Old 09-27-2005, 01:13 AM   #1
ice_bomb
Member#: 37972
2003 Impreza WRX
Default Something weird happened
Hi guys, I have an 03 WRX. The CE lights has been blinking for several weeks.
I didnt take it to autozone to have the code read.
The seller who was the original owner told me that it was because of the downpipe or something like that. (i can't remember).
Anyway, today, I tried to fix my turbo timer. Then fix my factory alarm so I can arm the car while the timer is running.
After I cut the dark green wire on the Keyless entry module above the fuse box, my CE lights is gone.
Is this normal??
I have no idea. Help!
ice_bomb is offline   Reply With Quote
Old 09-27-2005, 02:43 AM   #2
nate49509
Member#: 22452
'04 WRX
witty comment goes here
What was the code when you had it checked?
nate49509 is offline   Reply With Quote
Old 09-27-2005, 03:49 AM   #3
ice_bomb
Member#: 37972
2003 Impreza WRX
I didnt have it read. So I dont know. but the CE light is gone now.
Old 09-27-2005, 10:50 AM   #4
tooocool49723
Member#: 67127
3.3 I <3/h8 my GF3
1.8-2.5-2.2-2.5-2.2-3.3
Ok, if it was blinking, that's a bad thing... a really bad thing.
tooocool49723 is offline   Reply With Quote
Old 09-27-2005, 11:16 AM   #5
nate49509
Member#: 22452
'04 WRX
It should still be stored the ECU. You should get it checked. And ya blinking is very bad.
Old 09-27-2005, 06:57 PM   #6
ice_bomb
Member#: 37972
2003 Impreza WRX
Ok, I've called a couple places to read the engine codes. But they're charging me $150 just to read the code?!?!?!?
Anyone know somewhere else cheaper? I'm in san francisco.
Old 09-27-2005, 07:03 PM   #7
nate49509
Member#: 22452
'04 WRX
Auto Zone?
Old 09-27-2005, 07:07 PM   #8
Mulder
Trust no one
Member#: 11170
02 WRX
05 GTO/11 Sonata(!)
Did you have the two green connectors plugged together under the drivers side dash? That can make the CEL flash constantly as it activates a diagnostic mode for the ECU. It may have gone away if the wire you cut was from one of those connectors. The green plugs should be left disconnected, and if this is indeed what happened you probably cut the wrong wire as it should not have had any affect on the diagnostic connectors or the CEL.
I'd suggest getting some help from a shop or someone with more experience before you cut any more wires.
Oh, and if the car had a CEL from a catless downpipe with no "fix" installed the light would be on steadily, not flashing.
Old 09-27-2005, 07:16 PM   #9
ice_bomb
Member#: 37972
2003 Impreza WRX
Autozone charge me for $150. It's weird.
Mulder, I cut the green wire on the Factory alarm module. It shouldn't affect anything. I followed the instruction from this forum. And, I didnt cut anything from the two connector you're talking about.
that's why its weird.
Old 09-27-2005, 07:31 PM   #10
Mulder
Trust no one
Member#: 11170
02 WRX
05 GTO/11 Sonata(!)
Hm, I know that in CA Autozone won't do free scans like they do in other states. But I was under the impression that they would allow you to borrow the scanner for a deposit and do it yourself? Maybe try a different Autozone, or ask for help in your local forum from someone with a scanner. Depending on why the light was/is flashing there may not be any codes stored.
No, if you really cut a wire from the security module it shouldn't affect whether the CEL flashes or not.
It's possible the wiring in this car has been modified by a previous owner, I'd suggest you get the factory wiring manual and start looking around.
Old 09-27-2005, 07:36 PM   #11
ice_bomb
Member#: 37972
2003 Impreza WRX
Yes I'm sure I cut the wire from security module. That's why it's weird.
Anyone in SF have engine code reader???
Do you think I can buy the code reader, use it, then refund it?
Old 09-27-2005, 10:38 PM   #12
tooocool49723
Member#: 67127
3.3 I <3/h8 my GF3
Code readers are available at walmart for <$100.
And they have a 30 day refund policy... But I kept mine because it can erase the CEL too, or reset the ECU whenever I want to.
Old 09-28-2005, 12:03 AM   #13
ice_bomb
Member#: 37972
2003 Impreza WRX
I can't find it in Walmart.com
Walmart is too far from my place. Any other options?
Old 09-28-2005, 01:05 AM   #14
ice_bomb
Member#: 37972
2003 Impreza WRX
I found a few code readers on ebay. Some of them are expensive, some only 30 bucks.
what's the difference?
Old 09-28-2005, 08:47 AM   #15
tooocool49723
Member#: 67127
3.3 I <3/h8 my GF3
the $30 ones are probably vehicle specific. one for ford, GM, and chrystler.
The more expensive ones will do things like real time data graphing/logging, essentially functioning as extra guages, but be warned, the subaru sample rate is very slow.
something really weird happening GetUpKid Transmission (AT/MT) & Driveline 1 09-26-2007 09:09 PM
something weird happened today WRXout Factory 2.0L Turbo Powertrain 5 06-19-2004 11:28 PM
Something weird happened... jmaluso Factory 2.0L Turbo Powertrain 0 02-13-2004 11:10 AM
Something Weird Happened BlackRex22 Southern California Impreza Club Forum -- SCIC 10 02-09-2004 11:34 AM
something weird just happened to my mouse vile Off-Topic 3 01-28-2004 06:19 PM
Message Board Statistics All times are GMT -4. The time now is 04:44 PM.
