Old 09-22-2005, 10:43 PM   #1
wrxzo6
Member#: 95835
2002 wrx,zo6,87 GN
gray,black,black
Question Wrx Won't Stay Running
I broke my O2 sensor on the header so i guessed that was it. So i order a new one and a utec for later.It did not fix my problem. My car will start gose to 2k then dies sometime right away then sometime it will try to run but not long. It is real rich when it dose run. I put a up and down pipe ,short ram, pulley all perrin, headders, and now a utec. My problem was befor the utec was on it. The only thing i can think of is something with the mas on the short ram it is on the right way because there is only one way it gose on. Has anyone had this happen to them? if someone can help me i would be greatful.
wrxzo6 is offline   Reply With Quote
Old 09-23-2005, 01:03 AM   #2
VolkWRX56
Member#: 93083
2015 WRX Premium
Crystal White Pearl
When exactly did the problem start? Did you install something and then it started happening? Give us a break down.
VolkWRX56 is offline   Reply With Quote
Old 09-23-2005, 01:28 AM   #3
RallyImprezive
Member#: 5476
2007 WRX UGM
2010 FXT
Check all the vacuum lines. I'd be willing to bet one popped off or was not reinstalled correctly.
- Andy
RallyImprezive is offline   Reply With Quote
Old 09-23-2005, 04:13 AM   #4
specialev
Member#: 90156
1986 Syncro Vanaru
07 SV650
Or it was overlooked and subsequently not reinstalled whatsoever.
specialev is offline   Reply With Quote
Old 09-23-2005, 09:27 AM   #5
wrxzo6
Member#: 95835
2002 wrx,zo6,87 GN
gray,black,black
No it happened after the install. What lines could it be? I don t rem taking lines off
Old 09-23-2005, 11:21 AM   #6
wrxzo6
Member#: 95835
2002 wrx,zo6,87 GN
gray,black,black
Is there any sensors that could cause this to happen like this? This has me .
Old 05-05-2013, 08:16 PM   #7
Mcgregordm
Member#: 354691
Default Help
I am also having similar problems my car was running fine as I was driving back to my house I shifted from first to second in between gears I lost engine power and couldn't get it to start again at idle with the throttle down and 3ooo rims I could get it to run but had a little Dark smoke coming out started throwing misfire codes on all four and a running rich code. After I got it home I couldn't get it started at all I disconnected the mass air flow sensor and it will run first turn of the key but back fires I replaced MAS and still nothing. I need help I also replaced plugs with no difference and put fuel cleaner in. Everyone keeps saying ins my ignition coils or cam sensors. Would like to get some more input before I start replacing other pointless stuff.
Mcgregordm is offline   Reply With Quote
How to fix a Stg 4 that won't stay running, or "A month in the shop" shikataganai Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 05-11-2006 10:58 AM
My car won't stay running.....Utec Pacobeagle Engine Management & Tuning 5 09-18-2005 07:33 AM
Engine won't stay running. Need help. Phantom Rex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 07-14-2004 01:16 AM
HELP.. car won't stay running WRXonmind Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-12-2004 05:40 PM
Help..My won't stay running... vinster02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 09-02-2003 12:11 AM
