Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Old 09-26-2005, 04:20 PM   #1
jasona
Member#: 11786
2014 OB 2.5i 6MT
Custom Dirt/Snow twotone
Default What parts do I need to grease?
I just got my cams back from Delta and I'm ready to reassemble the engine and put it back in the car. What parts should I grease and how much do I use?
jasona is offline   Reply With Quote
Old 09-26-2005, 04:22 PM   #2
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Rod,main,cam journals. And the cam lobes.
Tim Sanderson is offline   Reply With Quote
Old 09-26-2005, 04:37 PM   #3
John*G
Member#: 19562
95 coupe
red
I've always used STP as a assembly lube without any problems. Painted it on all the parts Tim described above.
John
John*G is offline   Reply With Quote
Old 09-26-2005, 05:42 PM   #4
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Make sure you change the oil and filter soon after the break-in though.
Old 09-26-2005, 06:06 PM   #5
jasona
Member#: 11786
2014 OB 2.5i 6MT
Originally Posted by Tim Sanderson
Rod,main,
Piston rods? I only have the top end off, the bottom end is still together. And what do you mean by main?
What do I need to do for break in?
Old 09-26-2005, 06:23 PM   #6
John*G
Member#: 19562
95 coupe
red
You only need to do the cams then.
John
Old 09-26-2005, 10:59 PM   #7
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
And for the love of god! Don't use regular grease! Use assembly lube/grease please.
Since it's just cams then you could also just use motor oil if you're going to start it up soon.
And, since it's just a cam install then there is'nt really a "break in" for the motor. You will need to re-lash the valves in about 200-250 miles though.
Do not jag up the valve lash adjustments.
I use a "go/no go" system. For instance: the spec is 8 thou. You would then use a 7, an 8, and a 9 thou. feeler. Adjust the lash to 8 thou. Now the 7 should fit no problem, but the 9 should not. And remember that as you tighten the jam nut you will most likely tighten the lash so leave the feeler in there while you tighten them. Then try the 7 and the 9.
7, 8, and 9 thousandths was an example. Check the service manual for the proper lash clearances for your particular motor.
Good luck.
Old 09-27-2005, 01:40 AM   #8
jasona
Member#: 11786
2014 OB 2.5i 6MT
Really? Pull the motor and everything again?
Why didn't I have to do that when I bought the car and "broke in" the original cams?
Old 09-27-2005, 04:15 PM   #9
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
No, you don't have to pull the motor. Just the valve covers.
Old 09-27-2005, 04:52 PM   #10
jasona
Member#: 11786
2014 OB 2.5i 6MT
Oh, I wouldn't imagine you'd have enough room to work in there with the motor in the car
Old 09-27-2005, 04:58 PM   #11
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
short 10mm wrench and a stubby screwdriver fits fine.
Old 09-27-2005, 05:58 PM   #12
cjfike
Member#: 60116
1999 RS Coupe
Silver Thorn
You may have to set some valves from under the car. I found that easier atleast.
cjfike is offline   Reply With Quote
What parts do I need to install a HU? PureTorque Car Audio, Video & Security 2 12-22-2007 03:21 PM
What parts do I need to replace OE clutch MF-DIF Transmission (AT/MT) & Driveline 1 10-13-2005 10:46 AM
What parts do I need to add a turbo? Acejam2k Legacy Forum 21 10-12-2003 07:11 AM
What parts do i need to add a turbo to my car? Acejam2k Normally Aspirated with bolt-on Forced Induction Powertrain 4 09-29-2003 12:25 AM
What parts do I need to hook up amp?? entropy111 Car Audio, Video & Security 1 10-01-2001 02:51 PM
