Old 09-26-2005, 11:44 PM   #1
Loki
Member#: 4543
2003 WRX
Impreza GC8 Speedometer trouble
Heyas, been awhile since I have poked around here
I'm having speedometer trouble. It fluctuates a lot, always below my real speed, kinda odd.
Any idea what causes this, and how I can fix it?
MY98 2.5RS, stock.
Loki is offline   Reply With Quote
Old 09-27-2005, 08:57 AM   #2
Loki
Member#: 4543
2003 WRX
Update: It stopped fluctuating. It stopped moving altogether.
Old 09-27-2005, 09:35 AM   #3
kingsubi
Member#: 19239
2011 WRX
Speed Sensor
kingsubi is offline   Reply With Quote
Old 09-27-2005, 10:05 PM   #4
Loki
Member#: 4543
2003 WRX
Yep, speed sensor(s)
I have a CEL with the following codes:
P1540 Vehicle speed sensor malfunction 2
P0500 Vehicle speed sensor malfunction
(one of these has to do with idle speed)
*sigh* So where is the speed sensor? Anyone ever replaced one?
Old 09-29-2005, 04:02 PM   #5
kingsubi
Member#: 19239
2011 WRX
Side of the tranny - easier to get to from underneath.
I think the 98s had a two wire sensor - 85082AC012
Old 09-30-2005, 01:01 AM   #6
2phless
Member#: 69343
1998 TransAm cnvrtbl
Clever wording.
I have had mine die momentarily and come back. Sometimes not long enough to throw a code, sometimes it did. I noticed it was often water related, and sometimes work-related (that is, I'd made a commotion under the hood before the issue with the speedo.) Last time I was in there I wiggled the connector at the tranny and pressed it in. Hasn't messed up since.
I'd check the connection. Make sure it's clean, fully clipped in. Trace the harness to see if there is a wire rubbing through the loom and become exposed / shorted. Mine is on the passenger side of the tranny but I doubt it's the same from model to model.
Maybe you'll get lucky and it's just a quick fix like that.
2phless is offline   Reply With Quote
Trouble shooting for catless exhaust WRX10 AccessPort 2 06-02-2010 11:36 PM
1985 GL Trouble Codes (22, 24, 73) Speedometer pegged at 125mph!!! Sierradump Normally Aspirated Powertrain 10 04-04-2009 08:06 PM
Q's Trouble with catch can Extreme trouble moorebl Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 01-24-2007 09:37 AM
('93-'01) What makes a speedometer needle "shakey" Dobes Impreza Forum 4 04-09-2001 12:15 PM
('93-'01) 2002 WRX - Can't see the speedometer! RidinLow Impreza Forum 13 04-07-2001 01:14 AM
