Old 09-23-2005, 12:33 PM   #1
spdracr00
Member#: 65823
1996 Impreza L
Red
Default ej25's are all the same right?
I have a 99LOB with the ej25 motor, so could i use a set of plug wires made for an impreza with the 2.5 motor as well? or are the two 2.5's different? the reason i ask is my friend has a set of nology wires for a 2.5rs and i was wondering if they would fit my ej25.
thanks
-ben
spdracr00 is offline   Reply With Quote
Old 09-23-2005, 01:24 PM   #2
99subi
Member#: 78118
2002 Corvette coupe
05 Legacy
there are two of them there is a dohc one and a sohc one,either way the wires will work so your fine
99subi is offline   Reply With Quote
Old 09-23-2005, 06:10 PM   #3
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Actually, if I am not mistaken the DOHC wires are different than the SOHC ones. You should have a DOHC Ej25. Unless your buddy has a '98 RS, his is SOHC...
are all the airbag resistance the same wrxburton Electrical & Lighting 2 01-04-2007 05:45 PM
Are all the fuses the same? shemoves Electrical & Lighting 1 05-03-2006 01:01 PM
everyone always says no matter what the towns, cities and people are all the same.... doubledribble Off-Topic 27 05-27-2005 01:29 PM
Are rod/main bearings all the same or is one brand better then the other? lotus2843 Service & Maintenance 0 01-05-2005 12:14 AM
are 2.2's all the same? merlin8019 Normally Aspirated Powertrain 1 12-21-2000 03:28 AM
