 Impreza L
Baja
EJ25=FUN!
Hawk296 is offline   Reply With Quote
Old 09-25-2005, 07:03 AM   #25
EcksJay
Member#: 77677
1997 OBS
'07 KLR 650
I agree with redwagon. If I had the time and money, I would have rather had gone turbo, but at 136k, I thought it a bit risky.
How much power out of the stock 2.0? TBebault Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 07-15-2009 03:02 PM
how much hp out of a ea82T Flat4-SLO 'Old School' Subaru Forum 34 11-14-2008 12:39 PM
How much power out of a stock block? fatrounds Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 09-17-2007 06:59 PM
How much power out of a stg4 axis ej22t? SLO_02WRX Built Motor Discussion 1 02-06-2007 06:46 PM
how much hp off of alky injection cusco02 Newbies & FAQs 5 10-02-2006 12:05 AM
