Old 09-25-2005, 01:04 AM   #1
WRXRallyBlue
Member#: 48831
2002 Protuned Wagon
Bugeyes Forever
Default Aftermarket Intake Manifolds
What intake manifolds do you guys have and how do you like them? I haven't seen many options in this area. Do any major manufacturers have an aftermarket option available?
Any input if appreciated.
WRXRallyBlue is offline   Reply With Quote
Old 09-25-2005, 06:07 AM   #2
SJwrx
Member#: 14970
1997 GF8
multi
nobody really makes an alternative, except for Subaru I bealieve (but those are hard to come by). The intake manifold that was 'on' the '02 WRC car is available but good luck finding it, Ive been seraching for years. Intake tracks are one of our least concerns... its reall the exhaust, turbo and engine managment that you have to do first.
Rich
SJwrx is offline   Reply With Quote
Old 09-25-2005, 06:26 AM   #3
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Magnus and Tomei make them. When you find out the price though, get some tissues as your nose will be bleeding. Aside from that, a new intake should be FAR down your wish list. Things that would come first would be a built motor and new gears/gearbox.
Old 09-26-2005, 08:34 PM   #4
SJwrx
Member#: 14970
1997 GF8
multi
Do they really, NEVER heard/seen that before. TO the bat-mobile!
Rich
Old 09-26-2005, 09:00 PM   #5
vipernj
Member#: 86854
2004 fx35 02 Z06
Beryllium, Millenium Yell
magnus makes a sheet metal manifold for $1200... looks cool and it probably helps but way too much money...
vipernj is offline   Reply With Quote
Old 09-26-2005, 10:43 PM   #6
InfamousDX
Member#: 25413
Damn $1200... I was look for one but damn... was hoping it'd be at least under a grand.
Old 09-26-2005, 10:53 PM   #7
The_Black_WRX
Member#: 70964
99RS 04 wrx
07 wrx limited wagon
have your stock manifold extrude honed and the have it port macthed to your heads
Steve
The_Black_WRX is offline   Reply With Quote
Old 09-26-2005, 10:59 PM   #8
vipernj
Member#: 86854
2004 fx35 02 Z06
Steve
definetly smarter and cheaper..altough, if you have the money then go for the magnus... go to their website, they look sick
Old 09-26-2005, 11:15 PM   #9
The_Black_WRX
Member#: 70964
99RS 04 wrx
i agree with you on that they look killer
when the are all nice and shiny
one downside to having port matched is you can only use it for thoes heads
steve
Old 09-27-2005, 01:43 AM   #10
nate49509
Member#: 22452
2016 WRX
Magnus
nate49509 is offline   Reply With Quote
Old 09-27-2005, 09:45 AM   #11
InfamousDX
Member#: 25413
You guys think they look killer but I have seen a previous gen Magnus that looked like ****. The welds are some of lesser quality ones I've seen (LOOKS wise). Oh and I've also heard of one that had to be spot welded because ti was leaking.. but hopefully their quality control has increased.
Old 09-27-2005, 11:14 AM   #12
Samurai Jack
Member#: 21145
2002 Enemy of Aku
steve
Do you mean port match the intake or gasket match the intake? If you mean gasket match, the heads won't really matter, as long as you are using the same type heads, ie; stock, because you aren't making the manifold port opening any larger than the gasket itself and the head ports are unchanged.
It looks like he is only talking about the intake and not the heads.
Now, if you start getting into reshaping the head ports, that is something different.
Samurai Jack is offline   Reply With Quote
Old 09-27-2005, 11:41 AM   #13
NattiRex
Member#: 96738
96 Talon
He is talking about porting the IM to match the heads, once the IM has been modified the chances of it mathcing up to another set of heads is slim to none... P&P or extrude hone would be my choice... just my .02
NattiRex is offline   Reply With Quote
Old 09-27-2005, 01:07 PM   #14
vipernj
Member#: 86854
2004 fx35 02 Z06
Originally Posted by nate49509
Magnus
ewwwww, Blitz Dual Drive BOV, the LEAK MASTER
Old 09-27-2005, 10:25 PM   #15
The_Black_WRX
Member#: 70964
99RS 04 wrx
the reason you port match is that the stock heads and stock intake manifold dont match up perfectly when you have the port matched they use the gasket as a template and take out the same amount of matieral and that smoothes the air flow transition from the intake manifold to the heads removing any turblance that is created from the intake manifold and the heads not matching
Steve
Old 09-27-2005, 10:46 PM   #16
The_Black_WRX
Member#: 70964
99RS 04 wrx
here is some good info i found on port matching
Air flow makes horsepower. The more cubic feet per minute (cfm) of air that flows through the intake ports and into the combustion chambers, the more horsepower the engine makes.
To realize the utmost performance potential from a given combination of cubic inches and mechanical modifications, you also have to optimize the ports in the cylinder heads and match the ports to the runners in the intake manifold.
There are two ways to port and match cylinder heads: The right way and the wrong way. The right way is to refine the flow characteristics of the head and manifold so as much air as possible enters the cylinders at the engine’s peak power curve. Every engine is different so there’s no "standard" port configuration that is guaranteed to deliver maximum air flow on every application. The port profile that works best will be limited by the physical dimensions of the cylinder head.
Limiting factors include the size, position and angle of the stock ports; the size, configuration and angle of the valves; the thickness of the casting around the ports; and the location of the water jackets, head bolts and other valvetrain components. But other factors must be taken into account, too, such as engine displacement (big block versus small block), the engine’s bore and stroke, the shape of the combustion chambers, compression ratio, the depth and angles on the valve seats, total valve lift, camshaft profile (duration, overlap, etc.), and type of intake manifold and induction system.
Porting can unleash hidden horsepower by increasing air flow - but it requires know-how, a flow bench and special tools to successfully pull it off.
Opening Up
One of the basic goals of head porting is to minimize obstructions so air can flow relatively unimpeded from the throttle plate to the valves. Two things that get in the way are the valve guides and valve guide bosses. Cutting down the length of the valve guide stem and narrowing the valve guide boss can improve air flow past these obstacles. So too can using smaller diameter valve stems or valves that are necked down just above the valve head.
Bolt bosses that protrude into ports also create bumps in the ports that disrupt air flow. Grinding these flush with the surrounding port surface can also smooth out the route, provided you don’t run out of metal and grind all the way through the boss or dangerously weaken the head.
Transition areas in the port also need to be reworked so air will flow more easily around corners with a sharp radius and into the seat throat just above the valves. Sharp edges and rough castings also need to be smoothed and blended to eliminate turbulence and improve air flow.
The cross-sectional area of most intake ports becomes gradually smaller as the air moves toward the valve. This causes the air to accelerate as it approaches the valve, and actually helps ram more air past the valve into the cylinder when the valve opens. Any sudden changes in the cross-section of the port can disrupt this effect and restrict air flow. That’s why port modifications that are made in the area just above the valve must not upset the normal increase in air velocity. The same goes for the exhaust side, too, except here the cross-section of the ports gets larger as the exhaust gases flow away from the valves. Again, the secret to maximizing flow is to have a smooth transition and as few obstructions as possible.
The joint where the intake manifold and cylinder head meet also is a critical area. If the runners in the intake manifold are not perfectly aligned with the ports in the head, sharp edges can interrupt normal air flow and impair performance. Matching up the ports so there’s a smooth transition from manifold to head will ensure maximum air flow. The same goes for exhaust ports. The head ports must be aligned with the header openings so the exhaust gases can pass freely out of the engine without encountering any sharp edges or obstacles.
Bigger is not always better. Grind away too much metal and you may end up ruining the casting if you cut into a water jacket. But even if you don’t grind all the way through, removing metal in the wrong places can actually end up hurting air flow more than it helps. Here’s why: The secret to maximizing air flow and engine performance is maximizing volumetric efficiency and air flow velocity.
Big ports with lots of volume will obviously flow more air than a smaller port with less volume - but only at higher rpm. A lot of people don’t know that. At lower rpm and mid-range, a smaller port actually flows more efficiently and delivers better torque and performance because the air moves through the port at higher speed. This helps push more air and fuel into the cylinder every time the valve opens. At higher rpm, the momentum of the air helps ram in more air, so a larger port can flow more air when the engine needs it.
The ultimate port would actually be one with a variable cross-section that’s small at low rpm for high air flow velocity and gradually opens up for more air flow as engine speed increases. That’s sort of the idea behind staged split-plenum intake manifolds that open up and feed more air into the engine at higher rpm.
The bottom line is this: To realize the most power and performance out of an engine, air flow has to match the breathing requirements of the engine within the engine’s rpm range where it is designed to make the most power.
Therefore, when choosing either an OEM cylinder head or an aftermarket head, you should try to match the port size with the engine’s power curve and rpm range. Don’t waste your money bolting a set of high-flow heads onto an engine that can never realize the head’s full performance potential because of limitations in gearing, the valvetrain, cam specifications or carburetion. Likewise, if you’re going all out, then start with the highest flowing heads you can find and try to add even more cfm potential by massaging the ports and manifold.
As a rule, the roof of an intake or exhaust port has much more influence on air flow than the floor or sides of the port. The greatest gains in air flow can often be realized by removing metal from the top of the port only and leaving the sides and floor relatively untouched. This can have the same effect as using a different head casting or an aftermarket head that has the ports relocated slightly higher to give a straighter shot at the valves.
Additional gains in air flow can often be found by carefully smoothing and blending the short-side radius in the port floor where the port bends toward the valve seat. This helps air round the corner more easily for improved air flow.
In the area where the intake manifold and head are bolted together, using a template to scribe alignment marks on the head and manifold can serve as a guide for hand grinding and smoothing this area.
Though the greatest gains in horsepower will be realized only when heads are flow tested and professionally ported, do-it-yourselfers who are racing on a limited budget can still do some basic porting themselves to improve air flow and increase the performance potential of their engines.
The technical staff at Standard Abrasives (www.sa-motorsports.com) have an online DIY Cylinder Head Porting Guide complete with photos that provides detailed step-by-step instructions for head porting and manifold matching.
All you need are a basic porting kit (which includes various grinding stones and abrasive rolls), some common tools and some free time.
A basic DIY port job should focus on reducing restrictions caused by steps that may obstruct intake air flow as it transitions from the intake manifold to a smaller intake port entry in the head. These restrictions could be casting bumps, ridges or other marks, such as those on port floors or roofs, sharp edges, such as those around the valve guide bosses at the top of the valve pockets, and the area where the intake port floor curves down to the valve seat.
The job itself consists of six steps:
1. Enlarging and matching the intake port entrances;
2. Smoothing the intake short-side radii, valve guides and valve pockets;
3. Smoothing the exhaust short-side radii, valve guides and bowls;
4. Polishing the exhaust ports and bowls;
5. Polishing the combustion chambers (to reduce carbon buildup); and
6. Matching the intake manifold ports to the head.
Some porting suggestions offered by Standard Abrasives include:
• Use an air-powered die grinder with a maximum speed of 18,000 to 20,000 rpm and a 1/4" collet. An electric die grinder is OK, but you have to be careful to limit the grinder’s speed.
• Wear proper eye protection. Grinding throws off a lot of chips, and you don’t want any debris to end up in your eyes. Good lighting is also essential so you can see what you’re doing, and gloves are recommended to protect your hands.
• To keep grinding stones from clogging when working on aluminum heads, lubricate the stones with WD-40.
• To figure out how much metal needs to be removed to match up the ports, apply machinists bluing to the gasket template and bolt the template to the head and manifold. Then scribe the outline of the port opening on both the head and manifold. Remove all metal inside the scribed lines.
• When you start grinding, use a rotary round grinding stone for maximum metal removal. As you approach the scribe marks you’ve made, blend or feather the larger port into the remaining port by progressively removing less material as you move farther down into the port. In most cases, you want to grind about 1" to 1.5" into the port.
• Once the port has been ground to size, switch to a smaller diameter conical rotary stone to profile the small radii at the corners of each port.
• To finish the port, use the tapered rolls of abrasive, starting with 40 grit, then 80 grit.
• The point where the intake port floor curves down to the valve seat is known as the "short-side radius." From an air flow standpoint, this area is the most critical in any port. Smooth that spot and you can usually realize a significant increase in flow through the port. On most production heads, the short-side radius will be sharp-edged and rough. The goal here is to soften those sharp edges and smooth out the roughness.
• Bowl work includes blending the area under the valve seat. The valve throat, which is the smallest diameter in the valve pocket just above the valve seat, should be about 85% of the valve diameter. If the throat is smaller than that, use a combination of the rotary stone and cartridge rolls to open it up to the 85% figure.
• Exhaust ports flow best with a polished finish. A smooth finish also helps reduce the buildup of carbon deposits. Use a 120-grit or finer flap wheel after using the 40-grit and 80-grit abrasives, then polish with the medium Cross Buff and finally the fine grade Cross Buff.
• In most cases, you should not attempt to match the exhaust ports in the head with the ports in the exhaust manifold or headers. Many stock exhaust manifolds, and virtually all tube headers, have larger port sizes than the heads. You want that "step" from the port to the larger header tube or exhaust manifold because, as pressure pulses flow back and forth in the exhaust system, it acts as a "reversion dam" by resisting back flow of exhaust gases into the port.
Hope this info helps all of those not familier with port matching
Steve
Note:all information taken from
The Science of Horsepower: Porting & Matching Heads & Manifolds, Larry Carley, Underhood Service, November 2001
Old 09-27-2005, 11:05 PM   #17
D-Speed 2.5
Member#: 29516
2005 WRX Wagon
Former GC O.G.
Magnus
This is such a sick setup. My buddy has that same rotated HKS kit but with a FMIC. That manifold is awesome.
D-Speed 2.5 is offline   Reply With Quote
Old 09-28-2005, 11:05 PM   #18
WRXRallyBlue
Member#: 48831
2002 Protuned Wagon
Bugeyes Forever
Steve
Lots of useful info, thanks.
Old 09-28-2005, 11:06 PM   #19
WRXRallyBlue
Member#: 48831
2002 Protuned Wagon
Bugeyes Forever
Does anyone know the difference between the manifold on a WRX versus an STi? Or do they just paint them red?
Old 09-29-2005, 05:26 AM   #20
senortighto
Member#: 51873
2006 purty blue STi
in my driveway
yup, just red
senortighto is offline   Reply With Quote
Old 09-29-2005, 12:23 PM   #21
StealthWRX
Member#: 50175
2 Bugeyes
'11LGT '16FXT
the tomei manifold is so hot, does anyone knwo if you can actually buy it? and where?
StealthWRX is offline   Reply With Quote
Old 09-29-2005, 12:45 PM   #22
dentsport
Member#: 71201
Shop Sport Service
781-551-3399
This is the intake manifold that we came up with on the shop WRX. Here is a picture and a brief description to follow. Please feel free to enquire with any questions you may have.
The intake manifold started as a method to move the throttle body to the front of the car from the back. Now, with the forward facing style of the new manifold and the relocated alternator we can shorten the intake path to only about 3 feet of length from the the usual 6 or so that a Subaru with a front mount intercooler usually makes due with. The manifold is 6061alu with spun air horns sourced from Australia. We sell these horns seperately if you're looking for something similar. The throttle body flange is an in house item, 6061alu CNC machined to accept the Infinity Q45 TB. The new throttle body is 3.25 ID and runs a typical 5v TPS. The plenum volume is over 4 liters on our manifold.
Louis
dentsport is offline   Reply With Quote
Old 09-29-2005, 01:20 PM   #23
StealthWRX
Member#: 50175
2 Bugeyes
'11LGT '16FXT
make me one
Old 10-03-2005, 06:32 PM   #24
WRXRallyBlue
Member#: 48831
2002 Protuned Wagon
Bugeyes Forever
dentsport, that is a pretty sweet setup. Is that something you could mass produce?
Old 10-03-2005, 06:37 PM   #25
NattiRex
Member#: 96738
96 Talon
Sure is pretty! Sand that down and powdercoat it!
aftermarket intake manifold tonzo Built Motor Discussion 904 05-28-2015 02:20 PM
WTB: Polished or Aftermarket intake manifold midnightsti Private 'Wanted' Classifieds 4 06-13-2006 06:39 PM
Aftermarket intake manifold west005 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 18 05-30-2006 09:03 PM
New/Aftermarket Intake manifold Twelvz Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 29 03-11-2005 12:32 PM
New Aftermarket Intake Manifold DonkeyPunch Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 01-15-2005 06:15 PM
