Old 09-21-2005, 01:22 PM   #1
Larsony
Member#: 35273
2005 Saab 9-2x Aero
Stage 2
Default 3 inch downpipe with 2.5 inch catback?
I know this probably isn't the ideal setup, but can it be done? Yes, I have read the Unibomber's exhaust FAQ's.
I am planning on running Cobb stage 2.
Thanks in advance for responses, and please keep the "Search N00B" to a minimum.
Larsony is offline   Reply With Quote
Old 09-21-2005, 02:45 PM   #2
specialev
Member#: 90156
1986 Syncro Vanaru
07 SV650
Yup, I am doing it right now. With the ERZ DP and a factory catback, on Stage 2 maps, my car is more powerful than ever. However, three inch pipe will certainly only improve things for either you or me.
specialev is offline   Reply With Quote
Old 09-21-2005, 02:48 PM   #3
Larsony
Member#: 35273
2005 Saab 9-2x Aero
Stage 2
So did you have to use a special kind of adapter for the setup, or weld together, etc.?
Old 09-21-2005, 02:55 PM   #4
isis
Member#: 73283
05 CTS-V
03 Z1000
Cobb says that the factory catback will be fine with an aftermarket downpipe. If the downpipe says it will mate to any aftermarket catback (many of them taper in at the end so you can use the donut gasket) and the catback says it will mate to the factory downpipe, then you shouldn't need an adapter.
isis is offline   Reply With Quote
Old 09-21-2005, 02:56 PM   #5
AdmiralWRX
Member#: 80204
2005 WRX++
It's going to depend on the type of downpipe you get. I know that the MadDad downpipe (which I have) has the option of two different types of exit flanges: a factory style donut gasket exit flange (for mating up with your factory catback) or a 3 inch crush gasket flange (for mating up with a 3 inch aftermarket catback).
I'm not sure if that means you have to purchase a new 3rd cat eliminator pipe section (with a new exit flange type) when you decide to change your catback. I'm pretty sure it does.
At least it give you a little flexibility while saving up for a new catback.
AdmiralWRX is offline   Reply With Quote
Old 09-21-2005, 03:00 PM   #6
specialev
Member#: 90156
1986 Syncro Vanaru
07 SV650
The ERZ is designed for a flat gasket-type flange interface, the OEM uses a donut. I was able to seal the two dissimilar parts together by simply maneuvering the donut betwixt the two and tightening the crap out of it. I am sure I ruined the donut, but I am not worried about it; my new CBE is in the mail by now, hopefully.
Old 09-21-2005, 03:26 PM   #7
Larsony
Member#: 35273
2005 Saab 9-2x Aero
Stage 2
So no problems with leaking then?
Old 09-21-2005, 09:54 PM   #8
BoostinEJ20
Member#: 73710
what are u planning on getting or do u have that is 2.5"? why not just buy full 3"?
BoostinEJ20 is offline   Reply With Quote
Old 09-21-2005, 10:15 PM   #9
specialev
Member#: 90156
1986 Syncro Vanaru
07 SV650
I had problems when I initially fitted it, but that leak lasted all of five minutes. I removed the fasteners and reversed the donut seal so it fit into the ERZ better, then applied suitable amounts of torque so as to make it seal. It only took one try, and the leak was eliminated.
Old 09-21-2005, 10:24 PM   #10
Larsony
Member#: 35273
2005 Saab 9-2x Aero
Stage 2
Because I may first want to put on a downpipe, flash to stage 2, then put on a catback when the funds allow.
Old 09-22-2005, 01:47 AM   #11
electricpork
Member#: 9498
03 Bugeye
Junkyards are fun!
<--- 3" Stromung DWG DP, Daddys 3CE taper pipe, 2.5" cat back. Keeps original donut gasket. Works great.
electricpork is offline   Reply With Quote
Old 09-22-2005, 10:57 AM   #12
Larsony
Member#: 35273
2005 Saab 9-2x Aero
Stage 2
Nice!! Thanks for the info
Old 09-22-2005, 01:38 PM   #13
kx02wr
Member#: 59112
02 wrx
this is what i want as well. Power without attracting everyone's attention especially PoPo. I'm goin either stromung or sti 2.5 out the back.
kx02wr is offline   Reply With Quote
Old 09-22-2005, 08:07 PM   #14
WRX03
Member#: 20744
05 Baja Regal Blue
03 WRX Little Red Wagon
FYI: The donut gasket is pretty $$ from the dealer. I replaced a leaking one recently.
WRX03 is offline   Reply With Quote
Catted Downpipes with 2.5 hookup to stock. _FOoM Newbies & FAQs 2 07-06-2009 08:57 PM
FS: Custom 2.5 inch catback (Magnaflow muffler) highrevracer951 SCIC Private Classifieds 12 10-13-2007 10:52 PM
2.25 Inch exhaust vs 2.5 inch exhaust kghost Normally Aspirated Powertrain 3 02-27-2007 04:51 PM
Accessport with 2,5 inch exhaust tech Engine Management & Tuning 12 02-03-2006 04:42 PM
3 inch downpipe into 2.5 inch exhaust? krillz Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 03-04-2003 09:50 AM
