Old 09-22-2005, 12:21 AM   #1
srf
Member#: 50646
2004 WRX STi
Java Black
Default The theory around boost target
I'm curious as to how the "target boost PSI" number is chosen, even after reading a couple dozen threads (and not having much luck with Google).
From what I've gleaned my theory so far is that you try to hit the target boost pressure relatively low in the RPM range, then boost tapers off as you approach redline, since more revolutions requires more air to be delivered in a given time period.
So then if your target boost pressure is too high, the turbo won't be able to provide enough CFM as the RPMs rise, and you'll end up with less power across the RPM range?
All this being the case, target boost pressure for a given turbo & engine combo is more or less a case of trial & error with dyno & road tunes? Then the target boost pressure would imply the rate at which boost tapers off.
Also I assume that how much a turbo heats up the air is part of the efficiency of a turbo. How would one turbo running hotter than another manifest itself in a UTEC log?
srf is offline   Reply With Quote
Old 09-24-2005, 01:42 AM   #2
TypeC
Member#: 9794
02 2.5LWRX-Retired
335i w/twins
Looking at the compressor map and plotting your flow/PR over rpm. That and going by the results/findings of others.
The boost only tapers when the turbo is too small to push the air you want. If you had the choice, you wouldn't want it to taper.
Looking at Knock correction, EGT, timing, and know the point where your turbo is maxed out.
The best bet is to research the setup you want and set it in the range that seems to work for that combo. No need in reinventing the wheel. Let other people blow motors for you. Trust me
TypeC is offline   Reply With Quote
The Tuning Boost Targets Thread Broxma Commercial ECU Reflashes 29 05-19-2014 09:53 AM
Anyway around the 24.75 psi target boost limit in the 16bit ECU? Phatron Open Source Reflashes 10 11-06-2008 06:24 PM
cobb stg 2 boost target Q/cobb rant lordzappo Engine Management & Tuning 6 10-03-2005 05:27 AM
boost targets????? Pavoni8297 Engine Management & Tuning 0 09-17-2005 11:10 AM
Cobb stage 2... not hitting boost target level... WRXVII Engine Management & Tuning 37 06-06-2004 12:14 AM
