Old 09-25-2005, 11:56 AM   #1
Nicklbrso
Member#: 44887
00 GC6
Default HID kit problems
So it all started out a few months after I bought my 2000 RS last august. The previous owner had installed a retrofit kit from a Lexus GS300 into my RS. The light output was awesome but every now and then the drivers side lamp would go out. It would soon come back on again another time. This happened every once in a while until last week when it went out and has not come back on since. I switched bulbs and both still work. I also swapped ballasts from the drivers side to the passenger side and both still work. Somewhere along the line there is a loose connection. I cannot see it anywhere. If I cant figure out the problem I will probably just sell this kit and someone with more knowledge about electrical work can figure it out. here are some pics of the kit.
Any ideas? Thanx
Nicklbrso is offline   Reply With Quote
Old 09-25-2005, 02:59 PM   #2
BlueWRXagon
Member#: 18048
2002 Impreza Wagon
You could try wiggling some of the wires around and seeing if that will make the light come on...next step maybe check fuses and relays, and perhaps swap the harnesses so you can pinpoint whether those are the problematic areas...thats all I can think of...
Good luck.
BlueWRXagon is offline   Reply With Quote
Old 09-25-2005, 03:50 PM   #3
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
it's the wiring. best to use connectors and not solder no matter what you read. it's one of the 2 wires going to the balist having a problem.
Old 09-26-2005, 08:21 PM   #4
dubluv17
Member#: 26298
MBP
go get a bosch relay and wire it up following the diagram on this thread (http://forums.nasioc.com/forums/show...ness+schematic) the same thing happened to me and i ended up selling my ballast cuz i thought it was bad but it was just the wiring...i'm not saying that this is for sure what it is, but those are the same things that were happening to me...what happens is the factory wiring isn't setup for hids, so it's too small of a gauge...anyways, try that and see if it works
Brooks
dubluv17 is offline   Reply With Quote
Lowest Price on HID Kits available! Starting at $60.00! Apollo Performance Exterior/Styling 30 10-26-2010 10:41 AM
McCullough HID Kit Problems photog72 Electrical & Lighting 9 07-16-2004 04:32 PM
HID Kit Install Problem Uncle Ben Electrical & Lighting 3 09-24-2003 06:11 PM
Problem installing HID kit fuzzy logik Electrical & Lighting 7 07-27-2003 01:08 PM
HID kit installation problem nor1212 Interior & Exterior Modification 21 10-29-2001 02:46 AM
