Welcome to the North American Subaru Impreza Owners Club Thursday March 5, 2015
Old 09-22-2005, 02:20 AM   #1
moogoob
Member#: 7101
00RS I want to fill
your mouth with spiders
Default broom broom idle
2000RS
142k mile
LW flywheel
stromung catback
Ganzflow intake
Idle makes funny noise as title says, broom..broom..broom. once a second or so. Its not enough of a rev to move the needle though. The lights also dimmed between each mini rev.
This is a new problem. did not exibit these symptoms when idle before commute home. Stopped at a light after drive (45 miles) and noticed it. Felt like it might stall, but I let it sit idle for a while and there was no change, normal idle with a broom broom...
no symptoms when driving
car feels and sounds good
no CEL
Did not sound like i popped a plug wire off, that usually makes a more distinct burble pop..rev...
i just filled up, could bad gas do this?
I have not had a chance to look over anything tonight, any ideas where should I start?
moogoob is offline   Reply With Quote
Old 09-22-2005, 08:24 AM   #2
t3hWIT
Member#: 58779
95 STi RA (rhd)
98 Tacoma (300k Club)
any bogging? just a start, but check the hose from the idle air control valve.
t3hWIT is offline   Reply With Quote
Old 09-22-2005, 09:59 AM   #3
Pat L.I.
Member#: 20498
2006 WRX TR
bad gas? plugs/wires? clean the terminals on the coil pack. front 02 sensor?
Pat L.I. is offline   Reply With Quote
Old 09-22-2005, 03:43 PM   #4
moogoob
Member#: 7101
00RS I want to fill
No bogging at all.
All hoses seem to be on.
Plugs on 1 & 3 felt like they needed to be Pushed on more (I have magnecore wires) The engine did not behave as if they were not on but I Gave em all a ood shove anyway.
The coil pack on 3 was nasty black and goopy, 1 was evenly white coated. 2 & 4 (4 was the cuplret last time the wire popped off) was nice and clean.
I cleaned em up and topped off the oil and coolant since i was there already.
The idle was fine when cool, but after it warmed up a bit(2 miles or so to the first traffic light), it behaved the same.
Normal driving was fine.
Acceleration is fine on to highway as well
If I ever so slighty touch the gas the idle will steady at 1000RPMs.
Old 09-23-2005, 01:12 AM   #5
moogoob
Member#: 7101
00RS I want to fill
OK, New update.
Leaving the office today it was broom..brooming at the light, Threw a CEL.
Sit in traffic (car fire on a bridge) and it happens a bit more.
Arrive home hour and 20 later, no broom broom... noises. Steady idle.
I give it some time to see if it starts acting up again (5 minutes) but it is a perfectly smooth idle.
I'll try to find a code puller..
any thoughts on that?
Old 09-23-2005, 02:30 AM   #6
Kaymin
Member#: 96076
RIP 96 SBM GC8
05 Burnt Orange Evo
did u refill gas again? was ur tank really empty and sucked somethin bad in? lol i'm noob but i try and help with what i know
Kaymin is offline   Reply With Quote
Old 09-23-2005, 02:59 AM   #7
moogoob
Member#: 7101
00RS I want to fill
tank was half, filled it with same gas i usually fill it with...before it started, I'm only 150 imles into the same tank.
Old 03-25-2006, 09:27 AM   #8
moogoob
Member#: 7101
00RS I want to fill
Update: After it went away on its own.. I havent had the problem since.
Now at 154k miles.
Old 04-19-2006, 03:00 PM   #9
impreza_punk
Member#: 102900
2005 Impreza STi
Hey moogoob finally fixed my issue and posting it as well. My car had the same symptoms to a tee and after a week or two just progressed worst. Finally got the correct 02 sensor (#22791AA00A) and seemed to do the trick.
impreza_punk is offline   Reply With Quote
Old 04-19-2006, 11:09 PM   #10
newbiescooby2.5rs
Member#: 93758
Try seafoam in your fuel tank? cleans up idle a bit.
newbiescooby2.5rs is offline   Reply With Quote
Old 02-12-2007, 12:40 AM   #11
moogoob
Member#: 7101
00RS I want to fill
Well, another update at 167k mile.
Directly after a fill up, it started again... same symptoms.
I coughed it up to another bad tank.
My optima battery arrived and was installed shortly after. No more funny idle. The old battery was the original (2000) that came with my RS and was having a real hard time starting the car.
Could low voltage from the Bat been my problem all along, or just another coincidence....
get out the brooms, we're looking for a sweep. Tim Sanderson Mid West Subaru Owners Club Forum -- MWSOC 12 07-08-2004 02:00 PM
SUNY Binghamton / Broome County 300blueballs Tri-State Area Forum 8 09-30-2003 11:07 PM
Small Broom Ball Meet BuddyChrist Southern California Impreza Club Forum -- SCIC 22 05-09-2003 09:45 PM
Broom Ball pics mattjk Southern California Impreza Club Forum -- SCIC 16 10-10-2002 01:06 PM
I got the broom, you guy's have the dust pan? well_armed Texas Impreza Club Forum -- TXIC 6 04-16-2002 04:55 AM
