Old 09-21-2005, 01:35 PM   #1
chadr111
Member#: 37718
02 TS, (too Slow)
black
Default just passed obd check with no cat
My set up:Brullen header with gutted cat, 2.5 in midpipe, and a wrx rear section. The check engine light is always on.
I've been puting off getting the car tested because I was pretty sure it would fail. But in TN they don't sniff test 96' and newer cars, and you get one free retest if you fail. So I thought I would try it.
I reset the ecu, put 80 miles on the car and took it in. Not 5 miles after leaving with my "Certificate of Compliance" the check engine light came on. Man am I happy I don't have to swap the stock stuff back on.
Chad
chadr111 is offline   Reply With Quote
STi with no cats, and NO BOOST CREEP V6TurboTA Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 61 08-23-2009 08:10 PM
can I pass emissions with no cats??? IllNastyImpreza Normally Aspirated with bolt-on Forced Induction Powertrain 20 05-13-2007 01:09 AM
Running with no cat - pass emissions with Engine Mgmt? BritSti Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 01-28-2004 09:11 PM
Pass smog check with these mods?? SoBaLo Southern California Impreza Club Forum -- SCIC 9 02-18-2002 12:53 PM
