Old 09-22-2005, 10:51 AM   #1
sadd16
Member#: 37717
2002 Impreza WRX
Default Accessport: unable to change realtime maps for 02 wrx
With the news about gas prices going up, I decided to finally change to an economy map on my accessport.
Whenever I choose the "switch map" option, it tells me to select a map, so I select the economy map and hit the OK button, shows that it's sending to my ecu, and then tells me it's DONE and to click OK. So I clicked OK and then checked the map that it's currently using, and it's still showing Stage 2 93 octane.
I've tried changing the map while the car is turned off but with the ignition key set to ON, also tried other maps like valet, but that didn't change it either. Also tried changing the map with the car ON but it keeps showing Stage 2 93 octane.
What is the problem here? I also have Stage 2 93 octane set as my base map.
sadd16 is offline   Reply With Quote
Old 09-22-2005, 11:10 AM   #2
AdmiralWRX
Member#: 80204
2005 WRX++
I believe the AP will only display the base map you are currently running.
AdmiralWRX is offline   Reply With Quote
Old 09-22-2005, 11:11 AM   #3
pictureboy
Member#: 85132
11 Jeep
When you check current map the AP will only tell you the base map! Unfortunately there is no way to check whick real time map you are running. Or at least this has been my experience.
pictureboy is offline   Reply With Quote
Old 09-22-2005, 11:16 AM   #4
AdmiralWRX
Member#: 80204
2005 WRX++
User's Guide is your friend:
AccessPort User's Guide
Show current map only displays base map currently in use.
Old 09-22-2005, 12:01 PM   #5
BoostinEJ20
Member#: 73710
yup +1 for the accessport only showing base map.
BoostinEJ20 is offline   Reply With Quote
Old 09-22-2005, 01:14 PM   #6
sadd16
Member#: 37717
2002 Impreza WRX
AHHH no wonder. I was trying to for the life of me to figure it out.
The manual I had with it basically just said how to change it and how to view what map you have.
Thanks!
Old 09-22-2005, 06:16 PM   #7
hondaeater69
Member#: 60324
this should be a feature added to the AP SW. Not knowing what RT map you're running could be VERY dangerous. . .
Old 09-22-2005, 06:53 PM   #8
Poodie
Member#: 76010
05 WRX Sti
CGM
Yeah, but if you're that worried you could just reload whatever map you want
Poodie is offline   Reply With Quote
Old 09-22-2005, 07:10 PM   #9
hondaeater69
Member#: 60324
no kidding, but that's not the point. IMO it's fairly important to know what map you're running, base or RT>
Old 09-22-2005, 08:58 PM   #10
mrbell
Member#: 1871
2000 Impreza 2.5RS
Blue Ridge Pearl
The process of loading a realtime map is pretty fail-proof. If the AP says OK, and you know your battery hasn't been disconnected, then the realtime has been loaded. Base maps are a bit more complicated, and it's possible that something could happen to prevent you from having a proper basemap. In any case, the hardware of most of the ECU's prevents us from "signing" the realtime maps currently, so there's no way for the AP to easily say what map is running. The ONLY solution possibly available to us now is to read back the whole realtime map and compare it, byte by byte, to the maps on the AP. But the hardware of the AP doesn't make this currently feasable. It's quite possible, however, that the map no longer exists on the AP, and therefore reading it back wouldn't tell you what you were running.
Our philosophy is this: the basemap should match the hardware of the car the realtime map should be modifications on top of this. It really should not be dangerous to lose your basemap.
That said, we do recognize the need for and lack of this feature. We are addressing it, but it is not as simple as I would have thought it would be before I started looking at it.
mrbell is offline   Reply With Quote
Old 09-30-2005, 12:08 AM   #11
Trip McNealy
Member#: 37338
2007 Legacy 2.5 GT
2009 Daytona 675
I have a somewhat related question..when you load a realtime map into the ECU, how do you disable it and go back to the base map (stage 2 in my case)? does that entail me having to also transfer a realtime map for a stage 2 even though it's my base to begin with??
Trip McNealy is offline   Reply With Quote
Old 09-30-2005, 12:52 AM   #12
mcowger
Member#: 77483
2009 Audi A3 2.0T q
Lava Grey
You could either xfer the realtime version of your basemap, or reset your ECU.
mcowger is offline   Reply With Quote
Old 09-30-2005, 12:54 PM   #13
erik04wrx
Member#: 88066
2004 wrx sedan java
black Cobb SII
^ what he said
and for keeping track of what map is in use....... buy post-its or try to remember, my butt-dyno tells me wich map is running
erik04wrx is offline   Reply With Quote
Tactrix Ecu Cable with connectors for 02-05 and Map for 02 WRX deathskrye Engine/Power/Exhaust 3 02-25-2008 08:10 PM
Hybrid Map for 02 WRX? duece_bugeye UTEC 2 04-06-2007 03:39 PM
how many KM do you get on Accessport's economy map for 02 wrx sadd16 Engine Management & Tuning 0 09-22-2005 02:44 PM
Going from a TXS st1 w/TDO4 to VF29 do I need to change the map for now? Camperguy Engine Management & Tuning 7 08-06-2003 10:20 AM
Motec system maps for 02 WRX alfriedesq Factory 2.0L Turbo Powertrain 88 02-02-2002 03:17 PM
Message Board Statistics All times are GMT -4. The time now is 12:03 PM.
