Old 10-06-2005, 05:30 AM   #1
avengermike
Member#: 88713
04 STi
Default Nitrous on my stock IC
hey everyone was sleepin when it hit me. i have a 3LB nos kit i use on my bike i was thinking about takin it off and using it to freez my IC. I have seen kits in SuperStreet mag's. was wondering if i could do something with copper pipe or something and make the setup that sits on the top of the IC my self just have holes drilled?
avengermike is offline   Reply With Quote
Old 10-06-2005, 10:51 AM   #2
Car vs. Driver
Member#: 81620
2004 350Z
406WHP/350WTQ
Before you get flamed ... you may want to edit your post and replace NOS with nitrous.
Just buy the kit if you want to do it, they go fairly cheap used.
Car vs. Driver is offline   Reply With Quote
Old 10-06-2005, 03:03 PM   #3
jared nelson
Member#: 35075
for Trade with U!
PM me to trade.
and if its a nos brand nitrous kit, then you should modify your post before someone flames you. unless its not nos brand, in which case ill need to delete my post all together.
jared nelson is offline   Reply With Quote
Old 10-06-2005, 03:12 PM   #4
nathansvt
Member#: 28650
I wouldn't use it with an open element air filter either. Stock box, fine. But you don't want to be sucking that into your motor if it vents underhood.
nathansvt is offline   Reply With Quote
Old 10-06-2005, 03:52 PM   #5
Celly
Member#: 48724
TMIC this is a Minor if not a Non-Issue...
FMIC, Then you might see this effect...
Celly is offline   Reply With Quote
Old 10-06-2005, 03:59 PM   #6
Car vs. Driver
Member#: 81620
2004 350Z
406WHP/350WTQ
Really, if you want to be creative, you could just use your fogger nozzle and mount it in a similar fash to the IC sprayer. It should have a good enough spray pattern to have some effect for you. I would just mount it right near the TB inlet.
Old 10-06-2005, 04:13 PM   #7
avengermike
Member#: 88713
04 STi
thanks pep, i was thinking about using the 90 deg spray to see if it would hit it. now i have three jest 020,022,024 which one should i use?, sorry all but it is a NOS setup sneeky pete setup for a bike, 3Lb bottle. How much would this help? right now im using a deicer containing meth in my spray tank, seems to work better then water. but the nos kit is on my bike only used it twice and would rather put it to use on the car.
here is the kit i have
Sneeky pete kit
Old 10-06-2005, 04:43 PM   #8
Celly
Member#: 48724
Sneeky pete kit
I would use the largest Jet possible. I have the DEI Cryo, and even with the spray bar, at speed, I have a feeling more coverage would be better.
Now, if you kept the IC Sprayer, and The NOS Kit, We could call you "Snowconez"
Old 10-06-2005, 04:46 PM   #9
avengermike
Member#: 88713
04 STi
lol ill see how it all works out ill leave the jets out and just use the 90deg spray pattern. can i fill my bottle with C02? that would be colder?
Old 10-06-2005, 05:14 PM   #10
Celly
Member#: 48724
Eh.. Dunno about colder... But it will be cheaper...
Old 10-06-2005, 11:40 PM   #11
Absubtle
Member#: 85862
Carbon Dioxide (boiling point meaning turning into a gas)
Boiling Point : -78.5 degC (-109.3 deg F)
Nitrous Oxide
Boiling point : -88.5 C (-127.3 deg F)
So basically the same. I have seen prices for CO2 higher than Nitrous... but I guess it depends on the area your in.
Absubtle
PA
Absubtle is offline   Reply With Quote
Old 10-06-2005, 11:44 PM   #12
2phless
Member#: 69343
1998 TransAm cnvrtbl
"Boiling" directly to gas (at 1 atm) = sublimation. A much more fun word to use than "boiling."
2phless is offline   Reply With Quote
Old 10-07-2005, 12:24 AM   #13
avengermike
Member#: 88713
04 STi
if i did want to try something with copper would i run into any problems feeding it nos or co2
Old 10-07-2005, 08:45 AM   #14
T-boner
Member#: 57608
All your boost are
belong to us! Mwahahahaaa
I would wonder about using nitrous. I don't know what the temperature is at which point it disassociates into free oxygen and nitrogen, but I would think CO2 would be inherently safer.
Save the nitrous for the driver and passengers!
(I know, it's denatured)
T-boner is offline   Reply With Quote
Old 10-07-2005, 09:15 AM   #15
Celly
Member#: 48724
572 degrees...
With TMIC it really doesn't matter. What i have found, is, the best solution is what is closest and cheapest. In My case, it is Nitrous.
With FMIC's People historiclly tend to suck in the C02 or N20 after it is sprayed into their intake. One Hurting performance, One helping. This is why this Mod is so widely debated. But, it can also be tuned for. The choice is yours.
I personally, have never seen a major performance increase WOT while spraying. A bit more piece of mind perhaps, but the butt dyno never gets hit with the wow factor...
*** HOWEVER! *** Living in florida, I have found the Cryo Kit Second to none fighting heat soak. Numerous time, I have been stuck in traffic on 95o+ days [Not a dry heat] and the car is a dog... Short 5 Second - 10 Second blast, can make all the difference in the world.
If your a Track whore, and the Cryo won't bump your class for Auto-x, or your a 1/4 Mile monkey, This can easily become your new best friend... While in staging, Just pop a burst off ever few mins, and then one final one before you run. This is much easier that some jerry rigged ghetto fan rig.
P.s. By mounting a bottle of ANYTHING in your trunk, you are now the idol of ever 16 year old who carries groceries out to your car.
NOS on my 03 wrx? simon930 Water/Methanol Injection, Nitrous & Intercooler Cooling 26 03-18-2010 12:17 PM
STi y-pipe on wrx stock IC DubURX05 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 04-22-2006 01:51 AM
NOS on a stock STi? Vampyr Proven Power Bragging 32 10-01-2005 08:56 AM
Help on Modifying Stock IC Splitter Jpapania Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 02-07-2005 01:13 AM
is my car "Over Maxed" on my stock turbo, fuel, and intercooler??? bruce cohen Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-26-2003 12:14 AM
