Old 09-22-2005, 05:20 PM   #1
M32WRXin3seconds
Member#: 36797
Default Simple 05 legacy GT question...Top mount swap..
Can you install an intercooler from an 04-05 sti USDM V8 on the 05 leg gt (or the forester xt?) I have one sitting around and was wondering if i should send it up to my parents...
Josh
M32WRXin3seconds is offline   Reply With Quote
Old 09-22-2005, 05:24 PM   #2
melayout
Member#: 69316
2005 Legacy 2.5 GT
Black OBIS.blah.blah.DAN
I don't think so.
Plus, I've *heard* that the stock LGT IC is more efficient than the STi one and it's plastic endtanks result in less heatsoak compared to the STi all metal design.
melayout is offline   Reply With Quote
Old 09-22-2005, 05:36 PM   #3
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
you cant on the 05 GT use it unless you change the IC, turbo, and intake manifold. you can use it on the XT.
Ben
Old 09-22-2005, 05:48 PM   #4
Huffer
Member#: 36735
99 GF8 Impreza 2.0
2= 1998 BD + BK Legacy GT
They're physically different dimensions. The LGT one is smaller.
I recently assisted on an exhaust install on the LGT, and a friend with an 05 STi arrived, so we compared engine bays.
Huffer is offline   Reply With Quote
Old 09-22-2005, 06:47 PM   #5
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
smaller IC is not always less efficient, I'd imagine the LGT one is more efficient as melayout says he *heard*
Wiscon_Mark is offline   Reply With Quote
Old 09-22-2005, 07:10 PM   #6
PHATsuby
Member#: 13617
2001 Legacy GT back
they are not just physically different dimensions, the turbo bolts to the IC, so it has a flange on its compressor outlet that bolts to the IC, then the IC outlet is on the bottom diagonal and goes into the throttle body that is actually under the intake manifold on the drivers side.
the LGT IC is in fact as efficient as the STi IC due to its crossflow and end tank layout even though its actual surface area is smaller.
Ben
Old 09-22-2005, 07:24 PM   #7
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
isn't the LGT hood better for airflow to the IC also?
Old 09-22-2005, 11:02 PM   #8
PHATsuby
Member#: 13617
2001 Legacy GT back
I am not sure, I have no data to back up a statement, the design seems like it may be able to have better flow, because the cut in the hood basically just lets air go straight through to the IC instead of pulling it in with the scoop like on the STi. But i really couldnt say for sure.
Ben
Old 09-22-2005, 11:20 PM   #9
Edvig
Member#: 16147
no more turbo
05 Legacy, 11 Outback
Josh...I've read that the LGT IC is more efficient than the STi one as well.
Have your Dad do this...
http://legacygt.com/forums/showthread.php?t=19301
Check out LegacyGT.com for more fun filled information.
Edvig is offline   Reply With Quote
Old 09-23-2005, 01:45 AM   #10
Subietonic
Member#: 12588
Four Count 'em
GF5,BDA,BD5, BP5
Relatively new Perrin TMIC here. Will go quick and price may be negotiable. Almost two times the size of the stock LGT TMIC and double the size of the cooling channels.
Subietonic is online now   Reply With Quote
(NY) 05 Legacy GT Turbo Transmission (Direct swap into RS) GC8 400hp! SOLD mtcs Drivetrain 5 10-28-2009 09:17 PM
NY: 05 Legacy GT Turbo Transmission (Direct swap into RS) GC8 400hp! SOLD mtcs 1993 - 2001 Impreza Specific Parts 6 10-28-2009 09:16 PM
FS: (NJ) 05-08 Legacy GT Perrin top mount inercooler and other Parts MR YAT Legacy Specific Parts 5 03-30-2009 12:45 PM
WTB: ASAP (Today Tues) 05 Legacy GT Strut Top (front) or Pair of upgraded strut tops Paisan Tri-State Area Private Classifieds 0 07-15-2008 06:13 AM
New 05 Legacy GT questions unbekabal Legacy Forum 15 08-21-2004 07:47 PM
