Old 09-26-2005, 02:18 AM   #1
vipernj
Member#: 86854
2004 fx35 02 Z06
Beryllium, Millenium Yell
Default Autometer EGT question, cant find the one with the probe!
I did a couple searches and found some good info on other gauge compnaies, but I already have autometer...so....I have boost and air/fuel autometers in the ProComp/Ultralite series in silver. As I keep modding my motor I need an EGT being that the air/fuel does nothing but annoy me. Anyone know which autometer egt to get that comes with the probe? Does the probe bolt in to the stock egt location on the uppipe? Thanks in advance...
P.S. the autometer site sux
vipernj is offline   Reply With Quote
Old 09-26-2005, 02:41 AM   #2
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
Aspen White / Silver
Its easy, your not reading there page, part #4344 comes with thermocoupler thats the probe, if your not sure go to Summit racing and put in the part number atm-4344 you can see it comes with everything you need.
Token-Negro is offline   Reply With Quote
Old 09-26-2005, 11:07 AM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
ya want the p/n 5249 probe.
Old 09-26-2005, 12:28 PM   #4
Samurai Jack
Member#: 21145
2002 Enemy of Aku
And you don't want to put it in the UP. You want to put it in the Driver's side exhaust manifold.
There is a little "button" on the side of the exhaust manifold. The manifold will have to be drilled & tapped for a 1/8" NPT so you can thread the probe in. Either you can do this yourself or you can get it done. Some dealers have done it. I just don't know if ALL dealers will do it.
Why the Driver's exhaust manifold and not the UP or DP? You will get a more accurate reading of your exhaust temps in the exhaust manifold, and the #4 piston seems to be the area of greatest concern for high temps/failure, if any.
Samurai Jack is offline   Reply With Quote
Old 09-26-2005, 09:05 PM   #5
vipernj
Member#: 86854
2004 fx35 02 Z06
i have an aftermarket exhaust manifold... its stainless steel... Im gonna tap it in when I get the probe. thanks a lot guys, you gave me everything i needed to know
Old 09-27-2005, 12:02 AM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
...if you mean a 'header'...then it is very likely too thin to 'tap' for an egt bung....you will need it welded on.
Old 09-27-2005, 12:12 AM   #7
vipernj
Member#: 86854
2004 fx35 02 Z06
thanks, thats even easier
Old 09-27-2005, 12:44 AM   #8
Soon2Bgreat
Member#: 2258
1999 gc8 ver7 6mt
GT35R 504.7whp;)
I believe you can also use the TeamRip probe. That is supposedly a very high quality unit and pretty cheap. I don't have a link sorry, but a search should get you what you need. Just figured i'd throw some other options out there. Good luck.
Louis
Soon2Bgreat is offline   Reply With Quote
Old 11-27-2005, 12:58 AM   #9
taerron
Member#: 75744
2k2 low boostin
evo3, for now....
heres some food for thought, i just got an autmeter egt and the instructions for tubro cars is to place the probe 1-2 inches for the turbo exhaust outlet. on the non turbo cars it states to place it 1-2 inches from the cylinder head. completely opposite of what i have been reading.
taerron is offline   Reply With Quote
Old 11-27-2005, 09:01 AM   #10
Uncle Scotty
Member#: 16200
OK buy Nates beans
...yeah...we know
....MOST turbo cars DON'T have the turbo at the end of several feet of exhaust like ours do.....the turbo is on the manifold...NO up-pipe....SOOOOOooooooooooooooooooo......got it???
Cant find that one thread davedavis1981 Brakes, Steering & Suspension 2 12-11-2007 07:24 AM
Which APS 3 inch turboback is the one with the 2.5 inch bottleneck or reduction garface Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 05-20-2005 08:17 AM
which BOV was the one with the lazer shot sound? KnightWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 11-07-2004 01:10 PM
Want to try new knock sensor - the one with the inline filter Back Road Runner Normally Aspirated Powertrain 13 10-02-2004 06:29 PM
so, i cant find good prices on the C-West Kit for my 01 Damon Interior & Exterior Modification 6 12-29-2001 02:46 AM
