Old 09-23-2005, 12:56 AM   #1
anthonyrb98
Member#: 48307
02 bugeye
hbspeed tuned 18g sleeper
Default can compression test be done with accessport and antitheft mode?
i was just wondering if you can do a compression test with an accessport and antitheft mode (where the car won't start if you load the antitheft map)
to crank the engine without having to disconnect any fuses and such to disable spark and fuel.
anthonyrb98 is offline   Reply With Quote
Old 09-23-2005, 12:33 PM   #2
Rick Schu
Member#: 34661
The car has to crank in order to do the compression test. I've never used the anti-theft map, but I would imagine the starter won't even work at all.
You don't need to pull fuses - there is a green connector under the glovebox behind the ride side passenger kick panel. Disconnect this and then start the engine until it dies. Then crank for 5 more seconds.
You have to pull out ALL the spark plugs anyway for a compression test, even before testing the first cylinder. So, that means you have to pull out the coils anyway. That takes care of the ignition side.
Rick Schu is offline   Reply With Quote
Old 09-23-2005, 01:02 PM   #3
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
actually yes it should. i forget which on one of the two maps is better ...
i would pull the fuel pump fuse and let the car idel for a sec before hand but yes this is a fair idea
and yes the starter will work just fine
Old 09-23-2005, 01:21 PM   #4
parker/slc/gc8fan
Member#: 46241
- RIP
SDF-1
I cannot reccomend using this map for a compresion test.
The best way to do this for a WRX is to disconnect the ECU, the fuel, Floor the throttle to let air in, and turn the car over.
parker/slc/gc8fan is online now   Reply With Quote
Old 09-23-2005, 02:02 PM   #5
Corkfish
Member#: 39503
According to the Cobb website, the anti theft mode allows the car to idle. Once it goes over 1000 RPMs, the engine cuts out.
Corkfish is offline   Reply With Quote
Old 09-23-2005, 05:18 PM   #6
Rick Schu
Member#: 34661
Well, if it lets it idle, then you still have fuel pressure. I think he wanted to use the anti-theft map instead of disconnecting the fuel pump relay. So, this doesn't help you at all.
Just disconnect the fuel pump relay and start it still it stalls and then crank for 5 more seconds - takes like a minute to do. You have to pull all the plugs anyways to get an accurate reading, even before you test the first cylinder - this means your coils will have to come out, so that takes care of your ignition. Hook up your gauge. Put the accelerator to the floor. Then crank for like 3 seconds. Repeat for the other cylinders.
Old 09-23-2005, 05:41 PM   #7
MikeWRX-NJ
Member#: 33410
08 wrx
dgm
that's anti-theft map B
map A keeps the car from starting, period. I'm not sure if it simply closes the injectors/turns off the pump/sets the rev limit to 0.
MikeWRX-NJ is offline   Reply With Quote
Old 09-23-2005, 09:00 PM   #8
anthonyrb98
Member#: 48307
02 bugeye
yeah, one of the antitheft maps will not allow the car to start, so i thought that would be sufficient as far as cranking the car without having to disconnect anything
Old 09-24-2005, 01:32 PM   #9
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
um since parker is a cobb employee
his post shold have ended this thread ...
Old 09-24-2005, 02:30 PM   #10
Rick Schu
Member#: 34661
The other anti-theft map still uses a rev limiter - just set really low, so the car can't idle. That means some fuel pressure.
Old 09-24-2005, 02:38 PM   #11
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The best way to do a compression test is to pull the "IGN" fuse from the underdash fuse box. This completely disables the ECU in one easy step so there will be no spark or fuel. Pulling the fuel pump relay plug is fine for depressurizing the fuel system, but the ECU will still be active when the engine is cranked and the coil packs will have power (although they won't be grounded if removed to pull the plugs). Also even with the fuel pump disconnected the injectors will still operate and there will be residual fuel injected into the cylinders which could affect the compression readings.
Pull the fuse, do test, replace fuse, done.
Old 09-25-2005, 04:16 PM   #12
Rick Schu
Member#: 34661
How much residual fuel can there be if he cranks the engine until it stalls and then cranks for 5 more seconds? Not enough to affect a compression reading. Pulling the fuse would probably be a tad easier though.
Old 09-25-2005, 05:05 PM   #13
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Probably not much fuel, but pulling the fuse will completely shut down the ECU so the injectors and coil packs will not be active at all.
Can anything be done with these? shooter4fun Subaru Conversions 2 11-10-2005 09:33 PM
can this be done with out fender rolling? mixjon Tire & Wheel 16 09-05-2005 09:00 PM
Don't discuss, just view and be done with it Spheris South East Region Forum 14 03-21-2004 07:02 PM
Don't discuss, just view and be done with it Spheris Off-Topic 28 03-19-2004 04:28 PM
Can a UTEC be used with intake and FMIC ? blitz01 Engine Management & Tuning 6 02-19-2003 02:52 PM
