Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 09-24-2005, 12:58 PM   #1
Thomas Allen
Member#: 96848
2001 Outback LTD
Seamist
Default valve adjustment on 2.5 Series 2 Outback
Greetings all,
How hard is it to adjust the valves on a 2.5 Series II? Are they the same design with shims as the Series I? The dealer did a head gasket courtesy of Subaru, but one of the valves is tapping when when the engine is warm. It's not bad-bad, but all the others are quiet. The dealer is recommending just leave it alone until the 105,000 mark and hit it then.
Also, this thing has a hesitation when it's cold and you step on the gas from a dead start, almost like the TPS is lagging behind the throttle plate and the fuel trim is trying to catch up (probably an inaccurate disgnosis, but...). Other than some slight surging at highway driving in 4th with the converter locked, it feels OK. Any ideas?
TA
Thomas Allen is offline   Reply With Quote
Old 08-04-2011, 06:49 PM   #2
cky211
Member#: 31129
02 WRX MPB
No TGV + lots of P&P
for a 99 Outback with 2.5 DOHC
valve clearance is this what it should be set to?
.008" Intake
.010" Exhaust
cky211 is offline   Reply With Quote
Old 08-04-2011, 09:46 PM   #3
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
Intake valve: 0.0079 +/- .0008"
Exhaust valve: 0.0098 +/- .0008"
Clearance between shaft and rocker arm: .0008-.0021" standard with a limit of .0039"
CosmoTheCat is offline   Reply With Quote
Old 09-06-2011, 02:16 PM   #4
Columbo
Member#: 17328
2002 WRX Wagon 4EAT
Appliance White
You don't say how far away from 105,000 miles you are. The noisy valve is not a good thing...don't let it go.
If all were quiet before they did the work, they messed up somewhere and should make good on it for free. Naturally they want you to wait, so you can pay for it. :/
Columbo is offline   Reply With Quote
valve adjustment on 2.5 sohc wong-wing Normally Aspirated Powertrain 15 09-18-2014 11:32 PM
Valve adjustment on a 1.8? cfvwtuner Normally Aspirated Powertrain 2 01-04-2011 07:44 PM
Valve adjustment on 05 2.5RS wagon Saabarubi Normally Aspirated Powertrain 6 01-27-2010 09:40 AM
trip back from the dealer...valve adjustment on Subaru's? who's had it done? shukes24 Mid West Subaru Owners Club Forum -- MWSOC 9 12-29-2004 03:42 PM
Why isn't valve adjustment on the maintenance schedule? Dale_K Newbies & FAQs 2 09-01-2004 11:04 PM
