Old 09-26-2005, 11:33 PM   #1
MattSTi
Member#: 54885
2004 PSM STi
2006 Mazda MX-5 Race Car
Default I Need More Camber - But How Much?
After 6 track events this summer/fall I've noticed some abnormal wear of my RA-1's. The outside shoulders seem to be getting overheated and wearing more than then the center of the tire. This abnormal wear occurred with -2.5 camber up front, -1.5 in the rear, 0 toe all around. I know that I need more camber, but how much? I'm thinking -3.5, -2.5 or -2.0 would do the trick, but I don't have experience with those settings yet.
Any help would be appreciated.
-Matt
MattSTi is offline   Reply With Quote
Old 09-26-2005, 11:54 PM   #2
AlpoRS
Member#: 81338
2005 2.5 RS Wagon
Crystal Gray Metallic
this is kinda more of a suspension issue...maybe tire pressue is low, that could wear the outside a little more because you may be rolling over on the sidewall and wearing on the outside a bit iff tre pressure is low
AlpoRS is offline   Reply With Quote
Old 09-27-2005, 12:49 AM   #3
HornSharks
Member#: 66236
2004 PSM WRX Wagon
Towing a 13' Whaler
I think you should try posting this in motorsports or suspension along with your suspension mods and tire size and pressures. Assuming you're running reasonable pressures, it could be one of 2 things:
1) Your tires have too much grip for the suspension to handle, causing the outside front suspension to dip into the "bad" part of the camber curve where camber goes positive again. Running narrower or less-sticky tires, a larger front swaybar, or stiffer or higher front springs could help this.
2) You're just driving too fast and need to slow down a little more before turn-in. Any car will understeer if you're going fast enough.
HornSharks is offline   Reply With Quote
R134a for 03 WRX right? But how much? 0260B4U Service & Maintenance 10 08-21-2008 02:02 AM
Damn ticket, but how much? fluxcapacitor Southern California Impreza Club Forum -- SCIC 10 03-04-2007 09:14 AM
I need more HP, but how? 2.5rsDOHC Normally Aspirated Powertrain 10 09-13-2006 10:33 AM
I Need More Camber - But How Much? MattSTi Motorsports 30 10-01-2005 05:06 PM
camber kits......how much, and do they work? soobyfan Brakes, Steering & Suspension 4 03-03-2003 04:36 AM
