Old 09-26-2005, 10:21 PM   #1
oldbluwrx
Member#: 61677
02 wrx
blue
Default big probs after nitrous backfire.
I have a water prob it is takeing water on where could it be going? it is definentlyburning water but the head gaskets seem to be fine. the intake manifold is full of water oil mix all the way down to the intercooler. Can anyone explain this?
oldbluwrx is offline   Reply With Quote
Old 09-26-2005, 11:22 PM   #2
prescottsti
Member#: 84902
04 Chevy Silverado
Duramax Diesel 500Hp
nitrous is badd ummkay
prescottsti is offline   Reply With Quote
Old 09-26-2005, 11:34 PM   #3
west005
Member#: 65684
1993 JDM Soarer TT
White on golds
possibly turbo seal. I like Nitrous too!
west005 is offline   Reply With Quote
Old 09-26-2005, 11:41 PM   #4
Blackboxracing
Member#: 90106
usually its a really bad idea to run alot of nitrous if you are not tuned well enough for it as so not to detonate. I would say try to find a good tuner before next time you spray
Blackboxracing is offline   Reply With Quote
Old 09-27-2005, 01:03 AM   #5
Soon2Bgreat
Member#: 2258
1999 gc8 ver7 6mt
GT35R 504.7whp;)
Is it burning smoke out of the exhaust?
I'd check oil levels, pull the sparkplugs, try a compression test and check your coolant level. Good luck, i'm hoping for the better.
Louis
Soon2Bgreat is offline   Reply With Quote
Old 09-27-2005, 03:28 PM   #6
jared nelson
Member#: 35075
for Trade with U!
PM me to trade.
is it running?
jared nelson is offline   Reply With Quote
Old 09-27-2005, 05:09 PM   #7
oldbluwrx
Member#: 61677
02 wrx
blue
The car runs still no missing or sputtering, I pulled the plugs and they all look the same color, There is water in the intercooler in the throttlebody, is it posible that water from the turbo is going through the pipeing to the intercooler vaporized and then turning back to a liquid form on the other side of it to the throttlebody?
Old 09-27-2005, 05:32 PM   #8
jared nelson
Member#: 35075
for Trade with U!
PM me to trade.
i wouldnt think that its vaporizing and reliquifying, but rather yes,that its just simply a turbo seal that is causing coolant to go into the charge pipe. thats going to be a bad thing if you hyrdolock your car, id say dont run it anymore untill you find that out. also, you can just bypass the water inlets outlets on the turbo, and just run it as a oil cooled unit.
Old 09-27-2005, 06:24 PM   #9
oldbluwrx
Member#: 61677
02 wrx
blue
I havent run it at all, I am in the prosess of removeing the motor and replaceing the head gaskets, when I get it back together I will bypass the water to the turbo.
Old 09-27-2005, 06:57 PM   #10
jared nelson
Member#: 35075
for Trade with U!
PM me to trade.
do you have bad compression? dont fix both things, its only either one or the other, its not like your turbos seals went out, and your motor popped gaskets at the same time. do you have bad compression?
02 WRX starts then dies after a backfire bmv68128 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 04-21-2009 09:05 AM
02 WRX starts then dies after a backfire bmv68128 Service & Maintenance 0 04-20-2009 09:27 PM
stumble and then after or backfire hokiewrx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 35 05-30-2006 02:12 PM
this thread has teh nitrous backfire!! El Camino Off-Topic 12 02-17-2005 11:31 AM
Question/Prob after installing Apexi Auto TT SloWrX Electrical & Lighting 2 07-31-2003 02:34 PM
