#1 |
Member#: 90248
NESIC
I am boosting my car next summer, but until then, what mods should i do to my engine (bolts on and internal work) to prepare for the turbo? Also, aftermarket cams are fine for my engine after its boosted, correct?
#2 |
Member#: 90396
NWIC
Vehicle:2005 Legacy 2.5i Brilliant Silver Metallic |
Don't screw around with cams, just do an STI shortblock for boost ^^.
Nice exhaust setup would be main thing for turbo... Then a lightweight crank pully and... well might as well start upgrading your clutch/tranny before you snap em with your turbo. Good Luck! Nick |
#3 |
Member#: 5692
Vehicle:WTF? YES! I am better than you! |
Be careful with cams. You'll need turbo specific grinds. (Less overlap)
#4 |
Member#: 43114
Vehicle:1998 Legacy GT Turbo Green |
You can run boost on stock internals, but the better the engine is prepped
beforehand, the less likely you will have a surprise breakdown that'll leave you without a car for a while. If your car has not had it's headgaskets replaced during its lifetime, I highly suggest replacing them. Same goes for the timing belt: if it hasn't been replaced in a long time, now's the time. A 2.5" exhaust, in my opinion, would be very important on this engine. I would not personally do anything cam-related to the DOHC engine, unless you really plan on building a race engine. Once the turbo is on, there are countless things you can do to add further power besides cams. A cam switch on this particular engine is very involved and time-consuming. The one thing that I could also recommend is a set of forged pistons. 8.5:1 or 9:1 would seriously improve the durability of your engine. I highly recommend some form of fuel controller. You will definitely want to adjust your fuel once the turbo is on, and there is a lot of power waiting to be made by doing so. The possibilities for power-gains are endless once the turbo is on. $2 or $3 can sometimes add as much as 10 hp, where on an NA engine, it took $500+ to get those gains. |
#5 |
Member#: 90248
NESIC
thx leondal!
yeah when she gets boosted i'm gonna be running a greddy e-manage, so that takes care of my fuel. |
#6 |
Member#: 81067
NWIC
Vehicle:1989 RX, FX16 both white |
it might not be in your greatest interest to build your car for low compression and drive it around without the turbo. I would suggest putting in all the low compression pieces right before you do the turbo installation. On my car, i unhooked the turbo and drove it around just to see what it is like, and it made about 50 hp
. Maybe you should look into a megasquirt as well, thats what i'm saving up for. |
#7 | |
Member#: 90248
NESIC
| Thread Tools | |
| Display Modes | |
| What is the life expectancy of the factory turbo on the WRX? | Moshpit552 | Factory 2.0L Turbo Powertrain | 2 | 08-30-2004 08:10 AM |
| New turbo on the way, anyone wanna make me a deal on a TMIC and injectors? | Big_Hitter | Texas Impreza Club Forum -- TXIC | 1 | 03-08-2004 03:32 PM |
| How come Subaru puts the Turbo on the.... | SubaruImpreza_power | Newbies & FAQs | 29 | 11-18-2002 07:24 PM |
| What Is The Size Of The Turbo On The 2002 WRX? | Uthinkso | Factory 2.0L Turbo Powertrain | 4 | 11-26-2001 08:15 AM |
| Hi, question about the turbo on the wrx... | kwakman | Newbies & FAQs | 8 | 09-01-2001 11:06 AM |
