Old 09-26-2005, 01:38 PM   #1
jasona
Member#: 11786
2014 OB 2.5i 6MT
Custom Dirt/Snow twotone
Default Sealant for Camshaft cap
Here's what I'm looking at in the service manual:
Do I just use any rendom gasket dressing or is there anything in particular I need to use?
Do I just squirt it down and fill the little channel for it?
jasona is offline   Reply With Quote
Old 09-26-2005, 03:16 PM   #2
SubyTechMaster
Member#: 4423
'04 08 Tribeca, SVX
Gold, Maroon
Subaru does not specify a suitable alternative to Fuji ThreeBond 1280B. It needs to be applied as described.
SubyTechMaster is offline   Reply With Quote
Old 09-26-2005, 04:16 PM   #3
jasona
Member#: 11786
2014 OB 2.5i 6MT
Well hell, the dealership is a 2 hour drive one way. I find it hard to believe there's nothing I can get from the local parts store that'll work.
Old 09-26-2005, 04:20 PM   #4
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
permatex makes some stuff called "the right stuff". It is damn good. I highly recommend it.
Tim Sanderson is offline   Reply With Quote
Old 11-30-2013, 09:13 AM   #5
V8 GTFO Lesbic WGN
Member#: 191212
2007 FXT-5MT E85 20G
TD06SL2 Kinugawa
Bump, which is better for this purpose?
  1. Permatex Right Stuff
  2. Permatex Ultra Grey
  3. 3M Ultrapro 08672
Service manual is confusing, it calls to use the same liquid gasket (Three Bond 1215) for the both the top and bottom mating cap surfaces, but the factory installed a black sealant for the head to cap side (bottom of cap), and a grey sealant for the cap to rocker side (top of cap).
Also, same question for oil separator plate on block, factory sealant is very rigid, looking for equivalent to 1217G.
V8 GTFO Lesbic WGN is offline   Reply With Quote
Old 11-30-2013, 11:41 AM   #6
Storm
Member#: 5218
96L Most Over-
Developed Beater
I use Ultra Grey for everything. No problems.....ever.
Jay
Storm is online now   Reply With Quote
Old 11-30-2013, 11:44 AM   #7
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
I also use ultra gray for everything.
Old 12-01-2013, 09:18 AM   #8
Elbert Bass
Member#: 283429
That is not entirely correct. Please refer to TSB 01-167-08R Recommended Materials (All Vehicles).
3M™ Ultrapro™ High Temp Silicone Gasket 08672 Black is a suitable alternative for ThreeBond 1280B as well as 1105, 1207C, 1215, 1217B, and 1217G.
Elbert Bass is offline   Reply With Quote
Old 12-01-2013, 10:17 AM   #9
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
^Thanks for posting, FYI TSB was issued on 2012, SubyTechMaster made that comment 7 years prior to the TSB being issued.
Wow, the 3M seems to be da good stuff, replacing all 6 OEM ThreeBond products.
Here is the TSB: http://www.bbbind.com/free_tsb.html, Input 2012 Impreza, Chemicals/Antifreeze/Additives.
Old 12-01-2013, 11:04 AM   #10
Elbert Bass
Member#: 283429
One of these days I will look at these post dates ;-)
The 3M does not give you the extra working time some of the FujiBonds do, but it does the job.
Old 12-01-2013, 11:27 AM   #11
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
How long working time approx? 5 minutes/10 minutes?
Does it come with a dispensing cone tip? Any tips to ensure even bead, uniform cross section? Icing/Marinate syringe dispenser maybe? Sealant dispenser?
Just bought at Amazon
Amazon.com: 3M 08672 Ultrapro Black High Temp Silicone Gasket Tube - 3 oz.: AutomotiveAmazon.com: 3M 08672 Ultrapro Black High Temp Silicone Gasket Tube - 3 oz.: Automotive
Old 12-01-2013, 12:15 PM   #12
Storm
Member#: 5218
96L Most Over-
Developed Beater
The Ultra Grey working time is approximately 10minutes, depending on room temperature and part temperature. The tubes come with a bead producing cap, though I've gotten into the habit of using my finger to make a thin film on the parts and minimize creeping when they are joined. I find it important particularly when doing internal motor work as blobs of sealant squeezed out from joints can break off and create problems with oiling.
Have fun,
Jay
Old 12-01-2013, 12:44 PM   #13
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
That's my concern, not enough coverage and you have a leak, too much and you get to buy a new engine. I hate liquid gaskets, wish everything had gaskets.
Old 12-01-2013, 03:35 PM   #14
Elbert Bass
Member#: 283429
+1 with Storm.The black is about the same. Squeeze the tube before you open it to see if it is mushy or hard. When I had to get some (rush warranty repair) our vendor sent 3 factory sealed tubes that had hardened on the shelf. Apparently not a great shelf life.
I have a steel butterfly handle that slides over the end of the tube you use to roll the tube up. Seems like I got it with a tube of Kia FIPG when I put a timing cover on a V6 for our body shop.
I use a caulk gun for ThreeBond products.
camshaft cap torque spec. PSolbergfan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 09-10-2008 08:50 PM
Camshaft cap bolt size (Torx) ghostme76 Normally Aspirated Powertrain 2 04-04-2008 09:44 AM
Camshaft cap that holds the oil seal cegpcola Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 03-06-2006 10:43 AM
Removing Camshaft Caps SOLUTION Normally Aspirated Powertrain 2 11-24-2005 11:15 PM
Camshaft cap torque specs? FSM discrepancy? jblaine Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 06-14-2005 10:01 PM
