Welcome to the North American Subaru Impreza Owners Club Thursday June 20, 2013
Old 09-14-2005, 09:52 PM   #1
Hondaslayer
the artiest
Member#: 4562
1998 Forester,lifted
95 Legacy,75 VW Westfalia
Default What?? Teh hondarslayer back in the AFI game??
Yep, Co-worker bought an old Minnam kit for his RS, so you guys will be seeing more of my traitor ass in here
So whats the new engine management of choice for the RS?
Any places to still buy a P&P harness for the Link plus?
Old 09-15-2005, 12:01 PM   #2
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
Link+ is dated but cheap - if you don't mind piggybacks, eManage and PerfectPower seems to do the job. Depends on whether you need OBD-II, I wouldn't remove the stock ECU at all. I just wish i-Speed made an RS-T reflash but they didn't...
kgb is offline   Reply With Quote
Old 09-15-2005, 12:11 PM   #3
Drac9
Member#: 9861
1999 2.35 RS-T w/NOS
Hybrid Rally Blue Pearl
Autronic here
Drac9 is offline   Reply With Quote
Old 09-15-2005, 01:19 PM   #4
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
P&P harnesses are very hard to find outside of the manufacturer
and QUITE expensive
its almost more cost effective to buy an emanage for what its worth
White 2.5rs is offline   Reply With Quote
Old 09-15-2005, 02:21 PM   #5
Hitokiri
Member#: 2604
1999 2.5RSt
RBP
emanage ultimate if you are going to get an emanage
Hitokiri is offline   Reply With Quote
Old 09-15-2005, 07:49 PM   #6
Hondaslayer
the artiest
Member#: 4562
I never liked the E-manage, I just have experience with the Link (and loved it)
He is considering a Hydra at this point.
What the hell is a Hydra??
Old 09-15-2005, 07:53 PM   #7
DoctorNick
Member#: 7022
2013 BRZ Limited
A local has a hydra on his RS. Seems to like it. Seems like the link is still the way to go. I keep hearing about this perfect power but don't know much about it.
Wish it was as easy as wireing in a wrx ecu and getting a reflash.
DoctorNick is offline   Reply With Quote
Old 09-15-2005, 08:43 PM   #8
Andursun0013
Member#: 11616
1998 2.35RS-T
2006 Baja 2007 Leg. Wagon
Hydra -- they can hook you up with a p&p harness -- I haven't had much time to play with mine yet to tell you how i like it but its good so far.
Andursun0013 is offline   Reply With Quote
Old 09-15-2005, 10:44 PM   #9
speed_freak27
Member#: 30798
2001 RS-T Hybrid
2.5>2.2T>257>2.35S
I vote for the link+ as well. A local guy just picked one up off rs25 for 500. Might look over there. I've heard good things about autronic as well but it's rather expensive.
P.S Why didn't you put a 3" downpipe w/ a wg dump on the car to begin with it would have saved me from having to have on fabricated.
speed_freak27 is offline   Reply With Quote
Old 09-16-2005, 12:48 AM   #10
shemoves
Member#: 80663
1997 Outback
1. Complete standalone ECU
2. multi-headed dragon
shemoves is offline   Reply With Quote
Old 09-16-2005, 08:38 AM   #11
Hondaslayer
the artiest
Member#: 4562
Pm SubEd for details
I wanted to run WRX and VF-series turbos on it.
Old 09-16-2005, 09:20 AM   #12
8Complex
Member#: 922
04 FXT
Red
www.hydraems.com
8Complex is offline   Reply With Quote
Old 09-16-2005, 12:12 PM   #13
PDXTuning
Member#: 49831
2008 Get Tuned Now
Knowledge is Power
Autronic for me
Ben
PDXTuning is offline   Reply With Quote
Old 09-16-2005, 12:41 PM   #14
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
For a used one, it is a good deal if you don't care for OBD-II and you don't live in a place where climate changes drastically. That thing is just too big to allow for the stock ECU to run along side with it (to provide OBD-II). I hope the link+ is doing IAT corrections because my Link-1 certainly doesn't (unless I upgrade to version 5 and get their IAT since it says it can't use the stock IAT )
I guess there are still a few RS-Ts running around with Link+ and doing OK.
Old 09-16-2005, 01:37 PM   #15
DoctorNick
Member#: 7022
2013 BRZ Limited
Old 09-16-2005, 11:06 PM   #16
imp2.5
Member#: 11354
2009 LGT
BF3 tag: Snbrd4evr
I have a hydra. I love it, autotune, closed loop is really easy to control and set up. But it's all up to you, go with what you know
imp2.5 is offline   Reply With Quote
Old 09-21-2005, 05:33 PM   #17
PunKidd
Member#: 8533
2002 2.5 RS-T
LudeSpeed S. III W/ FMIC
I'm still running the Link + as well, but I've been trying to find a PNP harness w/ little luck. I want to start developing an RS-T reflash, but I need to be able to swap back and fourth easly and right now it's hardwired in. Let me know if you find anyone who still has them in stock.
-Jared.
PunKidd is offline   Reply With Quote
Old 09-21-2005, 08:33 PM   #18
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
Actually, who can obtain the plugs for both side (stock ECU and stock harness)? I suppose those plugs are expensive enough that I shouldn't bother trying to make my own PnP harness? Those PnP harness are getting awful hard to find used, let alone new
Old 09-21-2005, 10:42 PM   #19
PunKidd
Member#: 8533
2002 2.5 RS-T
The Link Side comes w/ the link. If you feel like picking up a stock ECU from the junk yard you can get the other end that way.
If anyone is going to do this, let me know & I'll try and dig up the pin out I had for a PNP harness a few years back. It's not hard to piece togeather, but I had it in excell format, and if the work has been done why repeat. It's been tested, so you know it will work on the first shot.
-Jared
Old 09-22-2005, 03:06 PM   #20
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
So that's how the plugs are made - junk yard ECU and harness. I just wish someone in the plastic industry can clone those and not get sued
Old 09-22-2005, 08:01 PM   #21
PunKidd
Member#: 8533
2002 2.5 RS-T
There was a guy on here back in 01 or 02 that knew where to get them in bulk from a supplier. He had to buy them in min qty of 1,000, and I don’t know if he ever got them or not. I’m sure they can be sourced, it’s just easier to hit up a wrecking yard.
And you only need the ECU side beings you plug the PNP harness into your existing chassis harness.
-Jared.
Old 09-23-2005, 02:08 AM   #22
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
Unless of course you need to run Parallel Engine Management with the stock ECU
Old 09-23-2005, 11:31 AM   #23
PunKidd
Member#: 8533
2002 2.5 RS-T
Parallel??? I guess you could use both sides of the harness if you planed to run a piggy back w/ the stock ECU, but the PNP harnesses were typically so that you can swap your stock ECU out w/ a stand alone w/o any cutting or soldering
Old 09-23-2005, 12:55 PM   #24
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
Yes, for something like a Link+ that can handle everything in the car, I can see that you can go without the stock ECU. Except no aftermarket ECU supports OBD-II, and I certainly don't want a blown motor during smog check running the stocker
LeeC is Back in the Subaru Game! LeeC Member's Car Gallery 54 04-29-2010 06:34 PM
My New 08! I am back in the Subaru Game! Touge86 Member's Car Gallery 18 12-11-2008 04:13 PM
Back in the dating game advice... Spitfire999 Off-Topic 44 06-26-2007 09:23 PM
Want to get back in the Scoobie game! GooseMan General Community 10 08-15-2006 02:42 PM
So I want to get back in the Subie game.... GooseMan Legacy Forum 14 08-14-2006 01:36 PM
Message Board Statistics All times are GMT -4. The time now is 05:53 AM.
