Closed Thread
Old 08-23-2001, 03:45 PM   #1
Imprezer
Dynamic Uno
Member#: 1
2011 Impreza WRX STi
Default WRX Turbo Install Tips and Tricks
Yesterday I re-installed my tiny stock turbo. I have to send my VF-22 to get it checked out. This is the 4th time I replaced the turbo on a WRX myself and even then I did some mistakes, but since I think I have done every single mistake you can make, I will tell you guys what to do and what not to do in order to avoid as much problems as possible.
1. Always drain the coolant complely before doing anything. I prefer to disconnect the lower radiator hose. This way both the block and the radiator get drained right away.
2. Open the hood all the way. I usually just tie a rope to the locking mechanism and tie it to my garage celling. This gives you more room to work.
3. Do not lean on the fenders too much. They WILL bevel in.
4. Remove the IC and put a rubber glov onto the TB to prevent stuff from getting there.
5. Undo the coolant lines from the turbo first. Get some paper towels and collect some coolant that will leak out from the turbo and the hoses. There isn't much of it there (if you drained the system) but enough to get all over, stink and cause white spots.
6. Undo the oil feed line and gently bent it out of the way or loosen the bolt that holds it to the block (good luck trying to do that) and move it out of the way.
7. Once the coolant and the oil feed line are off, unbolt the intake pipe.
8. Remove the downpipe. Make sure to wait long enough until the turbo is cold. Warm bolt tend to get stuck and cause major pain.
9. Once the bolts are removed the only thing that is holding the turbo is the oil return line which is clamped onto the turbo with a very weak clamp.
10. You can pul the turbo straight up.
11. MAKE SURE NOT TO LET ANYTHING FALL INTO THE UPPIPE. This will take about 2 extra hours to disassemble the header and the uppipe and get that something out of there. I prefer to slowly pull the turbo up and cover the uppipe with my hand, and then plug the hole with a paper towel.
12. If you get coolant into the uppipe, you can loosen the header/uppipe joint and drain it.
13. When putting the new turbo in, simply PLUG it onto the oil return line. Move the clamp about 4mm away from the top. Make sure that the turbo is pluged onto the hose.
14. Make sure to refill the coolant after you are done.
15. First thing to check after you start the car with a new turbo is all the coolant and oil lines. They MUST not leak. Look under the car and make sure that nothing is leaking.
I think these are the most crutial areas of the turbo install. Feel free to ask any questions you may have. If you know what you are doing, you can replace the turbo in about 1.5 hours.
Imprezer is offline
Old 08-23-2001, 04:28 PM   #2
DeliciouSpeed
Member#: 3389
07 STImpreza
Satin
K here is my question, wanna come to my house and help me do this next weekend . K Im laughing but I am serious, I have air tools. And beer (tapping neck)...
Ken
DeliciouSpeed is offline
Old 08-23-2001, 04:37 PM   #3
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
Imprezer - could have used those intructions before I bent my fender !!!!!!
Thanks for the tips -
Hey my jap instructions that came with the PE 1820 which I got translated gave another hint - before you put the oil intake line on the top of the turbo - but after its pluged over the oil out put hose - squirt a bit of oil into the intake of the turbo to prime the bearing - - and chaneg the oil after 500 miles break in
Imprezer - - I'd really LOVE to hear how the car runs with the uppipe and all that with the stock turbo - - how quick does it spool ??? It must have lots of low end????
alfriedesq is offline
Old 08-23-2001, 06:20 PM   #4
illmatic
Member#: 3536
2015 IMS BRZ Limited
2002/2003 AW/PSM WRX
Will you have to reprogram the tec2 with the stock turbo?
illmatic is offline
Old 08-23-2001, 06:26 PM   #5
nmyeti
Member#: 4980
My car is as described... 1bar at 3000rpms in 3rd gear. Not bad for 5200 feet above sea level. I was at 1 bar at about 3600-4000rpms stock.
-Nathan
nmyeti is offline
Old 04-08-2010, 09:58 PM   #6
tubmyster
Member#: 59868
so these tips are great!
I would like to ask a question to clarify about tip 13.
by simply plugging it into the oil return line, is there a risk that the line will come off if it is not clamped?
tubmyster is offline
Old 04-09-2010, 03:50 PM   #7
andrew3776
Member#: 172133
2003 vfdirty wrx
rotten banana
For step 13, make sure you tighten the lower part of the hose and make sure its tight. Mine came off when i did mine and its easier. Just to clarify that step. And also add, when taking the large coolant inlet line off, have something to plug into it so you dont lose a lot of coolant. And you wont have any burping issues. I plugged mine right away and the coolant didnt need to be burped and only lost the coolant that was in the turbo.
andrew3776 is offline
Old 07-16-2010, 04:12 AM   #8
oguitar
Member#: 206720
2002 WRX Wagon
Bump in honor of NASIOC member #1 Imprezer.
oguitar is offline
Old 03-13-2012, 03:52 AM   #9
SubaDre7
Member#: 242645
Bump!
SubaDre7 is offline
Old 03-22-2012, 09:03 PM   #10
glennegrabil
Member#: 313475
Cool turbo replacement on my2002wrx wagon
i do believe my turb0 is going out, lots of smoke,,""only sometimes"" so i've been checkin out alot of options, should i do a rebuild kit myself?? should i upgrade?? if i dooo upgrade can i get something that will give me ""MORE"" low end torque?? not so interested in doing 145, as i am gettin it thru some tight cornering,, ""hate that turbo lag"",, luuuuv my subbi,, thought my rings took a dive on me,, or that i had a gasket go out, no signs of oil in my coolant, or coolant in my oil,, no loss of power,, so00o0ooo must be the turb0!!!,, any addvice wrx world??? o0o00o and i am a discount kind of a guy,, any turb0's layin around collecting dust,, do'nt need don't want???,,, other needs include:: passenger front fender,,bumper cover& passenger fog lite,, spun out black ice in a snow storm,, bummer of a day,, still here tho
glennegrabil is offline
Old 03-22-2012, 09:05 PM   #11
CrazyCatfish5
Member#: 245236
2003 WRX
Rally Blue
Woahhhhhhhhh
CrazyCatfish5 is offline
Old 03-22-2012, 11:54 PM   #12
FD_Wear
Member#: 314323
Very helpful, I've been thinking of upgrading the turbo in mine for a while...
FD_Wear is offline
Old 03-26-2012, 10:42 PM   #13
LatentWagen
Member#: 50315
0806 LGTspecB & Saab
9-2xAero5MT DGM & MBP
I hope you are trolling...
LatentWagen is online now
Old 03-27-2012, 12:29 AM   #14
Haelan
Member#: 151045
2013 Subaru STI
CBP
Another small tip to add here. My Monster TD04 finally start leaking oil and I recently replaced it. I used a pair of these to pinch off the coolant feed line to the turbo instead of draining the system:
Worked pretty well and saved some time.
Haelan is offline
Old 03-27-2012, 02:26 PM   #15
wrx surfwagon
Member#: 262719
02 WRX
PSM with rust accents
I watched a vid and a guy plugged the line with a AA battery. I had batteries ready and did the same, it worked perfect.
wrx surfwagon is offline
Old 03-27-2012, 08:06 PM   #16
jchafee
Member#: 238453
05 05 WRX
These x2 makes it so much easier to not have to dean your entire system. I have a pair of matco ones. They still drip a bit, but Nothing a well placed rag won't take care of. As for the aa batteries, that's an awesome idea. I maybe have to give it a try.
jchafee is offline
Old 04-25-2012, 10:44 AM   #17
wgr73
Member#: 232458
2005 & 2008 STi
Cobb 20g & EFR 7670
#1 has been found! Oh, and great tutorial
wgr73 is offline
Old 04-25-2012, 08:01 PM   #18
SubieMonte
Member#: 264803
2005 WRX Wagon
GANGSTER!
SubieMonte is offline
Closed Thread
Arminís Quick and Dirty Tips and Tricks to Automotive Photography Verdugo Member's Car Gallery 10879 10-08-2016 08:47 PM
FS: Stock 04 WRX exhaust jouka NESIC Private Classifieds 24 06-22-2010 11:54 AM
Engine install Gurus....tips and tricks? n2xlr8n Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 32 06-28-2005 04:34 PM
Coilover install/setup tips and tricks (help needed) jackansi Brakes, Steering & Suspension 15 05-14-2003 10:29 PM
Sweet amp install tip and trunk alarm trick. Jessie James Car Audio, Video & Security 6 07-20-2001 11:30 AM
