Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2016
Old 09-25-2005, 04:51 AM   #1
Hossamk
Member#: 95718
Default Compression Ratio in the Normally Aspirated
Dear All
the air pressure over the sea is 14.7 PSI or 1 bar. in a normally aspirated engine with a compression ratio of 10:1 does this mean that the engine is running on .1 bar or 1.4 PSI is this true?
if this is true, what kind of boost i can run on this engine with the internal cylinders and heads unchanged and with fuel octane 92? i read that using turbo compresses more are in the cylinder which heats it more and the fuel can burn before the Sparks works and the engine will be knocking?
Hossamk is offline   Reply With Quote
Old 09-25-2005, 05:54 AM   #2
Jesse00
Member#: 78036
02 Impreza 2.5TS
Midnight Blue
first of all, you might want to goto the forced induction forum instead. this is a Natural Aspirate, not the turbocharging forum you wanted. And the maximum safe level you can put into the ej25 engine is around 6psi. However, I remembered someone that put 9psi into theirs, but i think he put alot of money into making it happen. In short, dont turbocharge your 2.5rs, isnt worth the money you spend on it.
If you have a 2.2t engine, then disregard my post (but then again, your in the wrong forum)
Jesse00 is offline   Reply With Quote
Old 09-25-2005, 07:17 AM   #3
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Ummm, no. Those piston things going up and down inside the engine (well, actually back and forth in our engines) compress the air. That's why it's called "compression ratio". So the 14.7psia is compressed to 147psi in a 10:1 engine. Depending on cam timing, the dynamic CR may be higher, so you may see more than 147psi during a compression test.
http://auto.howstuffworks.com/
Pat Olsen
Old 09-25-2005, 12:14 PM   #4
Hayes
Member#: 11808
Any compression ratio is a STATIC measurement of the combustion chamber. The ratio running is can be lower or higher due to intake and exhaust valve overlap and pumping losses in the intake and exhause system. .
Hayes is offline   Reply With Quote
Old 07-06-2008, 04:21 PM   #5
Suby2.5i
Member#: 176032
2007 Impreza 2.5i-T
SGM
dont turbo charge your rs's
Suby2.5i is offline   Reply With Quote
Old 07-06-2008, 05:25 PM   #6
Subyroo2.5
Member#: 168129
2013 WRX
WRBP
YEAH SAVE IT FOR THE 2.5I LOL
Subyroo2.5 is offline   Reply With Quote
Old 07-06-2008, 08:25 PM   #7
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Thank goodness we bumped a 33-month-old thread for that bit of random advice that had nothing to do with the subject of this thread.
Old 07-06-2008, 09:02 PM   #8
rougeben83
Member#: 115154
2005 Outback XT
White on grey
rougeben83 is offline   Reply With Quote
FS: Normally Aspirated (NON-Turbo) JDM header setup, only one in the country!!! Kostamojen Engine/Power/Exhaust 7 10-17-2008 04:24 PM
anyone know off the top of their head the compression ratio on the wrx?? JDIS213 North West Impreza Club Forum -- NWIC 2 11-08-2006 10:41 PM
What is the stock compression ratio for the 99-01 RS? WRC1 Normally Aspirated Powertrain 7 06-08-2004 07:27 PM
Gear Ratios in the Baja-T? 02_Forester Baja Forum 1 01-05-2004 09:08 AM
What is the correct compression ratio for the WRX myko011 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 09-12-2001 05:57 PM
