Old 09-21-2005, 07:48 PM   #1
tonzo
Member#: 94903
1996 Impreza Wagon!
Satin Black
Subaru Stars boring out a 2.2
how far can u bore out a ej22? I was thinking about putting in some wider pistons but wasn't sure how wide i could go.
tonzo is offline   Reply With Quote
Old 09-21-2005, 07:51 PM   #2
Whiteghost 2.5
Member#: 72994
2001 Racekor
Emerald Green
is this a closed deck block or 2.2 na?
Josh
Whiteghost 2.5 is offline   Reply With Quote
Old 09-21-2005, 07:53 PM   #3
99subi
Member#: 78118
2002 Corvette coupe
05 Legacy
2.2 na guessing form his profile
99subi is offline   Reply With Quote
Old 09-21-2005, 09:50 PM   #4
JoshP
Member#: 94350
20 over, throw in a 2.5crank while you're at it
JoshP is offline   Reply With Quote
Old 09-21-2005, 09:54 PM   #5
svek
Member#: 82259
1999 impreza 2.2L
Brilliant Red <4EAT Club>
theres no replacement for displacement
but this seriously wont do much of anything for you.
svek is offline   Reply With Quote
Old 09-21-2005, 09:57 PM   #6
tonzo
Member#: 94903
1996 Impreza Wagon!
Satin Black
Subaru Stars
you're saying that if i bore them out i won't gain much?
Old 09-21-2005, 10:00 PM   #7
svek
Member#: 82259
1999 impreza 2.2L
think of it like this: the ej25 is 165 hp, the ej22 is 142 or 137(depends on which version). so 300 cc (actually like 250 but whatever) difference, thats a lot of boring out it would significantly reduce the sidewall thickness making it weaker. the ej25 is also 10:1 compression ratio where the ej22 is 9.7:1 giving the rs more power.
Old 09-21-2005, 10:34 PM   #8
tonzo
Member#: 94903
1996 Impreza Wagon!
Satin Black
Subaru Stars
true, the only reason i bring this is up is that I'm having a problem finding pistons for my engine. I'm planning on turboing it but before i can even think about that I have to rebuild my engine.
Old 09-21-2005, 10:39 PM   #9
svek
Member#: 82259
1999 impreza 2.2L
take a look here: http://forums.nasioc.com/forums/showthread.php?t=849236
ej22t/e hybrid, the 22t pistons should be decently strong, and that motor can hold boost like a wildebeast
Old 09-22-2005, 12:22 AM   #10
tonzo
Member#: 94903
1996 Impreza Wagon!
Satin Black
Subaru Stars
thanks for the help. still can't find a place that sells them but i guess ill just keep looking. id rather get new pistons if possible rather than used
Old 09-22-2005, 12:36 AM   #11
svek
Member#: 82259
1999 impreza 2.2L
Old 09-22-2005, 11:48 AM   #12
Lethargic1
Member#: 20998
Svek, how do I find out if I have either the 142 or 137 ej22?
Lethargic1 is offline   Reply With Quote
Old 09-22-2005, 12:23 PM   #13
GuyLR
Member#: 21811
2003 WRX Wag/01 OBS
WRB and SM
Your '97 is a Phase I engine so it's 137hp.
Go here for more info> http://www.cars101.com/impreza_archive97_98.html
GuyLR is offline   Reply With Quote
Old 09-22-2005, 12:27 PM   #14
Lethargic1
Member#: 20998
Thanks a bunch.
Old 09-22-2005, 12:31 PM   #15
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Crawford Performance sells new takeout Ej22T pistons from the engines they are building. They are pretty cheap, like $100 or $150 a set. What matters most is not displacement, it is about compression ratio. Using Ej22T pistons in an Ej22E will get you there.
Or we built an Ej20G with Ej22 heads and it was a fun little car. 10psi on a vf-11, non-intercooled, run with an E-manage. Closed deck, under piston oil squirters, and the ability to rev to 7500rpm. It gives you 9:1 CR, which is still fairly boost friendly. We figure it is good for around 200-210 like that. If you intercooled it, you could put 12-15psi through it and seem more like mid to high 200's. I have one of these blocks available if you are interested.
Also, one of our members, Snowjob, has a used Ej22T block on E-Bay right now...
Old 09-22-2005, 02:33 PM   #16
GuyLR
Member#: 21811
2003 WRX Wag/01 OBS
WRB and SM
If you're staying normally aspirated though the EJ22T pistons will hurt instead of help because they will lower your compression. So you're kind of limited as far as increasing compression or displacement on the EJ22 without custom pistons. An EJ25 swap would be cheaper in the long run.
Old 09-22-2005, 03:08 PM   #17
tonzo
Member#: 94903
1996 Impreza Wagon!
Satin Black
Well i'm not just adding the pistons here. I'm doing a total rebuild
Old 09-22-2005, 04:05 PM   #18
GuyLR
Member#: 21811
2003 WRX Wag/01 OBS
WRB and SM
Matt, are you saying that EJ22T pistons in an EJ22E will raise compression? If yes, do you know how much?
Old 09-22-2005, 04:13 PM   #19
Matt Monson
Member#: 832
99 2.5RS, '85 911
No. They will drop his compression to 8:1 just like an Ej22T. But he said he wanted to build an engine that will later be subject to boost. Why do it twice. I know a guy who is running an EJ22T normally aspirated in his car because he could only afford to rebuild the engine at first. Now he's saving for the turbo portion of the project, but he had to keep the car running.
Contrary to what people say, driving a low compression vehicle without boost isn't a big deal. Hell, my 914 actually comes with 7.8:1 CR stock as an NA car. I find CR is a terribly misunderstood thing...
Old 09-22-2005, 06:13 PM   #20
Lethargic1
Member#: 20998
I find that as well. It is mostly misunderstood by me. After reading a few threads on the subject, it doesn't seem like something that really needs to be done by mostl; however, I'm still confused by the whole thing a little bit. People swapping this head for that head, it's madness I tell ya'
Old 09-23-2005, 02:09 PM   #21
tonzo
Member#: 94903
1996 Impreza Wagon!
Satin Black
found pistons finally at a decent price. now just need to find some good rods.
Old 09-23-2005, 04:17 PM   #22
Matt Monson
Member#: 832
99 2.5RS, '85 911
Check the threads with recent activity in the AFI forum. I don't remember which thread, but there is a guy selling rods with pistons for $350. He might part out just the rods...
Boring out a 2.0 to a 2.2? reddevil Built Motor Discussion 3 08-09-2007 06:25 PM
Boreing out a 2.0???? turboimpreza07 Built Motor Discussion 7 06-15-2006 04:31 PM
Boring out the 2.5 block? 0260B4U Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 11-05-2004 01:08 AM
More worthwhile: 2.0 re-honing or 2.2 bore-out? sick1.8t Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 07-12-2004 01:48 AM
2.5 = bored and stroked 2.2 baldcherub Normally Aspirated Powertrain 19 06-25-2002 02:15 PM
