Old 08-23-2001, 04:20 PM   #1
SUBYRS710
Member#: 5186
2000 2.5 RS Coupe
Silverthorn
Default can borla headers be used with Ludespeed kit?
Hey everybody, just wondering...would the BORLA gen.lll headers be able to be used with a LUDESPEED stage 2 kit??! Thanks in advance,
Tim
SUBYRS710 is offline   Reply With Quote
Old 08-23-2001, 04:20 PM   #2
Jewbaru
Member#: 1994
2013 Impreza WRX
yes, if the stock header bolts up, the borla should bolt up fine.
Jewbaru is offline   Reply With Quote
Old 08-23-2001, 05:15 PM   #3
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
Ludespeed kits bolt to the stock header, so it should.
Midwayman is offline   Reply With Quote
Old 08-23-2001, 05:46 PM   #4
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
But you have to take into consideration that the stock header is even more of a equal-length solution then the Borla one, so you could get odd results with the Borlas.
Also, I've heard that thicker runners on the exhaust manifold will cause the turbo to spool up more slowly.
Old 08-23-2001, 06:01 PM   #5
kaos200
Member#: 2692
yeah I wouldnt run the borlas on a turbo setup (or at all for that matter) Ive seen them break with the stress of the turbos on them (and without )
kaos200 is offline   Reply With Quote
Old 08-23-2001, 09:15 PM   #6
kaos200
Member#: 2692
haha my friend just told me he installed the Borlas on his RS-T and likes them (gen 3), more spool up and topend to boot!? Well proven wrong I guess.
Old 08-24-2001, 01:17 AM   #7
NickSTi
Member#: 626
2001 Impreza 2.5 RS
Black Diamond Pearl
Wink
yip i gotta chime in everytime this comes up.
we all agree borla headers are better than stock right? are less restrictive right? are good for some hp gain right?
so lets add things up... less restrictive on the exhaust side. hey that must be good for the turbo... quicker spool less backpressure.
i do agree that the welds are of question. some people believe they may not hold up the extra weight. mine hold up fine and i have the questionable gen IIs
NickSTi is offline   Reply With Quote
Old 08-24-2001, 04:54 PM   #8
Joe Hogan
Member#: 699
2002 golf TDI
Koa,
Is there specific evidence of better spool, data logs etc. on your friends car with the Borla Header? Not that I doubt the findings.
It was put to me that larger pipe diameter = less gas velocity = less boost at lower RPMs
Better power at top end makes some sense.
Joe
Joe Hogan is offline   Reply With Quote
Old 08-24-2001, 05:27 PM   #9
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Joe,
There's a problem with that though. You're forcing a whole bunch of air into the combustion chamber so where does it go?
One would think that there's some increased exhaust flow, at least to the limits of the cylinder head...
Increased exhaust flow could mean that the smaller plumbing is compromising velocity. Velocity depends on the pipe diameter, length, shape and volume of gas you're trying to push through it.
ColinL is offline   Reply With Quote
Old 08-31-2001, 07:04 PM   #10
Impreza Rider
Member#: 756
2003 Legacy L wagon
2009 Kawasaki C14
Sorry to resurrect an old thread, but did we ever decide if the Borla headers and a turbo were a good combo? I'm just wondering.
Impreza Rider is offline   Reply With Quote
Old 08-31-2001, 08:19 PM   #11
NickSTi
Member#: 626
2001 Impreza 2.5 RS
Black Diamond Pearl
Wink
well there is no agreement as to whether they are great for a turbo app but this is where i think it stands:
1. I think the best option is the legacy turbo headers and the crossmember. but that can be expensive unless you get a good junkyard to raid.
2. I think the worst option is stock.
3. I think the middle option is the Borlas.
ymmv
Old 09-01-2001, 01:08 AM   #12
Impreza Rider
Member#: 756
2003 Legacy L wagon
2009 Kawasaki C14
Thanks...I'm trying to decide what to blow the$450 I'm going to have left over on
Old 09-01-2001, 01:10 AM   #13
Andrew
Member#: 1170
2005 STi
the money can be better spent on other mods.
Andrew is offline   Reply With Quote
Old 09-01-2001, 01:22 AM   #14
Impreza Rider
Member#: 756
2003 Legacy L wagon
2009 Kawasaki C14
Yeah, money can always be spent on something else. The only other thing I was considering was a brake upgrade, since I'm afraid that the turbo is going to overwhelm the stock (besides SS lines) brakes.
Old 09-01-2001, 01:41 AM   #15
Andrew
Member#: 1170
2005 STi
make sure you have some form of engine management. i would suggest getting a J&S.
What size of injector to be used with SMC kit ninjaboy76 Water/Methanol Injection, Nitrous & Intercooler Cooling 0 07-05-2006 11:56 PM
What mods can I perform NOW, that can be used with a 2.5T swap down the road? aliengti Normally Aspirated with bolt-on Forced Induction Powertrain 10 01-07-2004 09:02 PM
Can a UTEC be used with intake and FMIC ? blitz01 Engine Management & Tuning 6 02-19-2003 01:52 PM
Any 98RS-T with LudeSPEED kit? Photo requested! TIA bensonwrx Normally Aspirated with bolt-on Forced Induction Powertrain 9 07-03-2002 11:06 PM
Can the Unichip be used with the GC8 2.5RS? Brood Normally Aspirated with bolt-on Forced Induction Powertrain 21 04-03-2002 05:40 PM
