Old 09-24-2005, 02:02 AM   #1
Imprezanize
Member#: 45273
2002 Impreza 2.5 RS
Default detonation sequence
what is the detonation sequence, if you are facing the car. 2.5rs my02
Imprezanize is offline   Reply With Quote
Old 09-24-2005, 04:24 AM   #2
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
Front left, Rear Right
Then Front Right, Rear Left
Same on all the 4 Cyl Boxers
I think that translates to 1-3, 2-4
Old 09-26-2005, 03:56 AM   #3
EcksJay
Member#: 77677
1997 OBS
'07 KLR 650
correct, and FYI, detonation is a bad thing. You mean ignition.
EcksJay is offline   Reply With Quote
Old 09-26-2005, 04:35 AM   #4
specialev
Member#: 90156
1986 Syncro Vanaru
07 SV650
The front is the part that is towards you and from this perspective layout is :
Passenger side seat------------------------------Driver side seat
3---4
1---2
------------Front of car----------
specialev is offline   Reply With Quote
Old 09-26-2005, 01:18 PM   #5
Master2192
Member#: 83254
98 2.5 RS
04 WRX
That animation from Howstuffworks.com is alittle misleading specialev
From Cars101.com http://www.cars101.com/subaru/imprez...tml#mechanical
Firing order 1-3-2-4
And also from another site.
http://autorepair.about.com/library/...bl-fo-0492.htm
I could have sworn that it did not fire two pistons on the same side at the same time though. Seems unbalanced to me somehow.
Old 09-26-2005, 01:59 PM   #6
Hayes
Member#: 11808
Two pistons do not fire on the same side at the same time. Remember this is a four cycle engine so each piston only fires on each second crankshaft revolution.
Hayes is offline   Reply With Quote
Old 09-27-2005, 03:38 AM   #7
Imprezanize
Member#: 45273
2002 Impreza 2.5 RS
thank you guys
SOHC HEAD torque sequence DJIMPREZA Normally Aspirated with bolt-on Forced Induction Powertrain 5 09-20-2002 10:54 PM
up pipe torque sequence? Danny Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 09-15-2002 01:08 AM
What is the sequence? nekard Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 09-14-2002 12:48 PM
retiring ! my fave RS sequence patr Vancouver Impreza Club Forum -- VIC 6 05-14-2001 03:22 PM
Correct Brake Bleed Sequence awu Brakes, Steering & Suspension 4 10-28-2000 08:39 PM
